fpbs ::
Nissan sold 50000 Leafs in USA:
http://gas2.org/2014/05/23/nissan-sold-...
WarpedGone ::
Leaf ima 24kWh baterijo, 115k njih skupaj 2760 MWh. Prodaja se od decembra 2010 naprej, že 42. mesec.
"Povprečni" Model S ima ~80kWh baterijo, 40k njih skupaj ~3200 MWh. Prodaja/proizvaja se od junija 2012 naprej, že 23. mesec. Bi reku, da bi Leafove številke morale bit večje, da bi se ga lahko štelo za velik uspeh.
Tesla CTO on Energy Storage: 'We Should All Be Thinking Bigger'
He noted that in the five years between the launch of the Roadster and the Model S, battery performance had improved by 40 percent. He said that battery energy density has doubled over the last ten years and that the curve is not starting to plateau.
Tesla's expected volumes by 2020 "break the model for lithium-ion capacity,
since last year, a 2 megawatt-hour battery pack has been helping to manage loads at the Fremont Tesla factory, managing 10 percent of peak demand ... The installation will be expanded to 4 megawatt-hours in the next three to four months.
there is a 400 kilowatt-hour battery pack at the Tejon Ranch supercharger site in Southern California. The "supercharger is the perfect application for energy storage" with its "incredibly peaky load
Zbogom in hvala za vse ribe
Vprašanje tako mimogrede; navigacija v teh EV upošteva trenutno stanje baterij in morebitne polnilne postaje na poti ter temu prilagodi pot, ali imajo zgolj klasično navigacijo?
WarpedGone ::
Navigacija ni ena, navigacij je mnogo. Različni avtomobili imajo različne.
Od takih, ki sploh ne poznajo polnilnih postaj, do takih ki te v realtime obveščajo o njihovi zasedenosti in hkrati upoštevajo pri predikciji dosega tudi vetrovne in druge cestne razmere.
Če maš 'dovolj' dosega, se s tem bol mal sekiraš.
... vendar ga nimaš, zato se moraš kar malo sekirati:8)
Matev ::
zadosti dosega je za večino ljudi veliko manj kot že sedaj ponujajo e-vozila
bluefish ::
Samo na hitro - Mini Touring Superleggera Vision, konceptni EV: http://www.theverge.com/2014/5/25/57501...
Žal nisem zasledil nič konkretnega o pogonskem sklopu, vendar je oblikovno izjemen avto. Škoda, ker ne bo dočakal vsaj maloserijske proizvodnje.
  • zavarovalo slike: gzibret ()
Matev ::
kabrio-ji so tok fensi šmensi (v slabem pomenu), da jih sploh ne bi smeli uvrščati med avtomobile
TribesMan ::
To je roadster ne cabrio...
WarpedGone ::
"Dovolj" ni črnobel ampak so to odtenki sivine.
Kolk je "črn" dovolj? 2000? 50.000?
WarpedGone ::
Sploh pa je fokus na "maksimalnem" dosegu zgrešena reč. Je cifra kaj je možno ob max planiranju, 'naporu' in ugodnih razmerah.
Čisto nekaj drugega je pa možno "v random" trenutku, ko te zasrbi da bi nekam skoču. S tolk energije kot jo maš trenutno v bateriji, ob takem vremenu kot trenutno je.
Tle pa statistika pravi, da bo baterija polna tolk kot je max tipično polnjenje minus tipična dnevna poraba. Če ma avto tipično 100km dosega, in tipično delaš dnevnih 50km dosega, maš 50km za 'random' skok.
MS60 ma max 320km, ob tipičnem polnjenju na 80% in že opravljenih tipičnih dnevnih 50km, v random trenutku še vedno preostane za 200km energije. Če na poti srečaš SC pa še te omejitve skorajda ni.
MS85 ma max 450km, ob tipičnem polnjenju na 80% in že opravljenih tipičnih dnevnih 50km, v random trenutku še vedno preostane za 300km energije. Če na poti srečaš SC pa še te omejitve skorajda ni.
Zato se še vedno vsi Evji delijo na Teslo in ne-teslo. Ker je v praksi uporabnost kot noč in dan.
