Forum » Omrežja in internet » Samba server @ linux z več user accounti & WinXP
HriBB ::
[global]
workgroup = workgroup
server string = hribb
hosts allow = 192.168.0.1
log file = /var/log/samba/log.%m
security = user
socket options = TCP_NODELAY
interfaces = lo eth0
os level = 65
preferred master = yes
unix extensions = no
guest account = nobody
[hribb]
comment = hribb.homelinux.com
path = /home/hribb
valid users = hribb
browseable = yes
writeable = yes
printable = no
guest ok = no
[bojan]
comment = bojan.homelinux.com
path = /home/bojan
valid users = bojan
browseable = yes
writeable = yes
printable = no
guest ok = no
______________________________________________
takole zgleda smb.conf na gentoo serverju. s smbpasswd sem ustvaril vse userje in dokler sem uporabljal linux sem ob bootu mountal remote folderje na local folderje v /etc/fstab. vse je blo kul dokler nisem obupal nad linuxom kot workstationom, zradiral particije in gor fliknu xpje. ko sm hotu povezat več network folderjev ... enega se da, več pa ne ...
"Multiple connections to a server or shared resource by the same user, using more than one username, are not allowed. Disconnect all previous connections to the server or shared resource and try again."
torej ... windows user lahko naenkrat z enim user:pass-om dostopa samo do enega shara. če hoče dostopati do drugega, more prvega diskonektati in šele nato lahko dostopa do drugega. a je to bug ali je feature? :D
lahko bi dal recimo dostop root userju do celega /home direktorija ampak potem bom zjebal vse ownershipe datotek. tko da potrebujem več samba accountov. ali obstaja način da se hkrati povežem iz xpjev na več samba accountov? po možnosti čim manj zapleten :D
hvala za odgovore in lep pozdrav
security = user
os level = 65
[hribb]
path = /home/hribb
valid users = hribb
browseable = yes
writeable = yes
printable = no
guest ok = no
[bojan]
path = /home/bojan
valid users = bojan
browseable = yes
writeable = yes
printable = no
guest ok = no
jaja
kekz ::
Mislim, da je fičer pri vindows, da do istega strežnika ne more dostopati z več uporabniškimi imeni naenkrat. (nisem čisto prepričan, ker winsi niso moja specialnost).
Mogoče bi nahecal sambo, da se predstavlja z več aliasi (s strani winsov bo vidno več strežnikov) in priključil vsak disk s svojega?
kekz ::
Morda je možnost tudi, da dostopaš kar z istim userjem.
Na direktorijih pa postaviš sgid (ne vem, ali dela tudi suid) bit v zaščiti, potem bodo vsi novi fajli, ki bodo nastali, dobili group lastništvo (pri suid morda tudi ownerja) od direktorija in ne od uporabnika.
- spremenilo: kekz ()
HriBB ::
uspelo mi je ...
chmod ug+s /pot/do/direktorija
in v smb.conf v [share] sekcijo ...
inherit owner = yes
inherit owner = yes
jaja
- spremenil: HriBB ()
| » | SambaOddelek: Programska oprema | 4799 (4091) | kiFni |
| » | Samba guiOddelek: Omrežja in internet | 2048 (1763) | Bug |
| » | Samba pomočOddelek: Operacijski sistemi | 1709 (1547) | borchi |
| » | Vaša smb.conf datoteka-nasvet?Oddelek: Operacijski sistemi | 1874 (1770) | Gh0st |
| » | LINUX+WIN2000Oddelek: Pomoč in nasveti | 2417 (1982) | tec |
