Forum » Strojna oprema » router FBR-1418TX in fowarding
Juventus ::
kako naj fowardam port 80. Grem na fowarding roules, pol pa na virtual server in vpisem port 80 samo dela samo znotraj LANA!
Kj eje problem.
VSe moznosti pod fowarding rules
Forwarding Rules
Virtual Server
- Allows others to access WWW, FTP, and other services on your LAN.
Special AP
- This configuration allows some applications to connect, and work with the NAT router.
Miscellaneous
- IP Address of DMZ Host: Allows a computer to be exposed to unrestricted 2-way communication. Note that, this feature should be used only when needed.
- Non-standard FTP port: You have to configure this item if you want to access an FTP server whose port number is not 21 (when Client uses active mode).
Hvala
Kj eje problem.
Forwarding Rules
Virtual Server
Special AP
Miscellaneous
Hvala
Juventus ::
se mogoce komu sanja zakaj izven mreze apache server ni dostopen, znotraj mreze iz katerega koli racunalnika ce vpisem http://82.149.25.222/ se odre apache serevr in vse kar pase zraven, ce pa kdo proba to izven mreze pa ne dela.
Je mozno da je problem v firewallu ki je vgrajen v ruterja ali firmware?
Hvala
Hvala
psychoshorty ::
Kolikor vidim imas Triero. Ni kriv router, kriva je Triera, saj privzeto blokira (fizicnim) uporabnikom porte od 0 do 1024.
Tomay ::
Jaz imam web server na portu 8080 + no-ip.com, ki ti lahko forwarda na port 8080.
T2 Here I Come
T2 Here I Come
Voodoo 4Ever
| » | se nekaj glede apacheOddelek: Izdelava spletišč | 1770 (1597) | Ziga Dolhar |
| » | Postavitev lastne www straniOddelek: Izdelava spletišč | 3217 (2498) | flipflop |
| » | Serv-U+no-ipOddelek: Omrežja in internet | 1380 (1263) | CaqKa |
| » | lastna domena z dinamicnim IPjem. Kako?Oddelek: Omrežja in internet | 2090 (1946) | sgdjkdlsugi4 |
| » | no-ip DUC in Serv-U!!!Oddelek: Omrežja in internet | 2138 (2097) | pivmik |