J.McLane ::
V naši familiji so 3 avtomobili in vsi trije vidijo 20k km letno, en avto ne vidi AC (brez vinjete) in ima dnevne vožnje v službo 75 km, uporablja se ga tudi ko je kam treba na hitro skočit (beri: manj kot 20 km).
Idealno bi ga bilo zamenjati za EV "mizerijo" :D Leaf za 25k € s subvencijo, strošek prvih 5 let (ocena izgube vrednosti) okrog 4k €/leto po tej dobi bistveno manj, če ne gre kaj k vragu. Sedaj 7 let star Punto s stroškom 3k €/leto in zelo verjetnimi izrednimi okvarami.
Trg meni podobnih vseeno kot kažejo statisitke ni majhen.
TribesMan ::
Punto z vsemi okvarami bo verjetno na long run cenejša izbira kot katerikoli EV...
WarpedGone ::
Katerikoli EV danes in še v naslednjih nekaj letih.
Ampak bencinu cena raste, baterijam pa pada tko da ni nemogoče, da se bo stvar nekoč splačala tudi direkt skozi EUR.
Bencin za 200k km pri 1,5EUR/L in 8L/100km = 24.000 EUR + redni servis (olje+filtri): 100 EUR na 20k km = 1000 EUR, skupaj ~25.000 EUR (raje več, ker gre bencim samo gor in gor).
Pri za puntota realnih 4km/kWh skuriš 50 MWh štroma, ki po današnji tarifi košta okrog 5000 EUR. Bodmo pesimisti in rečmo 10.000 EUR.
Ergo, ko bo EV punto z uporabnim dosegom manj kot 15k EUR dražji od bencinskega puntota, se bo EV lahko že tut direkt splačal.
Tipičen osnovni punto košta ~10k, ergo bi moral EV varianta koštat pod 25k da bi se splačal. Smo še ~10 let oddaljeni od take ekonomije v tem razredu avtomobilov.
J.McLane ::
Kako daleč, če pa dobiš Leafa za 25k €, res da s subvencijo ampak gre tudi za avto C segmenta, ki je večji od Punta. Torej v življenski dobi 10 let ali 200k km je cenovno že danes zelo isto. Pa ne vem če se je že kdo peljal v 7 let starem G Puntu, meni se zdi kot deja vu iz študentskih let z Yugotom, pa ja ni Leaf ista gajbica.
Če greš še v razred nižje recimo VW UP, potem je e-UP s svojimi 21k € (s subvencijo) dokaj drag.
No zdaj edino, če so Avstrijci taki p*** da navajajo cene s kakšnimi svojimi subvencijami...
P.S. Punto nam kuri 6 l/100 km, praktično samo relacija.
TribesMan ::
Mislim da se elektrika draži vsaj tako hitro kot bencin, če ne hitreje...
Sej ko napovejo da se bencin podraži 5 centov se vsi za glavo držijo, ko pa podražijo elektriko za pol centa pa gre lepo "mimo". Ker pol centa pri 10c se sploh ne pozna tolk k 5 centov pri 1.3€, ane :D
Poraba avta ranga clio je nekje 6l... če ga voziš tako kot EV ranga Leaf pa še manj.
Ma še dolgo bo trajalo preden bo cenovno konkurenčno.
J.McLane ::
Ja res je elektrike gre v višave, NOT:
http://www.eex.com/en/market-data/power...!/2014/05/26
http://www.eex.com/en/market-data/power...!/2008/05/26
In od kje ti ideja, da se EV počasi jajcajo po cesti?
Cenovno konkurenčen bo EV ravno toliko kolikor bodo proizvajalci hoteli prodati, zate očitno ne bo to nikoli dovolj dobro, za nekatere je že.
TribesMan ::
Večino jih srečam ko se vozijo 80km/h za tovornjakom... ostali pa kakih 110 na dober dan, razen Teslo sem videl enkrat ko se je peljal podobno kot ostal promet. Ostalo se pa samo jajca.
80 za tovornjakom vozim tudi jaz, pa (še) nimam EV ... Je čist kul feeling da lahko z enim tankom narediš 800km namesto 450, kot bi sicer.
