Predlogi novic
Predlogi novic
BBC: Catholic church gives blessing to iPhone app
The Catholic Church has approved an iPhone app that helps guide worshippers through confession.
The Confession program has gone on sale through iTunes for ?1.19 ($1.99)
Bloomberg: Nokia Said to Be Near Software Partnership With Microsoft
Nokia Oyj is close to announcing a software partnership with Microsoft Corp., a bet that together the two companies can better challenge Google Inc. and Apple Inc., according to a person with knowledge of the discussions.
Rusija bo ukinila premikanje kazalcev.
There is intelligence on this planet after all...
TED Blog: Announcing TED Conversations!
TED Conversations was designed and built from the ground up to foster meaningful conversation among the global community who watch, share and discuss TEDTalks. TED Conversations all fall under 3 categories: Questions, Debates and Ideas.
CaqKa ::
 cobiss
cobiss
Usenix: Reliably Erasing Data from Flash-Based Solid State Drives
Reliably erasing data from storage media (sanitizing the media) is a critical component of secure data management. While sanitizing entire disks and individual files is well-understood for hard drives, flash-based solid state disks have a very different internal architecture, so it is unclear whether hard drive techniques will work for SSDs as well. We empirically evaluate the effectiveness of hard drive-oriented techniques and of the SSDs' built-in sanitization commands by extracting raw data from the SSD's flash chips after applying these techniques and commands. Our results lead to three conclusions: First, built-in commands are effective, but manufacturers sometimes implement them incorrectly. Second, overwriting the entire visible address space of an SSD twice is usually, but not always, sufficient to sanitize the drive. Third, none of the existing hard drive-oriented techniques for individual file sanitization are effective on SSDs. This third conclusion leads us to develop flash translation layer extensions that exploit the details of flash memory's behavior to efficiently support file sanitization. Overall, we find that reliable SSD sanitization requires built-in, verifiable sanitize operations.
ZaLoMaT ::
PaX_MaN ::
Siol bo od jutri zaradi odločb UNPIS "blokiral" strani www.expekt.com, www.bwin.com, www.bet-at-home.com in sl.sportingbet.com.
Na siol.net -> Delovanje storitev -> Nepotrebna blokada pod prisilo.
  • spremenilo: PaX_MaN ()
Čisto tako kot zanimivost, 19. marca naj bi bila Luna najbližje Zemlji (356.577 km). Seveda se ob tem "že tradicionalno" napovedujejo razne naravne katastrofe (vulkani, poplave itd.).
Morda se jo da povezati obenem še s to novico BBC: Why the Moon is getting further away from Earth
Potem ko se je Nokia "prodala" Microsoftu, je tu še naslednja novica:
Nokia: Important information about Ovi Mail
Nokia is partnering with Yahoo! to power and enhance your Ovi Mail experience. In the coming weeks you can enjoy an easier and faster Ovi Mail website, the integration of instant messaging into the mail web experience, and the ability to import your friends' email addresses from other email services you might already use.
You're all set to enjoy these service enhancements very soon.
Important to know
Once the transition starts, you will immediately begin receiving new emails into your updated Ovi Mail account, but you may not see your old emails for several days until the transition has finished. Don't worry because your emails are safe and are being moved to Yahoo!. You will see them in your inbox again once the transfer is complete. We will confirm the completion of the transfer in a separate email.
We're sorry for any inconvenience that this might cause, but we assure you that this is a temporary situation that will be resolved as soon as the move to Yahoo! is complete.
Thank you for joining us in using the updated Ovi Mail service. We look forward to bringing you further enhancements in the coming weeks!
Sincerely,
Nokia
Gandalfar ::
Tole je ze pol leta staro: http://www.intomobile.com/2010/05/24/no...
Aha ok, hvala za INFO:) ... očitno so sedaj uradno začeli s premikom (ker so nas uporabnike začeli obveščati o tem).
onlive.com - igranje iger na remote
Zdaj dela celo pri nas. (free trial sem probal, ne vem, kako je s plačanjem)
Probal sem zaenkrat le Metro 2033. Je malo preveč lag-a za normalno (akcijsko) igro. (je pa res, da sem baje nadpovprečno občutljiv na take "malenkosti").
