fpbs ::
Nissan LEAF Crushes EV Sales Record In The UK:
http://electriccarsreport.com/2014/10/n...
bluefish ::
Mimogrede, glavni PR človek Tesle odhaja k Aston Martinu.
So mu boljši službeni avto obljubili?:)
WarpedGone ::
Bogsigavedi, je pa ta tip precej leteči:
- marec, 2014: Meet Tesla's new VP of communications: Simon Sproule,
- oktober, 2014: Tesla VP Communications Simon Sproule to Leave for Aston Martin
V celi sliki a non-event.
Zbogom in hvala za vse ribe
fpbs ::
Kia Details Its Massive Charging Station Installation Plans For Europe:
http://insideevs.com/kia-details-massiv...
Brane22 ::
DarkSite ::
WarpedGone ::
Linkov je precej, USAToday so članek 'uspeli' objavit prehitro.
Better Acceleration - 3.2 0-60
Better Top Speed - 155 mph
Better Range (275 miles)
P85D - Almost 50% more power
Personal Roller Coaster
Three Settings - Normal, Sport, Insane
Autopilot - Part of all cars off the line the last 2 weeks
Forward Looking Radar
Forward Camera
360 Degree Long Range, Ultrasonic Sonar - Bubble
Self Parking - Even w/o being in it
All digital control system - no latency
Electro-mechanical braking
Electric Power Steering
New Dash Interface - Shows Obstacles
Adjustable Sensitivity to Autopilot
Visual, Audio, Tactile Feedback
Test Rides!
* electromechanical brakes
* full authority electric steering
* all cars produced in last 2 weeks have all the hardware to enable ACC, Lane assist, self-parking, etc.
* car recall (connected to the calendar) and car self-park (both on private property only) and lots of other cool self-driving scenarios to be enabled via updates in the future
M-XXXX ::
Ma zadeva isto konjev ali ne? Sploh nikjer ne najdem podatka...
WarpedGone ::
S60D:
P85D:
Avtopilot:
Tesla Model S P85D AWD and auto-pilot demo
(pod) 3.2 s od 0 do 100 brez trganja sklopke.
  • zavarovalo slike: gzibret ()
TribesMan ::
Heh... tist k veš da bi bila lahko 60D in 85D bolj zmogljiva, pa so namenoma zabremzal zadnji motor... :/
WarpedGone ::
Vse je namenoma in nič ni zabremzano. Lakšna reč je le mal dražja kot kakšna druga.
V vseh Model S je enak motor, razlikujejo se po max moči baterije in sposobnostih inverterja.
S60 in P85 sta omejena z močjo baterije, S85 pa z močjo inverterja. Zato je v P85 "posebna" izvedba inverterja, ki je sposoben pretakat večje tokove.
Tle bo podobna zgodba. V D variantah bo drugačen kontroler ki bo narejen z mislijo na to, da ni edini. RWD variatne pa bodo še vedno imele inverterje, ki so edini in zato pod rahlo drugačnimi tipičnimi obremenitvami.
Musk said in an interview with USA TODAY that his favorite car is the super-fast McLaren, a high-dollar, low-volume production car with racing attributes. Musk thinks the quickest Tesla will match the McLaren's 3.2-second sprint to 60 mph from standstill.
... the all-wheel-drive versions of its Model S electric car will manage a slight increase in range of about 10 miles on a charge vs. the rear-drive models -- for a maximum of 275 miles -- because of efficiencies designed into the new system.
Tesla's suite of safety features and driver aids is partly catch-up, partly leapfrog,.Tesla says the cars it's building now have forward-mounted radar, a camera and 12 sensors each able to "see" 16 feet to enable the safety tech. Those can't be retrofitted to older models, Tesla says.
It also ties the system into the steering, braking and GPS, making it capable of unusual tricks that can't be matched by other cars.
Highlights:
oThe new system will move the car over a lane when the driver uses the turn signal.
oThe car reads speed-limit signs and adjusts the car to the speed on the sign.
oDrivers will be able to get out of the car in their driveways and watch it park itself in the garage. When drivers are ready to leave, the car will able to drive itself up, with the car's temperature and stereo system set to the driver's preferences.
"It will come to you wherever you are," Musk says. "It will slowly make its way to you."
vostok_1 ::
Še baterije, da nekako rešimo in bodo ICE-ji zgodovina. Oz. the horse.
nekikr ::
No ja, 500km je že kar precej dobro za večino...cena je sitnica. Z tak denar dobiš že luksuzni avto, ki je spodobno narejen... :)
J.McLane ::
Sam tale avtomatsko parkiranje brez voznika v avtu ima en major flaw.
Priključek za polnjenje.
WarpedGone ::
:) Indeed.
Zadevo elegantno rešuje brezžično polnjenje.
Vprašanje časa.