CaqKa ::
https://www.kickstarter.com/projects/16...
skate board na elektromotor.. tisti ki se malo bolj spoznate na elektromotorje, kako je možno da ima zadeva 2kw motor?
glede na doseg in baterijo, ki sta zraven napisana, je tale uporabljen motor bolj v rangu nekaj sto W?
TribesMan ::
Jah, nekaj je peak power nekaj pa trajna moč.
Tole za par sekund navit na 2kW ni nek problem. Da bi pa s tem peljal na polno 10 minut pa seveda ni nikakršne možnosti.
Sicer pa to je nekaj povsem normalnega za "EV".
Števlike za moč ki jih vidite niso "trajna obremenitev", ampak samo dokler pogonski sklop ne doseže neke temperature. Potem se moč zmanjša.
WarpedGone ::
Tle bo glavna razlika med 'športnimi' in 'plebejskimi' EVji. Učinkovito hlajenje elektromotorja ni tako simpl kot hlajenje ICE mašine. Stator že opremiš z tekočinskim hlajenjem, rotor se pa kuha v induciranih tokovih.
TribesMan ::
Hlajenje rotorja pa spet ni tak problem. Definitivno je veliko lažje porihtat hlajenje rotorja, kot pa hlajenje v povprečni ICE mašini. Naredit votlo akso in dodat par semeringov pač ni neka znanost.
Je pa res da za večino povprečnih avtov to sploh ni potrebno, velika večina izgub je tako ali tako v statorju, če je stator "hladen" se preko zraka tudi rotor dobro ohlaja (zračna reža je zelo majhna in prepih je velik zaradi vrtenja).
Obremenitve na polno so v povprečnem avtu kratkotrajne.
WarpedGone ::
Bom postal prepričan, ko bom v praksi vidu 'zadovoljvo' hlajenje.
FormulaE zna bit dober lakmus.
TribesMan ::
Sicer pa od kje ti informacije da je pregrevanje rotorja tak problem? Ker jaz imam ravno kontra informacije.
Bo Formula E sploh imela asinhronce? V F1 uporabljajo motorje s permanentnimi magneti.
Matev ::
jaz pa pozimi srečujem upokojence s suvi in so zelo počasni
WarpedGone ::
Praksa. Vzorec je resda majhen - dve izvedbi roadsterja in tri izvedbe MS - ampak vseh pet po nekaj minutah "cegu na gas" omeji max moč. Če trmariš naprej, se max moč spusti na 140 kW.
90% učinkovit motor se ob 300kW outputa lepo greje s 30 kW. Recimo da je tut baterija "90%" učinkovita i.e. jo greje teh istih 30kW, pa kontroler tut.
Baterija je 'prepredena' s kanali za tekočinsko hlajenje, enako tudi kontroler. Prva vaga svojih 400kg in ima znatno toplotno kapaciteto in tudi 30kW grelec potrebuje precej časa, da ji znatno dvigne temperaturo.
Kontroler je po dimenzijah bol podoben motorju a je ravno tako prepreden s tekočniskim hlajenjem.
Varianta je tudi, da se toploto ne uspe dovolj hitro oddat v zrak a bi se to pokazalo z dvigom temperature hladilne tekočine, pa se ne - ko gre avto v powerlimit, je hladilna še vedno cca enako topla kot prej.
Tudi bi pomagalo "predhlajenje", pa ne. Folk je probu dirkat z mrzlim avtom pa je bil efekt točno enak - power limit čez dva kroga na dirkališču.
Razlaga je, da powerlimit ni rezultat podatkov senzorev ampak direkten softverski poseg - če v določenem časovnem obdobju sprostiš preveč energije, avto omeji moč. Kar kaže na to, da se skuša zavarovat del, kjer ni toplotnih senzorjev. V času, ko je vse ultra pametno, zakaj tega ne kontrolira senzor? Bi stavil da zato, ker se pregreva del, kamor je mal smotano porinit senzor - notranjost rotorja.