Japonska katastrofa: zaskrbljenost in strah pred učinkom domin - delo.si
Zadnji odstavek:
Predsednik Inštituta za svetovno gospodarstvo iz Kiela Dennis Snower je v intervjuju za Süddeutsche Zeitung izrazil bojazen, da bi se utegnil zgoditi učinek domin. Če izpade oskrba podjetij z japonskimi čipi, bi utegnilo priti do precejšnjih težav v avtomobilski industriji in računalniških podjetjih, tako v Aziji kakor tudi na drugih celinah. Ker ključne težave, ki so povzročile svetovno finančno krizo, še niso odpravljene in ker svetovno gospodarstvo kljub rasti še nima trdnih temeljev, so zunanji šoki, kakršen je Japonska katastrofa, po Snowerjevem mnenju skrb vzbujajoči.
Brez igrač bomo! :P
  • spremenil: MrStein ()
Roadkill ::
Ü
Cepivo proti radioaktivnosti?
Ruski znanstveniki iz Vladikavkaza v Severni Osetiji so izdelali cepivo proti radioaktivnosti, kar je edinstven primer v zgodovini. Uporabljati naj bi ga začeli kmalu, da bi z njim nevtralizirali izpostavljenost radioaktivnosti pri tistih, ki bodo po jedrski nesreči v nuklearki Fukušima čistili teren.
Samo so potem zgleda umaknili to besedilo.
http://dnevnik.si/tiskane_izdaje/dnevni...
Stran v google cache še ima to.
CaqKa ::
  • spremenil: CaqKa ()
Primoz ::
CaqKa ... saj če bi bral S-T novice, ne bi bilo nobene škode.
There can be no real freedom without the freedom to fail.
CaqKa ::
za gugl music sem našel ta drugo pa ne...
lurker ::
Val novega mišljenja o avtorskih pravicah?
Nemški dvotednik c't (naklada 320 tisoč)
je v številki 2011/01 objavil komplet člankov o HD filmih preko interneta:
- Die Welt in HD
Hochaufgelöste Inhalte aus dem Netz
Splošno of HD posnetkih na voljo na internetu. Zastonj, podcast-i ipd.
- Nur 48 Stunden
HD-Filme und -Serien aus Online-Videotheken
HD filmi in serije iz online videotek (plačljiva ponudba).
- Raubschau
So funktioniert die Moviez-Szene
Opis ne-legalne scene, kako deluje, kje, kateri tool-i olajšajo download (JDownloader - iz enega klika downloada po rapidshare&co razpršene dele, združi v RAR fajl in ekstrahira film, pripravljen za gledanje). Omeni se tudi Usenet. Konča z mislijo, da se tako ponujajo filmi. Velika izbira, brez DRM navlake, brez komplikacij: vtipkaš ime filma, klikneš, počakaš na download, gledaš (na napravi po svoji izbiri).
Članki žal niso v celoti javno dostopni.
Nato še uvodnik v številki 2011/7: http://www.heise.de/ct/inhalt/2011/07/2/
(tukaj v celoti berljiv)
Na kratko: Serije so dostopne v Nemčiji leto in več po predvajanju v ZDA. Ni na voljo originalnega tona. Predvajajo se na "obskurnih" kanalih, ob obskurnih časih. Smo leta 2011. Človek hoče serijo istočasno kot američani. OK, dan pozneje. Če tega TV ne omogoča, se to naredi na Rapidshare in Usenext. Torej ni, da ne bi radi plačali (internet plačajo, Rapidshare account se plača, Usenext članstvo se plača).
Naj se ponudniki učijo iz tega!
