Forum » Znanost in tehnologija » Zakaj so električni avtomobili prava stvar
Nikec3 ::
Servis je tako skromen, da si že zmišljujejo svoje fore, da ti lahko kaj zaračunajo. Still tho, še vedno zelo ugodno napram ICE. More or less gre za pregled, menja se bore malo.
Kona EV ima servisni interval na 15k km, moj i20 dizel ima na 30k. Mene je servis stal 200€, tako da trenutno je servisiranje mojega dizla cenejše od EV-ja.
3, 2, 1, naj se rage začne.
@WarpedOne o Elonu Musku:
WarpedGone ::
jernejl:
Ja, baraba grda elonova ne spoštuje zakonov, butasti nemci mu pa to dopuščajo.
Al pa je butast nekdo drug ...
Rage boš našel na forumu lastnikov Hyundai Kone.
Sploh so "smešna" uradna pojasnila hjundaja zakaj tako... "smešna" v smislu "a se hecate?"
Tesla očitno daje še manj od zakonske omejitve in nemcev.
Zbogom in hvala za vse ribe
jernejl ::
Your Rights Under Local Laws
This New Vehicle Limited Warranty provides you with rights that are in addition to the statutory
warranty rights that you may have under applicable local law according to the Warranty Region
where your vehicle was first purchased. These statutory warranty rights can not be modified,
a„ected or substituted. Tesla also refers you to Dispute Resolution and Country-Specific
Consumer Disclosures on page 11.
Se zdaj zavedaš kako neumen si? A sem res moral to prilepit kar bi moralo bit jasno vsakemu, ki so ga spustili iz osnovne šole?.
lufthammer ::
Sej ni tko težko poguglat:
Vehicle Warranty
Your vehicle is covered by a New Vehicle Limited Warranty for 4 years or 80,000 km, whichever comes first. The Battery and Drive Unit in your vehicle are covered for a period of:
Model S and Model X - 8 years (with the exception of the original 60 kWh battery manufactured before 2015, which is covered for a period of 8 years or 200,000 km, whichever comes first).
Model 3 - 8 years or 160,000 km, whichever comes first, with minimum 70% retention of Battery capacity over the warranty period.
Model 3 with Long-Range Battery - 8 years or 192,000 km, whichever comes first, with minimum 70% retention of Battery capacity over the warranty period.
These warranties cover the repair or replacement necessary to correct defects in the materials or workmanship of any parts manufactured or supplied by Tesla, which occur under normal use.
For further details, please review the New Vehicle Limited Warranty.
Vehicle Warranty
jernejl ::
S tem si zgolj dokazal, da si neumen ti. Garancija pri Tesli je, kot je že nekdo zgoraj prilepil, 4 leta ali 80.000 km, kar pride prej. Če voziš veliko, kar za EV ne bi smelo biti neobičajno, sicer se slednji ne splača, lahko teh 80.000 km dosežeš prej kot v dveh letih.
Seveda poleg obstajata tudi jamstvo za stvarne napake in obvezna garancija, ki sta določena z zakonom in trajata dve leti oziroma eno leto, ampak to dvoje je enako tako za Golfa TDI kot za Teslo 3.
Najprej bluziš o tem, kako ima Tesla daljšo garancijo od TDI... ko te postavim na laž, pa se začneš zgovarjat na zakonsko določena jamstva, ki so enaka za vse proizvajalce.
Ti si res debil. Vw ima garancijo po zakonu, enako kot tesla, vw ima poleg tega 0, tesla pa 4 leta na vse dokler ne presežeš 80,000 km, in 8 let na pogon ali dokler ne presežeš km. Kater ima več garancije je jasno vsakemu, ki ni debil, in vsakemu je tudi jasno kaj si prej napisal - da tesla ne dosega niti garancije po zakonu. Torej, tvoja diagnoza je jasna.
In kaj zaboga traja eno leto??? Obvezna garancija na avte je 2 leti, nič eno. Kako ima nekdo s tako malo, oz. nič pojma o čemurkoli, tolk za napisat v tej temi...
- spremenil: Utk ()
MrNighthawk ::
IL_DIAVOLO je izjavil:
Lol kaj pa bos servisiral? Ventile na gumah?
Zapelji se v delavnico pa boš videl. Sem bral protokole Nissana za novega Leafa. Tako da ...
KONA EV:
Če je račun prevelik potem imajo "fore", ker pri ICE je vsak račun zagotovo legit
Uradni servis mi je za 120k aka velik serivs (menjava praktičo vsega kar je potrebno) za ICE računal 260€ (cca 50€ je bilo samo olje), na neuradnem servisu je bilo cca 210€.
Tako, da tale račun od EVja je sicer manjši ampak glede na to, da to ni servis, ki ga delaš vsako leto, ni tako drastično zmanjšanje stroškov, je pa manjše.
ziga1990 ::
^^ samo vseno to je samo redno vzdrževanje kaj pa ko kaj crkne verjetno so tu ICE vozila cenejša?