Švohnejši EVji niso nobena referenca ker z nižjo max močjo, je tudi nižje max sproščanje toplote, dimenzija motorja (in s tem sposobnost odvajanja toplote) pa približno enaka.
Tudi niso referenca 100kW elektromotorji, ki tehtajo 2 toni. Tle gre za 300kW zadevo velikosti fuzbal žoge.
Zanimiv podatek bi bil kolk dirkaških krogov je sposoben speljat mercedesov AMG SLS. 5 minut al 10 minut?
BMW specify that the i8 is not for track use.
Le zakaj ne?
J.McLane ::
AMG SLS je imel v rokah Clarkson pa ni bilo slišati nekih pritožb. Prav tako so el. motorji uporabljeni pri KERS sistemih kjer morajo biti majhni in lahki in se jih verjetno uporablja na max moči. Sicer imajo vmes malo počitka ampak pri LeMans prototipih je tega počitka verjetno bolj malo
WarpedGone ::
Moč kersa je bila max 60kW, letos dvignjena na 120 kW. Delovanje je precej bol pulzirajoče kot glavni pogonski motor v ModelS s trikrat večjo močjo in podobno velikostjo. poleg tega se tut kersi pregrevajo... Don't use max kers power ...
TribesMan ::
Montirat senzor temperature rotorja pa res ni noben problem.
Če bi bile potrebe po nadzoru temperature rotorja, bi senzor tam bil 100%. Samo mislim da rotor ni problem.
Na rotorju se mogoče sprosti kakih 15% vseh izgub asinhronca, kar je manj kot 5kW (to v primeru da bi gonil 100% ves čas, kar je seveda nemogoče, večina dirkališč ima full throttle kakih 60% časa).
In s tem da se rotor lahko segreje na konkretne temperature, preden pride do težav, max. delovna temperatura enega navadnega "poceni" rotorja je 180°C. Se da pa naredit tud take ki zdržijo preko 200°C.
Če uspeš držat temperaturo statorja z vodo na nizki temperaturi, ne vidim nobenega problema zakaj se rotor nebi mogel hladiti kar preko zraka (znotraj motorja je konkreten prepih). Še toliko manj pa je to problem če rotor hladiš vodno, kot ga Tesla.
Jaz bi stavil da gre za zaščito krmilnika, take časovno pogojene degradacije moči se ponavadi vprogramirajo zaradi zaščite krmilnika. Vsaj mi jih... V krmilniku so hlajena samo IGBT stikala, vse ostalo je prakitčno nemogoče vezat na vodo, in se hladi samo preko konvekcije znotraj krmilnika. Določene zadeve (recimo kondenzatorji) kar gagajo.
Primerjat KERS z motorjem v Tesli nima smisla. KERS tehta nekje 7kg (držiš ga v eni roki brez problema, dimenzije okoli fi100x200mm). Je velik približno toliko kot štarter navadnega avta (mnogo manjši kot Teslin motor). Ima permanentne magnete na rotorju. Je montiran direktno na blok super navitega V6 turbo motorja katerega hladilna tekočina ima 130°C, olje pa še malo več in s tem motornim oljem se "hladi" KERS. Vrti se s konkretnimi obrati (25.000rpm če se ne motim). Different kettle of fish.
J.McLane ::
Toyota TS040 ima dva elektromotorja skupne moči 353 kW. V enem krogu LeMansa po pravilih lahko odda 6 MJ (1,67 kWh) na pogonske motorje, 1,67 kWh pa s 353 kW regeneriraš več kot 20 s (zardi izgub) in potem spet poganjaš motor s polno močjo ca. 17 s. torej je zadeva v pogonu 37 s znotraj 3:25 dolgega kroga, mora pa zdržati 24 ur tekmo. Cel dirkalnik z vso hibridno navlako tehta 850 kg. Če ta hibridni sklop faila, se to na času pozna konkretno in tudi ko se je to zgodilo prvo leto pri TS030 so failale še zavore ker so pod dimenzionirane.
Nissan je tudi močno prisoten v EV dirkanju, v LeMans gredo z ZEOD kot projekt izven kategorije, na vsakih 12-13 krogov bodo odpeljali en krog samo na elektriko, cilje je doseči hitrejši čas od GT klase (manj kot 3:50).
