Pomoč pri matični Asus P5B konfiguracija RAID-a
Mirč ::
Kolega je kupil asusovo P5B matično,katera podipra raid.Ampak problem nastane kako priti do nastavitve raida.Ima 4 diske na enem je sistem na enem podatki,2 diska pa čist nova na novo sformatirana in ta nova diska bi naredila RAID.
Matična ima 4 sata priključke in 1 en posebaj sata priključek za raid jmicron JMB363 seial ATA RAID connector.
Če ta priključek vežema na en sata disk pol pridemo po komb.tipk ctrl+J v raid bios ampak tu najde samo 1 disk in ne moremo nič pametnega naret.
Kako naprej?
Kaki je postopek da naredima raid 0 če je kdo delal na tej plati naj prosim razloži
Mirč ::
opisano
JMB361/3/5/6 all support Cross RAID Function between SATA II and PATA channels. In order to setup a workable RAID system, you must complete the following install steps.
(1) Install SATA/IDE HDD in your PC system
(2) Setup JMB36X Operating Mode and Boot Priority in Main BIOS Menu
(3) Enter JMB36X RAID BIOS to setup your RAID configuration
(4) Create a Floppy Disk with JMB36X Driver for Windows OS installation
(5) JMB36X Driver Installed when Windows OS Installation
Based on the following install steps, you must prepare the following equipments.
(1) More than two HDD (To get the best system performance, suggest you to prepare HDD with the same Model Name and Capacity as possible. You can connect only one SATA/IDE HDD when you don��t want to setup a RAID system.)
(2) A white Floppy Disk when MB vendor does not provide it.
(3) Microsoft Window OS Install CD (Windows 2000/XP/2003)
(4) MB Driver CD
mlav ::
Zanimam se za nakup plošče P5B in postavitve sistema z raid Mirror (mislim da je to 1) zaradi varovanja podatkov. Ali je možno?
WIN7 ne prepozna SATA diska
Oddelek: Operacijski sistemi
173365 (2901) Andy21
WD my book zmrzne na e-sata
202678 (2296) MrStein
Zunanji eSata preneha delovati?
232856 (2522) thebaloh
Ni zvoka Asus P5K
81366 (1194) MIREL
Jmicron in s.m.a.r.t.
51390 (1317) Icematxyz