Nikec3 ::
- spremenil: Nikec3 ()
ziga1990 ::
ena stvar ponavadi pri ICE je tako, da predmet ki odpoveduje kaže znake, da bo kmalu odpovedal pri EV pa samo crkne in je avto mrtev
Sedaj smo pač v obdobju "poskusnih zajčkov" za EV; kjer si pač potrošniki lahko sami izberejo, ali bodo testni subjekti ali ne in če da, potem za možnost testiranje tudi plačajo polno ceno za e-vozilo (države pri tem sicer malo pomagajo proizvajalcem, bodisi s subvencijami, nižjimi davki itd.).
Ko boš čez kakšnih 10 let teh testiranj konec, bomo pa končno lahko tudi ostali začeli množično kupovati EV-je; razen seveda, če se bo takrat izkazalo, da tovrstni EV-ji s težkimi baterijami niso prava stvar in bo na obzorju druga alternativa (ki bo sicer najbrž tudi na elektriko, a z drugače izpeljano rešitvijo).
Tako da v letu 2019 EV-ji še niso postali prava stvar. Nekako dvomim, da bodo postali prava stvar v letu 2020; razen morda s kakšnim državnim prisilnim dekretom (prepoved vseh ostalih vozil ipd.).
nekikr ::
Kakšni testni zajčki neki, potegni že glavo iz riti. EV je prodanih že cel kup, pa nič ne kaže, da bi bili vsi ves čas na servisu. Glede na vse podatke je trenutno stanje tako, da je vzdrževanje lahko malenkost cenejše, in da se kvarijo nekje toliko kot vsaka druga potrošniška krama. Se pravi nikakor ne drži, da so brez stroškov vzdrževanja in 100.5000x cenejši in enostavnejši, nikakor pa tudi ne drži, da odkartaš 50.000€ in naslednji dan neuporaben kup pleha pelješ na odpad.
jernejl ::
VW ima dveletno garancijo brez omejitve kilometrov. Tesla ima štiriletno garancijo z omejitvijo 80.000 kilometrov. (razen določenih delov, za katere veljajo drugačni pogoji)
Kateri ima več garancije je odvisno od tega, koliko kilometrov prevoziš letno, in ne od tega, da si ti debil.
Če prevoziš 50.000 km letno, boš pri Tesli ob garancijo po približno letu in pol, pri VW-ju pa po dveh letih.
Minimalna obvezna garancija na avte je kar eno leto, nič dve leti, razen za debile tvojega kova. Kolikšna je garancija v tvojih blodnjah, si lahko sam izbereš, a to z resničnim življenjem kaj veliko nima opraviti. Kako ima nekdo s tako malo, oz. nič pojma o čemurkoli, tolk za napisat v tej temi...
lejko0 ::
Sem na hitro preletel zadnjih nekaj strani teme in lahko recem, da opazim en kup brezciljnega prerekanja in prisotnost kupa teoretikov ter "dvornega norčka", ki v svoji zaslepljenosti namesto, da bi podpiral EV na splošno in ga s tem promoviral zdaj pravi, da je prava samo njegova izbira (znamka).
Me pa vseeno zanima, kaj mi priporočate za resničen problem. Kupujem nov avto do 30k eur - zaradi kilometrine (cca 40kkm) kupujem testnega, oz rabljenega do 1 leta. Gledam audi a4, bmw 3, vw passat (vse dizel). Dizel zato ker imam relacijo do službe 60km (v eno smer), od tega je 95% avtoceste (povprečno vozim po acc vozim 150kmh, ampak bi bil pripravljen to spustiti na 130kmh v primeru nakupa EV). Zdaj me pa zanima ali obstaja EV v tem cenovnem rangu, ki bi me prepričal v nakup.
Sam mislim, da EV market sploh ne ponuja alternative. Na eni strani so vozila s premajhno kapaciteto, kjer bi se pozimi (če ne takoj pa čez nekaj let) na acc tresel ali bom prišel do doma (razni e-golfi) na drugi strani pa precej dražji ev s tisočimi kompromisi (manjši prtljažnik, brez servisev v slo...). Vseeno bom vesel, če mi kdo s podatki (brez verskih vložkov) dokaže, da obstaja ev alternativa.
ziga1990 ::
^^ kaj pa PHEV avtomobili^^
J.McLane ::
Pri tvoji uporabi je omejitev na točno nakupno vrednost vozila totalno zgrešeno. Če delaš 40k km letno pomeni, da za dizel zagoniš ca. 3.000 € letno, z EV bi prišel skozi z manj kot 1.000 €. Torej 2.000 prihranka vsako leto, ali 10.000 prihranka v 5 letih, v resnici še več.