Z Branetovega linka:
Musk said that the next thing he wants the car to do is automatically plug itself in, and he announced that, "we will probably do something like that." He made no mention of wireless charging or how much all of this new tech would cost.
Nikec3 ::
Torej, glede na moč P85D to pomeni, da se baterija ob konični moči dejansko prazni z 0,5 MW (sliši se bolj grozljivo), oziroma z 6-7C? Kakšna debata o vplivih na baterijo, ali je čas pri katerem avtomobil deluje s takšno močjo tako minimalen, da ni omembe vredno?
Še video:
@WarpedOne o Elonu Musku:
  • spremenil: Nikec3 ()
7982884e ::
dej za navadne smrtnike tole še enkrat napiši ker mi ni čist jasno
Oldi ::
500kW moči in tok praznjenja, ki je 6-7 x večji od amperskih ur oziroma je baterija pri takem toku prazna v 9 minutah oziroma ker ji pri takem toku kapaciteta gotovo pade, še veliko prej.
V modelarskih razmerah je 7C zelo nežna uporaba baterije :)
Še pred štirimi leti sem redno gonil baterije na 60C, res da le za max 15s. Prva opazna posledica je bilo povečanje notranje upornosti in iz tega sledeča nezmožnost dajati od sebe take tokove, kar se je zgodilo nekje po 100 štartih, kolikor sem jih približno naredil v eni sezoni.
Oldi ::
To so specialne NiCd oziroma NiMH baterije, če prav vem.
tudi li-poly baterije maš take, ki so sposobne dat veliko več toka od sebe..
TribesMan ::
Different kettle of fish...
Te baterije ki so v Tesli niso niti približno sposobne dat od sebe 60C.
Sej dobro vemo da gre zadeva v omejevanje moči že približno po minuti tiščanja z enim motorjem... z dvema bo kvečjemu še malo slabše.
Nasploh so te specfikacije moči pri EVjih zelo "vprašljive", saj so vsi elementi močno poddimenzionirani.
Brane22 ::
MIslim da je cel point P85D da ti da _možnost_ pritisniti na pedal ob pričakovanju, da normalen smrtnik tega ne bo počel 1x v minuti, kar je nekako pričakovano glede na ciljno publiko.
Saj stvar že glede na maso baterije ni mišljena za konkurenco tahudim supercarom na dirkalni stezi. Je bolj normalen avto, ki ga lahko pritisneš na trenutke, da ti sapo vzame.
Kar so IMHO dosegli 100%.
Domnevam, da so del enačbe tudi nove ali optimizirane celice in da se bo naslednji korak v to smer zgodil, ko bo stekla masovna lastna proizvodnja.
Poleg tega bi se avto moral daleč lepše obnašati v ovinkih in na težavnih terenih, tudi če ne presežeš prejšnje moči normalne verzije, kar bo glavni point, ki ga pričakujem od testerjev reviewov, ki pridejo.
Nikec3 ::
+ potrebno se je zavedati, da pride v 2015 masovna proizvodnja Model X, ki je grajen na enaki platformi kot Model S, bil je pa že od prej načrt, da bo imel X 2 motorja. Podvozje bo praktično enako.
bluefish ::
No, Pečjak se je pricjazil z Bleda do Dubrovnika: http://www.siol.net/avtomoto/novice/201...
nekikr ::
Ja, ravno berem kako "revolucionarno" je to. 66km/h povprečna hitrost na precej dobri in prazni cesti...
A se spet trudimo bit slovenci ... Sonarodnjak postavi svetovni rekord v tržno obetavnem segmentu, mi pa "ah kaj pa je to tazga" ... Kdo tu mu / jim je sposoben čestitat? Če privzemam, da nimate soldov, da bi jih vložili vanje ...
thramos ::
Dobr no, kok pa je drugače povprečna hitrost na cesti, kjer je najvišja omejitev 90, po poti pa cel kup vasi in mest, kjer je omejitev nižja? Jaz za svoja potovanja po regionalkah vedno računam 60 km/h.
nekikr ::
Eh, se posipam s pepelom, enostavno sem prebral avtocesta. Bedak. 66km/h je potem poštena hitrost.
  • spremenil: nekikr ()
TribesMan ::
Razlogi za uspeh:
- IPM motor, ki ima pri taki umirjeni vožnji zelo dobre izkoristke
- uporaba menjalnika, ki omogoča poganjanje IPM motorja v optimalnih obratih in še dodatno izboljšanje izkoristka (110Wh/km je zelo dobra številka)
- dobre relativno lahke in drage baterije ter veliko njih namontiranih v prtljažnik
- polnjenje/praznenje baterij do limita
- neupoštevanje marsikaterih varnostnih standardov (ta avto za moje pojme ni za na cesto)
Samo po drugi strani, če se Tesla odloči, pa zmeče v prtljažnik še mal baterij, in odstrani zaščite ki preprečujejo polnjenje praznenje baterij v "nevarna" območja, mal optimizirajo izgube (manj potratna kolesa) tole komot izenačijo/presežejo. Ampak se jim verjetno ne da s tem ukvarjat, majo verjetno kak bolj resno delo.