Za rajo se max moč itak rabi samo za prehitevanja, potem je pa hitrost že takoj previsoka. Pa ni ovira samo el. motor ampak tudi baterija, vsi nekaj jokajo ko se omenja hitro polnjenje, čeprav je hitro praznjenje, ki je lahko 3x večje veliko bolj kritičen faktor..
Nikec3 ::
http://www.businessinsider.com/elon-mus...
Elon Musk Is Making The Most Difficult Bet Of His Career
@WarpedOne o Elonu Musku:
bluefish ::
Da ne bomo le o osebnih vozilih. Volvo bo v Gothenburgu testiral polnjenje električnih mestnih busov s pomočjo stare dobre inducije: http://www.engadget.com/2014/05/27/volv...
SmeskoSnezak ::
Koliko resnosti date temu projektu in navedbam? Jaz sem skepticen...
http://solarroadways.com/faq.shtml
@ Pusti soncu v srce... @
c00L3r ::
SmeskoSnezak je izjavil:
Meni se zdi to ena najboljših idej zadnjega časa. Bi pa jih bilo treba probat na nekaj cestah za par let, da vidimo kako se obnesejo v praksi.
Še malo bolj zanimiv video:
Qcube ::
Malo bolj realen pogled na to idejo:
Nikec3 ::
Qcube je izjavil:
Kul video, a bolj nadležnega naglasa še nisem slišal.
WarpedGone ::
WOMBAT - Waste Of Money, Brain And Time. Žal tujega denarja.
Pojavile so se boljše slike notranjosti 85kWh baterije, kar je končno tudi potrdilo število uporabljenih celic: 7104
Battery interior and Repair of Model S
Odprt 85kWh pack, brez dveh modulov:
En modul:
Matematika za 85kWh baterijo gre torej:
- skupno 7104 celic
- razdeljenih v 16 zapredno vezanih modulov
- posamezen modul šteje 444 celic
- v posameznem modulu je 6 zaporedno povezanih skupin 74 paraleno povezanih celic
- skupno gre za 96S74P organizacijo celic
O 60kWh bateriji je znano manj, zgleda pa da je uporabljeno manjše število celic z nižjo kapaciteto.
J.McLane ::
Tisto na koncu je verjetno priključek za hladilno tekočino?
BMS je vezan na posamezen modul (16) ali še na tistih 6 (6 x 16) zaporedno vezanih skupin?
7104 celic povezati ni mačji kašelj, kako bodo te povezave kaj čez 10-15 let, kontakti znajo oksidirati?
60 kWh pack dobiš z manj paralelno vezanimi celicami, namesto 74 pač 52, na tak način praktično vse ostalo ostane enako kot pri 85 kWh modelu.
fpbs ::
J.McLane je izjavil:
Jaz se sprašujem, kakšne bodo te povezave čez 8-10 let.
J.McLane ::
Problemi na kontaktih se lahko pojavljajo pri čisto vseh avtih (12V), pri Priusu sem tudi že bral o kakšnem problemu tam letnika 2001-2002, ni pa to pravilo.
Dejansko IMHO znotraj 10 letnega obdobja ni pričakovati kakšnega problema na tem področju, bi pa vseeno izpostavil dejstvo, da kdor gre v nakup katerokoli EV naj ga kupi zato da se bo vozil in da bo v 10 letih naklepal preko 200k km. Če ga imaš pa zato da si frajer je pa iz energetskega in ekološkega stališča slika bolj boga.
Sem pa malo prebiral http://www.mynissanleaf.com/ in tam našel model staranja Leafove baterije, vsekakor zelo zaskrbljujoči podatki:
http://www.electricvehiclewiki.com/?tit...
Za našo dokaj ugodno klimo je predvidena življenska doba (70% kapacitete) ca. 8,4 let ali 168k km, za moje pojme zelo slabo.
Informacije o novi topoltno odporni bateriji so pa zelo skope in ni čisto jasno ali Nissan noče tega obešati na veliki zvon (zanikanje, da je zdaj kaj narobe) ali pa dejansko niso dosegli nekega velikega napredka. Za MY 2015 je edina vidna razlika nova barva.
