Napaka pri zagonu...
Ozric ::
Ob zagonu XP-jev se prikažeta dve napaki - "Can't open kernel driver asLM75.sys" in "Can't load AsmiHwIo.dll".Menda gre za bug na Asusovih mat.ploščah? Any idea,kako to odpravit? Thanx..
  • spremenil: Ozric ()
Izi ::
Če bi malo pogooglal tudi nebi škodilo.
Here is the best possible fix to the boot-up error: can't open kernal driver aslm75.sys and can't load asmiHWIO.dll
It is caused by the bios of ASUS motherboards in its attempt to autoexecute ASUS Probe upon bootup. Note that this has nothing to do with the normal functioning of ASUS Probe--only the startup auto execution mode.
The solution:
Open up ASUS Probe
Click on SETTINGS
Uncheck the box at the lower left corner that says "Auto-Execute ASUS Probe on startup."
Exit ASUS Probe.
Restart your computer and the error messages will not occur.
Ozric ::
Thanx....;)
Asus RT-N16 DD-WRT print server
Oddelek: Omrežja in internet
61638 (1528) errhec
Ubuntu 9.04->10.04 = Mail ne dela več
Oddelek: Operacijski sistemi
61381 (1298) Icematxyz
[Debian] Po dveh dneh uporabe sem ga sesul :S
102445 (2192) Ice-Heki
connecting own dialling router to siol adsl
92764 (2660) enis
FreeBSD - nekaj newbie vprašanj
111600 (1462) ghaefb