Torej zakaj ne EV za 40k €?
Morda zato ker želiš kupit EV samo zato, da bi prišparal, ne bo šlo tako na izi.
No ja, te lahko kaj hitro udari po zepu. Enemu je zaradi električnega udara uničilo elektroniko v zoe-ju(ne zmisljujem si) , skode za slabe 3 jurje, ki seveda ni pod garancijo. Zavarovalnice se tudi znajo hitro izgovorit na malomarnost, kar tudi je.
Kaj ce ti poskoduje baterijo do te mere, da jo lahko stran vrzes in moras iz lastnega zepa kupit novo? To je takoj 5-10k. Da sploh ne omenjam ostalega kablovja.
To niso heci.
J.McLane ::
Saj, malomarnost je tudi, če v dizla natočiš bencin.
Me pa zanima kaj konkretnega ja ta lastnik Zoe ušpičil, da je prišlo do električnega udara? Je skušal napolnit 12V baterijo?
J.McLane ::
Kako je to lahko malomarnost voznika? Udar strele je stvar zavarovalnice, itak da garancija vozila tu nima veze.
EV odpade.
|HP EliteBook|R5 6650U|
WarpedGone ::
Levers to unleash value
Dr. Herbert Diess Chairman of the Board of Management Volkswagen AG
VW leta 2020 software še vedno meri s številom vrstic kode.
To se je za zgrešeno pokazalo okrog leta 1970 ...
Ampak ampak ampak, VW se vsaj zaveda, da SW obstaja in je bistven.
Kakšna Honda na drugi strani ... Honda CEO Peers Into The Future, Sees Nothing But Piston Power From Here To Eternity
Al pa mazda: Mazda wrongly says long-range EVs are worse for CO2 than diesel cars. Še VW se z njimi ne strinja.
Globokost glave v riti je presunljiva ...
- spremenilo: WarpedGone ()
codeMonkey ::
Zakaj si tako skromen? Povej vec kje so se zmotili pri softverju in zakaj naj bi bili njihovi zakljucki ter odgovori na problematiko napacni. Bo softverja manj? Je bolje da se vedno kompletno platformo zaupajo Tier 1 in Tier 2 partnerjem? Ali pa samo pises kar tako, in razvoja avtomobilskega softverja nisi videl niti od dalec.
WarpedGone ::
Zamenjaj svoj nick, nisi še kvalifciran za kodersko opico ...
Angleške vire že konzumiraš al si še na slovenskih audio tutorialih?
Source lines of code @ Wikipedia
codeMonkey ::
Se vedno nisi nic povedal.
Using lines of code to compare a 10,000-line project to a 100,000-line project is far more useful than when comparing a 20,000-line project with a 21,000-line project. While it is debatable exactly how to measure lines of code, discrepancies of an order of magnitude can be clear indicators of software complexity or man-hours.
WarpedGone ::
En odstavek. Preberi še ostale. Pa še kak drug link in vir.
Postani vsaj code-monkey.
jernejl ::
WarpedGone je izjavil:
Predstavitev pove, da se bo število vrstic povečalo. Ker nisi podal nobenega argumenta, zakaj se to ne bo zgodilo, si pač izpadel popoln tepec, ki se vtakne v neko reč, o kateri nima pojma, in se ji posmehuje, čeprav ne ve, zakaj.
vostok_1 ::
There will be chutes!
It came from the lab.
WarpedGone ::
Danes nobena softverska firma obseg/zahtevnost projekta ne planira skozi št. vrstic kode.
To počnejo le napol upokojeni slinarji, ki so svoj prvi in zadnji program napisal leta 1978.
To je deadgiveaway, da VW ne obvlada softwarskih projektov sploh.
Če komu to ni bilo očitno že, ko so priznal, da bo več deset tisoč sestavljenih id3 čakalo na parkirplacih še vsaj 3/4 leta na dokončan SW.
Dokončan... O dokončanem SW zopet sanjajo le ljudje, ki še niso nikol dejansko speljali SW projekta, ga dal v produkcijo in nato popravljal in vzdrževal.
Ampak nepoučena javnost zaupa in verjame naprej v vsemogočne švabe...
Čeprav se njihov OS popravlja vsak teden. Ampak ne, VW bo SW dokončal ...
jernejl ::
Aha, tudi nepismen ni. Pripeta predstavitev pravi zgolj to, da se pričakuje večje število vrstic kode, ne pa, da planirajo povečat število vrstic kode na X milijonov.
In še zmeraj čakamo argumente, zakaj naj se število vrstic kode v prihodnosti ne bi povečalo, čeprav v resnici argumentov od tebe tako ni pričakovati.
a_borlak ::
Za malenkost več dobiš Leafa z 62kWh baterijo, bi pa moral že osnovni zadoščat. Takisto Kona oziroma Ioniq. Skratka, so možnosti.
codeMonkey ::
Seveda ga bomo dokoncali, kjer ga je potrebno dokoncati. Bi ti raje videl, da ga pustimo nedokoncanega kot Boeing ali Tesla?