TribesMan ::
To je vse točkovno varjeno, tako da sami kontakti niso glih problem, dokler se držijo.
Problem so segrevanja in posledični raztezki, ki uničujejo te spoje.
Sicer temperaturna nihanja tukaj niso tako ekstremna, kot znotraj krmilnika, ampak tam je že kar umetnost naredit spoje, ki ti zdržijo 20.000 in več ciklov ohlajanja in segrevanja (ponavadi dT okoli 60-70°C)...
In ko ti recimo en bond zaradi razlike temperaturnih raztezkov silicija in aluminija poškoduje površino IGBTja naredi samo še POK!
Pri battery packu je to manj problematično, glih razneslo ne bo ničesar, samo s časom izgubljaš na kapaciteti in moči.
J.McLane ::
Dvomim da je posamezna celica varjena v svoje ležišče, kako bi to izvedel ne da bi pretirano segrel celico?
TribesMan ::
Danes so praktično vse baterije v battery packih točkovno varjene. Mislim da tole ni noben problem naredit.
WarpedGone ::
Matrvola, ugibate o stvareh ki so javno znane že vsaj 2 leti.
Posamezna celica je na 'vodilo' privarjena preko relativno tanke žičke, ki hkrati služi kot varovalka.
Tokovi skozi posamezno celico nikoli ne presežejo 5C, oz. ~15A. Povprečni tokovi gredo tja do 2A.
Hudih/hitrih temperaturnih nihanj med običajnim delovanjem tle ni, posledično razteski tle ni problem. Oksidacija pa še manj ker je kontakt privarjen.
TribesMan ::
Aha, izvedbe tega detajla še nisem videl, to sicer ni glih varjeno, ampak ultrazvočno bondirano z aluminijasto žico... kar je ena od metod "hladnega varjenja".
Se pa ne strinjam glede nihanja temperature. Tale žica ima premer v najboljšem primeru 500um, bolj verjetno pa nekje med 300 in 400um (to je standardna dimenzija, več kot 500um pa zaenkrat ne obstaja, razen "ribbon", kar pa tole na sliki ni). In že 10A skozi tako tanko aluminijasto žičko povzroči precej visoka temperaturna nihanja na sami žički. Žička se zelo hitro segreje (par sekund 10A) do nekje 100-150°C.
To povzroča raztezke same žice. Zaradi raztezanja žice, pride na "peti" bonda do zvijanja, kar na dolgi rok (10.000+ ciklov) povzroči da plastične defromacije poškodujejo žico. Tako zgleda poškodba bonda:
heel crack 1
heel crack 2
Druga možnost odpovedi je na spoju samem. Aluminijasta žica se med obdevalo ultrazvočno privari na subrstat (ponavadi z nikljem ali srebrom prevlečen baker, lahko pa tudi aluminij, samo tukaj je zelo težko zagotavljat enakomerno strukturo oksida na substratu in kvaliteta bondiranja zelo niha), ustvari se intermetalni spoj, kvalitetga katerega je zelo odvisna od čistosti, debeline žice, uporabljene sile itd.
Zaradi razlik v temperaturnih raztezkih žice in substrata pride do notranjih sil na spoju, ki s časom spoj odtrgajo s površine substrata (lift off). Take poškodbe zgledajo takole:
cracks
Tukaj res ne rabiš nekih hudih temperaturnih nihanj, že dT 20°C je dovolj da pride do plastične deformacije.
V realnosti to pomeni da praktično vsaka sprememba obremenitve (ko pohodiš ali spustiš pedal za plin) pomeni majhno plastično defromacijo.
Seveda je situacija v samem krmilniku, kjer so IGBTji enako bondirani z aluminijasto žico, veliko slabša, saj tam dT preko 70°C ni nobena redkost. Temperaturna nihanja na površini IGBTja so še toliko večja, zaradi izgub v IGBTju samem.
Ampak tudi v takem battery packu je mehanizem odpovedi popolnoma enak.
WarpedGone ::
J.McLane :: danes, 11:35:22
Da.
