[php] branje vsebin in prikaz
NeOman ::
ubistvu imam problem z branjem vsebin na neki strani, zanima me kako bi lahko npr. iz tecajne liste prebral podatke ki jih stran prikaze in jih uporabil na neki svoji strani? ima kdo izkusnej s tem, kaksen namig bi bil dobrodosel.
Kami ::
Uporabiš file_get_contents da prebereš stran pol pa s pomočjo regular expressions pobereš ven tiste podatke ko rabiš.
NeOman ::
ok, hvala.
sicer dobim: Warning: file_get_contents(): URL file-access is disabled in the server configuration, mi je pa princip vsec. preden grem config spreminjat bi uprasu, ce obstajajo kaksne alternative za file_get_contents in ali se odprejo kaksne luknje na strezniku ce omogocim URL file-access?
r5r ::
Rešitev: http://si2.php.net/manual/en/function.fsockopen.php
Grem poiskat, če imam kaj uporabnejšega na disku.
And it makes me wonder.
r5r ::
<?php
error_reporting(0);
$r = new HTTPRequest('http://example.com/file.txt');
$out = $r->DownloadToString();
if ($out!=='1') {echo $out;}
else {echo 'Connection error!';}
class HTTPRequest
   var $_fp;         // HTTP socket
   var $_url;        // full URL
   var $_host;        // HTTP host
   var $_protocol;        // protocol (HTTP/HTTPS)
   var $_uri;                // request URI
   var $_port;        // port
   function _scan_url()
       $req = $this->_url;
       $pos = strpos($req, '://');
       $this->_protocol = strtolower(substr($req, 0, $pos));
       $req = substr($req, $pos+3);
       $pos = strpos($req, '/');
       if($pos === false)
           $pos = strlen($req);
       $host = substr($req, 0, $pos);
       if(strpos($host, ':') !== false)
           list($this->_host, $this->_port) = explode(':', $host);
       else
           $this->_host = $host;
           $this->_port = ($this->_protocol == 'https') ? 443 : 80;
       $this->_uri = substr($req, $pos);
       if($this->_uri == '')
           $this->_uri = '/';
   // constructor
   function HTTPRequest($url)
       $this->_url = $url;
       $this->_scan_url();
   // download URL to string
   function DownloadToString()
       $crlf = "\r\n";
       // generate request
       $req = 'GET ' . $this->_uri . ' HTTP/1.0' . $crlf
           .    'Host: ' . $this->_host . $crlf
           .    $crlf;
       // fetch
       if ($this->_fp = fsockopen(($this->_protocol == 'https' ? 'ssl://' : '') . $this->_host, $this->_port)) {
       fwrite($this->_fp, $req);
       while(is_resource($this->_fp) && $this->_fp && !feof($this->_fp))
           $response .= fread($this->_fp, 1024);
       fclose($this->_fp);
       // split header and body
       $pos = strpos($response, $crlf . $crlf);
       if($pos === false)
           return($response);
       $header = substr($response, 0, $pos);
       $body = substr($response, $pos + 2 * strlen($crlf));
       // parse headers
       $headers = array();
       $lines = explode($crlf, $header);
       foreach($lines as $line)
           if(($pos = strpos($line, ':')) !== false)
               $headers[strtolower(trim(substr($line, 0, $pos)))] = trim(substr($line, $pos+1));
       // redirection?
       if(isset($headers['location']))
           $http = new HTTPRequest($headers['location']);
           return($http->DownloadToString($http));
       else
           return($body);
        }else { return ('1'); }
NeOman ::
kul jaka, hvala. ti positnarim se kej preko IMinga ;)
php send data to private dir
Oddelek: Programiranje
51188 (927) Excavator
PHP - Prenos priponk iz RSS vira
5902 (825) keworkian
PHP & XAMPP file_get_contents
Oddelek: Izdelava spletišč
151667 (1447) KoMar-
[php] Kako odstraniti dolocen text
51474 (1415) rokpok
Kako z VS.NET priti do izvorne kode neke html strani?
91701 (1496) Microsoft