PaX_MaN ::
V okviru projekta >>Ljubljana - svetovna prestolnica knjige<< je bila 31.3.2011 organizirana videokonferenca na temo >>Svoboden pretok idej in univerzalna pravica dostopa do informacij<<. V okviru razprave je
J?niš K?rklinš predstavil aktualne programe UNESCA za področje komunikacij in informacij. V razpravi so sodelovali dr. Sandra Bašić-Hrvatin iz Univerze na Primorskem, Simon Delakorda, direktor Inštituta za elektronsko participacijo (INePA), dr. Marko Ivanišin iz Univerze v Mariboru, mag. Marko Bonač, direktor Arnesa, Vuk Ćosić, spletni strateg in dr. Marko Milosavljević iz Univerze v Ljubljani. Videokonferenčno okroglo mizo je vodil dr. József Györkös, državni sekretar na Ministrstvu za visoko šolstvo, znanost in tehnologijo.
CaqKa ::
Prek 50% opazovanih podjetij uporablja nelegalno programsko opremo
http://www.sio.si/sio/sio_portal/novice...
http://www.google.com/+1/button/
CaqKa ::
googlov odgovor na like button je plusone button :>
Bananovec ::
Regards, Apple
PaX_MaN ::
Slovenija za uravnoteženo kaznovanje kibernetskih napadov
Informacijska vrednost novice je bolj švoh, ker pove bore malo, edino tale del zna biti zanimiv:
Odprta vprašanja so tudi glede opredelitve obteževalnih okoliščin in glede uporabe orodij za storitev kaznivih dejanj in vse to je še stvar pogajanj, je pojasnil minister Zalar.
Pa seveda da se ve, da se sprejema, da se jim lahko začne težit kaj ja in česa ne.
Roadkill ::
Ü
ZaLoMaT ::
Here is what 2011 holds for Windows Phone 7 - on video (gsmarena)
This is Windows Phone Next -- developers take notes (video) (engadget)
Microsoft delivered a big batch of mobile happiness at its annual MIX developers' conference this morn, promising a host of major features including multitasking, background audio, push notifications and raw sensor data (not to mention over 1500 new APIs) in the next version of Windows Phone. Of course, it's one thing to tell you how pumped attending developers might be to bite into a nice juicy mango next month and another to see for yourself, so feast your eyes on the best of Windows Phone Next in the video above. Not bad, eh?
PaX_MaN ::
PaX_MaN ::
LHC odkril "božji delec".
Pravkar slišal po radiju.
Google bo vedel več.
PaX_MaN ::
Bananovec ::
Regards, Apple
galu ::
Moje sožalje vsi PlayStation uporabniki..:'(
Ampak treba to dat v javnost.
http://ps3.ign.com/articles/116/1164641...
Bastards..!
Tako to gre.
Ubuntu 11.04 je zunaj, kaj zdaj? Orgazmirajo vsi? ;)
http://www.ubuntu.com/download/ubuntu/d...
Tilen ::
Gapi ::
http://www.mobitel.si/splosno/za-medije... Sej ne vem če tole vredno novice. Verjetno večina Slo-tech uporabnikov niti ne ve da obstaja tudi IPV6.
Če pogledam datum objave na mobitelovi strani vidim da je to pravzaprav stara novica. Sedaj je pa na vas da odločite ali to za objavo v novicah ali ne.
No person is rich enough,to buy back his past.
Sedaj je že novica, da naj bi se tudi Microsfot zanimal za Skype ...
BBC: Microsoft in talks to buy Skype, report says
Umazane igre>:D
Facebook Busted in Clumsy Smear on Google
The social network secretly hired a PR firm to plant negative stories about the search giant, The Daily Beast's Dan Lyons reveals--a caper that is blowing up in their face, and escalating their war.
PaX_MaN ::
Tilen ::
Jutri konec sveta.
Članki v vseh rumenih časopisih...
(petek je...)
Gmail uvedel oznake pomembnih (Important) mailov.
Ne vem, če je to isto, kot že omenjeni Priority mail...
PrimozR ::
AFAIK je, rahlo bolj streamlineano.
7 / 53
Nadomestilo za Adobe Creative Cloud (strani: 1 2 3 )
Oddelek: Programska oprema
12945747 (490) opeter
Skripal (strani: 1 2 3 )
13143012 (28761) Pac-Man