In ravno ko to napisem, zasledim tole: https://electrek.co/2019/12/30/tesla-dr...
- spremenilo: codeMonkey ()
WarpedGone ::
"moj nedokončan avto" je naredu oko 8300 km brez enega samega problema.
kvalitetna izdelava ?
trololol...
trololol...
Nikec3 ::
codeMonkey je izjavil:
Brez zamere, ampak na vsakem "študentskem podjetniškem seminarju / hackathlonu, pa tudi profesorji na faksih so že tako daleč v razmišljanju..." ti bodo povedali, da če narediš "dokončano kodo", si že zamudil svoj vstop na trg. Nasploh se mora Evropa naučit tega tudi pri strojni opremi in še kje. Ko delaš produkt, je za firmo BOLJE če daš čim hitreje ven izdelek, ki ni popoln in na podlagi feedbacka potem hitro narediš popravke, kot da xy časa tuhtaš in testiraš kaj je narobe in kaj bi lahko šlo narobe, na koncu zamudiš na trg, popolnega izdelka pa itak nisi naredil. Pri prvi opciji imaš takoj revenue in zelo hiter feedback kaj je šlo narobe, pri drugi opciji nimaš hitre povrnitve investicije, nimaš hitrega feedbacka, zgolj teoretično pa imaš boljši produkt.
To je klasičen švabski način "langsam und sicher", ki ga Kitajci (in ZDA očitno tudi) že trgajo na koščke. Mi kot Balkanci smo se marsikaj učili od Nemcev - tudi napačne zadeve, zato bomo morali marsikaj spremenit.
Preden mi začnete, kako je švabski način dela pravilen... trendi kažejo v drugo smer. Inoviranje se v Evropi praktično ne dogaja več, ker smo - preprosto - prepočasni, Kitajske firme pa požirajo Evropske kot po tekočem traku.
jernejl ::
Ja, tako so naredili pri Boeingu in dobili feedback v obliki nekaj sto smrtnih žrtev.
Ne moreš v isti koš zmetati vremenske postaje za dvajset evrov, telefonske aplikacije z govorečo živaljo, paličnega mešalnika, avta in letala.
V nekaterih panogah se lahko greš "dejmo to na trg in poglejmo, kaj se zgodi", v drugih pa so standardi precej strožji.
Zheegec ::
Mazda trdi, da bi njihov MX-30 z baterijo večjo od ~35kWh imel večje total lifetime CO2 emisije, kot Mazda 3 diesel. Se mi zdi kar pravilno. EV avto z ~90kWh baterijo ima lifetime emisije okoli 2x večje, kot Mazda 3 diesel. Kar pomeni, če vse avtomobila povprečnega Evropejca zamenjamo ta trenutek s Tesla Model 3 (54kWh in več), dejansko naredimo korak nazaj kar se tiče lifetime CO2 emisij.
Drugače je v US, Model 3 ima najbrž dosti nižje lifetime CO2 emisije, kot nek pickup in ostali ogromni avtomobili, ki jih tam vozijo.
Janez Janša, 29.04.2014
- spremenil: Zheegec ()
Zdaj moraš samo še najt nekoga, ki ga briga co2, pri vseh drugih strupih, ki prihajajo iz avta.
Kinjorts ::
trololol...
Javi se ko bo imel 456000 km, tako kot moj.
trololol...
ziga1990 ::
^^ je čisto možno, da Tesla naredi toliko kilometrov brez težav, ker pri EV se manj stvari lahko pokvari samo ko se pa kaj pokvari je pa cena popravila lahko kar visoka in ko je avto star je baterija slaba oz ne drži več toliko kot je prej kar pomeni manjši doseg
Tudi proizvodnja elektrike ima emisije, pa kaj? Glavno, da se ne smradi v centru mesta.
codeMonkey ::
Nacelom to drzi, ampak le za dele softverja v avtomobilski industriji. Ko gre za varnostno kriticne sisteme, morajo biti zadeve dokoncane. Produkti gredo nato skozi cerificiranje z vsemi potrebnimi analizami in testi zraven. Za bolj kriticne stvari se opravi se zunanja neodvisna presoja. Vsaka sprememba po tem postopku je draga. Tu ne gre konkretno za Nemce, ceprav so na tem podrocju res vodilni, ampak za mednarodni standard.
ziga1990 ::
nič skrbet ko bo potreba po več elektriki bomo novi TES odprli, ker se finančno najbolj splača plus zeleni nebojo protestirali
Nikec3 ::
Hahahaaha oni so kar battery replacement dali v svoh izračun hahaahaha. Ni šans, da kdaj povoham Mazdo.
