Forum » Programska oprema » FTP Server (Cerberus) za routerjem Linksys WRT54GC
sasok ::
Imam dinamičen ip preko DYNDNS pa domeno, ki javlja spremembo. Imam inštaliran ftp server freeware Cerberus (www.cerberus.com), ampak nikakor ne morem vzpostavit povezave, da bi mi delal od zunaj iz druge lokacije (WAN), medtem ko mi znotraj omrežja (LAN) deluje brez težav.
Torej kako naj naštimam PASV mode na programu - naj uporabim "Auto detect", "Use different IP for PASV (usually router ip)" ali "Use DNS service". Poskusil sem menda že vse troje, pa vedno ista napaka (izpisana spodaj).
User se lahko logira, ampak napaka pride pri prenosu, ko zaštarta PASV (passive) prenos, z PORT (active) pa spet isto.
Imam router Linkysy WRT54GC, na katerem se naredil port range forwarding takole:
Računalnik na katerem bo server ima notranji naslov 192.168.1.100, ruter ima 192.168.1.1
1024 - 3500 TCP na 192.168.1.100 ali na 192.168.1.1 (tudi isto)
20 -21 TCP na 192.168.1.1 ali 192.168.1.100 (ista pašta)
MI lahko kdo iz izkušenj svetuje kaj in kako naj odprem porte. Tudi Windows Firewall sem sključil.
Izpis loga, ko se prijavi nekdo od zunaj:
Oct 01 10:43:06 Added to Windows Firewall Exception list
Oct 01 10:43:06 Shutting down local Interface 2 located at 192.168.1.100
Oct 01 10:43:06 Vendor: GenuineIntel
Oct 01 10:43:06 CPU: Intel Pentium IV
Oct 01 10:43:06 Number of Processors: 1
Oct 01 10:43:06 Operating System: Microsoft Windows XP Professional
Oct 01 10:43:06 Additional Info: Service Pack 2 (Build 2600)
Oct 01 10:43:06 Cerberus FTP Server started
Oct 01 10:43:06 Local Host: xxx44
Oct 01 10:43:06 Local Interface 3 located at 192.168.1.100
Oct 01 10:43:06 Listening on Port 21
Oct 01 10:43:42 1 Incoming connection request on interface 192.168.1.100
Oct 01 10:43:42 1 Connection request accepted from 84.255.238.221
Oct 01 10:43:42 1 USER k
Oct 01 10:43:42 1 331 User k, password please
Oct 01 10:43:42 1 PASS ***********
Oct 01 10:43:42 1 230 Password Ok, User logged in
Oct 01 10:43:42 1 OPTS utf8 on
Oct 01 10:43:42 1 501 Unsupported feature
Oct 01 10:43:42 1 SYST
Oct 01 10:43:42 1 215 UNIX Type: L8
Oct 01 10:43:42 1 SITE help
Oct 01 10:43:42 1 502 Unknown site command
Oct 01 10:43:42 1 PWD
Oct 01 10:43:42 1 257 "/" is the current directory
Oct 01 10:43:42 1 TYPE A
Oct 01 10:43:42 1 200 Type ASCII
Oct 01 10:43:42 1 PASV
Oct 01 10:43:42 1 227 Entering Passive Mode (192,168,1,1,4,4)
I'll make you an offer you can't refuse.
sasok ::
A nihče ne ve kako bi to uredil, da bi mi delalo, kaj je napaka. Mogoče kakšna pripomba kako nastavit, da mi bo delal ftp server na računalniku za ruterjem.
Erwin ::
Downloadi si Serv-U program kr je res pregleden program in mislim da z njim ne boš imej težav
rebro ::
Mislim, da ima FTP program RaidenFTPD prav to možnost opisano v helpu...poglej pod: How to run RaidenFTPD behind a Linksys DSL/Cable route (predzadnji naslov.
Je pa res, da je program kar zajeten z ogromno možnostmi za uporabo, jaz jih še dešifriram...tak da se raje loti Serv-Uja, ki ga priporoča Erwin, ker je dosti bolj na easy.
sasok ::
Imam že od prej nastavljeno vse prav tako kot piše na tem helpu, ki si ga predlagal, pa vseeno mi javlja tole zgoraj opisano napako, ko se hoče prijavit s passive ali active mode. SIcer pa je moj Cerberus FTP Server tudi dost preprost programček, zelo podoben Serv-U, ki ga prav tako poznam, samo da je Cerberus freeware za privatno rabo Serv-U pa je pač potrebno malo bolj piratsko naložit je res? Torej, še vedno iščem idejo/rešitev. HVala.
sasok ::
No, sem poskusil tudi s Serv-U in mi javlja isto napako ... Še izpis napake iz client ftp programa, kar se tiče Serv-U je verjetno enako kot prej..
STATUS:> This site supports SIZE.
STATUS:> This site can resume broken downloads.
COMMAND:> TYPE A
200 Type set to A.
COMMAND:> REST 0
350 Restarting at 0. Send STORE or RETRIEVE.
COMMAND:> PASV
227 Entering Passive Mode (193,77,176,51,13,30).
COMMAND:> LIST
STATUS:> Connecting ftp data socket 193.77.176.51:3358...
ERROR:> Can't connect to remote server. Socket error = #10060.
ERROR:> Failed to establish data socket.
Še enkrat, če se je kdo že s tem ukvarjal in mu je znana napaka, bi prosil pomoč. Hvala.
COMMAND:> TYPE A
200 Type set to A.
COMMAND:> REST 0
COMMAND:> PASV
COMMAND:> LIST
darkolord ::
Poleg 21 moraš na rouerju odpret (forwardat) tudi porte, ki jih imaš na serverju nastavljene pod Passive
- spremenilo: darkolord ()
sasok ::
Vem, saj sem napisal že v prvem postu, da imam forwardirane poste 20 in 21, pa tudi 1025-3500 (za passive), katere sem tudi poskusil zamenjat z višjimi kot predlagajo na nekaterih drugih helpih.
Še kakšna ideja?
Še kakšna ideja?
Kekec ::
za port 20 ne rabiš odpirat nič ker to je za ctive mode in če se ne motim pri tem načinu odpre client, drugače pa maš log na routerju pa poglej če kaj pride not potem pa še na samem računalniku požen kakšen netstat pa poglej če sploh kaj posluša na tem portu ki ga client hoče uporabit.
sasok ::
No, da po skoraj enem letu (delam na enaki zadevi kot takrat, pa sem spet naletel na to temo) obrazložim v čem je bila težava in če je še kdo, ki ima podobno.
Težava je v tem, da ima firmware od routerja Linksys WRT54GC napako in ne spušča (posreduje) pravilno skozi odprtih portov. Na njihovi uredni strani se najde posodobitev firmware (zdaj je že tretja verzija). Potem pa samo odpreš FTP port 20~21 in pa po potrebi še PASV porte (odvisno od nastavitev).
| » | DronesOddelek: Problemi človeštva | 2103 (1557) | vostok_1 |
| » | FileZilla ftp strežnikOddelek: Omrežja in internet | 5990 (3894) | vice boy |
| » | FTP dostop Bulletproof serverOddelek: Omrežja in internet | 2225 (1974) | kunigunda |
| » | 3500+ overclocking & neznan restartOddelek: Hlajenje in modifikacije | 1792 (1498) | KrCbelca |
| » | Prihod Socket 939 Athlon 64 procesorjevOddelek: Novice / Procesorji | 4339 (4339) | AtaStrumf |