PR zna pa dobro zganjat, to pa ni vprašanje...
BigWhale ::
Meni se kljub vsemu zdi tole kar lep dosezek.
Brane22 ::
Ne štekam od česa živijo tipi a'la Pečjak in podobni.
Komu se dejansjko splača predelat avto na elektriko na ta način na nekih tržnih osnovah ?
TribesMan ::
Če dobiš podarjen pogonski sklop, pa baterije z dobrim popustom, in si na ta račun narediš nekaj dobre reklame za svojo firmo ki predeluje avte na elektriko... se verjetno pokrije na dolgi rok.
vostok_1 ::
Sicer karkoli je fanj, ampak ta dosežek je bl tko...meglen. Če je že motor dober naj ga temu primerno reklamirajo. Rečt, da ele avto zmore 700km+ je podobno, kot da avijon lahko preleti 30000km v enem šusu. (potnike zamenjaš za rezervoarje kerozina in letiš 150km/h v smeri zračnih tokov). Napram čemu ga naj primerjamo za božjo voljo?
  • spremenil: vostok_1 ()
Oldi ::
Kot je bilo rečeno, Pečjak dela avte za rekorde, drugi imajo pametnejše delo. S tem se je sam hvalil.
WarpedGone ::
In other news... iz poročila DEVS:
PS: Za pot na sestanek v Portorož sem iz Celja do Portoroža potreboval 12 ur. Še enkrat torej opozarjamo upravljavce in seveda tudi ponudnike električnih vozil, da je za normalno uporabo električnih vozil srednjega razreda nujna postavitev hitre DC polnilne infrastrukture.
Nekater si nabavjo mizerijo (Leaf, i3), pol pa stokajo.
Ni problem manjko polnilne infrastrukture ampak doseg 50km na lep sončen dan z vetrom v hrbet. Kar je tip vedu, ko je mizerijo plačal. Sedaj pa se cmeri ...
Spajky ::
Uf, bo treba v električne avte montirat kak DIY "free Energy device", da bo sproti polnil >:D .. pa ne bo več težav z dosegom :) ...
WarpedGone ::
povsem zadostuje že dovolj velika baterija, nekje nad 50kWh. ampak večini to ne potegne.
J.McLane ::
Pretiravat pa ni treba, če ima Leaf 50km dosega na lep sončen dan potem ga ima Tesla S85 v enakih pogjih samo 170 km.
Baterije so take kot so samo zaradi ekonomske računice EV proti klasičnim vozilom. Tesla je pa v segmentu kjer gre ekonomska računica pri klasiči konkurenci v višave, torej si tako ceno lahko privoščijo.
WarpedGone ::
Sej, in taka za lase privlečena računica ti na koncu rezultira v:
Če je neki predrago za nek segment trga, se ga tja pač ne tlači silo.
12 ur za celje - portorož ni niti mizerja ampak absurd. In za to ni kriv koncept EV ampak mojstri, ki tako mizerijo prodajajo kot tipičen EV.
Ob tem da bi dvakrat večja baterija koštala dodatnih 7 jurjev in teh 12 ur zreducirala na normalen čas.
bluefish ::
Tega EV-ja itak ne kupis za vozikanje na morje.
  • spremenil: bluefish ()
TribesMan ::
Plačat 100 jurjev, zato da se boš lahko v enem šusu pripeljal iz Celja v Protorož, je pa tudi absurd svoje vrste...
driver_x ::
TribesMan je izjavil:
Za v Portorož boz vzel rentacar.
Brane22 ::
Tesla je trailblazer.
Avto za €100k za zelo majhen del trga, ki pa jim bo omogočil izdelavo zelo spodobnega avta za manj ko pol tega denarja v prihodnosti, ko naredijo stopnico ali dve s celicami.
Glede na zadnje vzpodbudne novice naj to ne bi bilo predaleč v prihodnosti.
WarpedGone ::
Absurd je plačat 35 jurjev in se nato "furat" 12 ur.
M-XXXX ::
Realnost je taka, da je absurd OBOJE.
Oldi ::
WarpedGone je izjavil:
Torej baterija za 100km doseg stane 14kEUR in če po čudežu traja 10 let in mesečno z bencinarjem kuriš 117EUR bencina, bodo vsi stroški polnjenja šli preko bencinarske ekonomike.
Skratka kot trdim že od vsega začetka, vožnja na zastonj elektriko je dražja kot na bencin, ob polnem obratovanju TEŠ6 bo pa verjetno tudi ekološko spornejše, pa je tu še plin. Skratka malo morgen in EV.
  • spremenil: Oldi ()
Baterija za 14 jurjev te bo pripeljala precej dlje, kot 100 km.
215 / 1430
