Forum » Pomoč in nasveti » Kako inštaliram Win 2000 iz dosa.
segi ::
Da kako. Imam eno verzijo tega win samo ko poženem setup mi napiše da kao dela samo pod windowsi!!
POMOČ PROSIM
POMOČ PROSIM
Segi podobo na ogled postavi,
ker bolj resnico ljubi kakor hvalo,
zad skrit vsevprek posluša, kaj zijalo
neumno, kaj umetni od nje pravi
ChiefThunder ::
v biosu naštimi, da je first boot device cd-rom, pol ti pa prikaže meni, pa izbereš...
... po liniji najmanjšega odpora. ;)
segi ::
Sem naštimal in mi pri mojem cd-ju to ne pali.
Imam ga od kolega in je piratski.
Ali je mogoče da ni prav posnet!??
ToniT ::
Na CD-ju imaš fajl makeboot.exe - zaženi tega in naredil ti bo štiri sistemske diskete za inštalacijo win2000 iz disket.
Če lahko prideš do CD-ja preko dosa, pa uporabi winnt.exe za inštalacijo namesto setup.exe.
- spremenil: ToniT ()
segi ::
bom probal. Hvala za enkrat.
Samo to!
kje najdem winnt.exe??
V kateri mapi??
Samo to!
V kateri mapi??
segi ::
cool
hvala
hvala
Tr0n ::
If XP will not install from the CD or if you have a new drive with no operating system on it yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt32.exe to launch the setup from the hard drive.
Boot Windows 98
andrej ::
hm, ta druga navodila ne vem ce bodo stilama, ker pod DOS-om ne mores zagnat winnt32.exe...
Definitivno pa ce instaliras iz DOS-a dodaj smartdrv, drugace bo kopiranje trajalo celo vecnost...
segi ::
ja kaj pomeni smartdvr
ToniT ::
Smartdrv.exe je program, ki si rezervira del RAMa za cache pri čitanju z diska (ali CD-ja). Razlika pri nameščanju win2k je neverjetna. Ko smo testirali, smo rabili brez smartdrv za prvi del namestitve eno uro, s smartdrv pa cca 10 min.
segi ::
cool!!
segi ::
valda!!!
Hvala vsem za pomoč!
| » | Windows XP namestitev brez uporabnega CD pogonaOddelek: Operacijski sistemi | 3175 (2929) | Mercier |
| » | HP laptop 6715b free dos: setup windows xp in driverjevOddelek: Operacijski sistemi | 8082 (6813) | Gwanaroth |
| » | Nastavitev Win XpOddelek: Pomoč in nasveti | 2028 (1900) | Jana |
| » | Windows XpOddelek: Pomoč in nasveti | 1186 (994) | Gandalfar |
| » | W2K INSTALACIJAOddelek: Pomoč in nasveti | 1311 (1264) | ABX |