BMS nadzoruje skupino 74 vzporednih celic.
Ni mačji kašelj, če to počneš doma z lotkolmom. Ko to dela robot, je zadeva lahko narejena dovolj dobro, da so okvare zaradi variacije v izdelavi dovolj redke. Se pa vseeno dogajajo - simptom je, da ti avto reče da se bo treba zapeljat do servisa. Tam pogledajo in ti zamenjajo baterijo z drugo, vsaj enako ohranjeno baterijo. Ko odpove povezava na neko celico se to pokaže z 1/74 nižjo kapaciteto šestine modula - elektronika to zazna kot 'prehitro' višanje napetosti tega modula med polnjenjem.
To je teoretično možna pot, ki ni bila izbrana.
60kWh baterija ima Vmax 350V, kar je ravno 1/8 manj kot 85kWh baterija. Predvidevamo lahko, da je je napetost posamezne celice enaka pri obeh baterijah, da se lahko uporabi isti BMS. To pomeni da je 60kWh baterija sestavljena iz 14 modulov:
60kWh, 350V
85kWh, 400V
'Manjkata' modula med prednjimi kolesi, ki sta postavljana en na drugega. Če bi teh 14 modulov vsebovalo enako število enakih celic kot 85kWh baterija (3230mAh), bi imelo kapaciteto 74kWh, torej to 'enostavna' varianta odpade. Ostanejo tri manj enostavne:
a) manjše število paralelno povezanih modulov enakih celic kot v večji bateriji - 360 celic povezanih kot 6S60P oz. skupno kot 84S60P. Organizacija 5 x 74 navrže preveč celic - 370 oz. 61,7kWh baterijo
b) enako število paralelno povezanih modulov celic z nižjo kapaciteto. En modul ima 25Vmax in 4285Wh oz. 9,65Wh na celico. To da 2600mAh celice.
c) mešanica variant a in b - manjše število celic z nižjo kapaciteto kot varianta a) in višjo kot varianta b).
Če bi Tesla Motors kupoval 'off the shelf' celice i.e. zadeve, ki jih Panasonic že itak štanca tudi za druge, bi se jim splačalo da kupi čimcenejše zadeve kar običajno pomeni nižjo kapaciteto celice in varianto b ali c.
Ker pa Panasonic itak dobavlja 'optimizirane' celice, kjer je recept teslin, se jim ne splača izdelovat dveh različnih kemij, sploh ker je obseg proizvodnje MS60 relativno majhen (manj kot 10% celotne proizvodnje).
Zato je varno stavit na varianto a in omenjeno 84S60P organizacijo 60kwh baterije.
Ampak dokler nekdo ne odpre 60kWh baterije in prešteje celice, ne vemo 100%.
Se pa iz tega da sklepat naprej: MS60 je 83kg lažji od MS85 in po varianti a vsebuje 5040 oz. 2064 manj enakih celic. To pomeni da ena celica tehta ~41g in vsebuje 297Wh/kg.
85kWh baterija skupno vsebuje 290kg celic in še kakih 150kg 'podpornega' materiala - ohišje, cevi, tekočina, .. oz. skupno ~450kg.
60kWh baterija skupno vsebuje 207kg celic in še teh dodatnih 150k 'podpornega materiala, ker se uporablja enako osnovno ohišje oz. skupno 360kg.
Ampak vse to je akademija, v praksi je pomembno 8 let garancije brez omejitve prevoženih kilometrov in 430 km dosega po EPA standardu. Ter seveda relativno nizka degradacija kapacitete skozi čas.
Nikec3 ::
Če to drži, potem so to super podatki.
To se mi vseeno zdi malo visoko, razen če je Tesla res toliko pred konkurenco. (do sedaj se je omenjalo maksimalno energijsko gostoto celic ~250 Wh/kg, gostoto celotnega battery packa pa 150-180 Wh/kg.
WarpedGone ::
Diagnostika v MS85, zaenkrat dostopna le servisom:
BMS
Temperature in pretoki
fpbs ::
Zopet največ prodanih Leafov:
http://electriccarsreport.com/2014/06/m...
196 / 1414
