Forum » Programiranje » [php] branje vsebin in prikaz
NeOman ::
ubistvu imam problem z branjem vsebin na neki strani, zanima me kako bi lahko npr. iz tecajne liste prebral podatke ki jih stran prikaze in jih uporabil na neki svoji strani? ima kdo izkusnej s tem, kaksen namig bi bil dobrodosel.
Kami ::
Uporabiš file_get_contents da prebereš stran pol pa s pomočjo regular expressions pobereš ven tiste podatke ko rabiš.
NeOman ::
ok, hvala.
sicer dobim: Warning: file_get_contents(): URL file-access is disabled in the server configuration, mi je pa princip vsec. preden grem config spreminjat bi uprasu, ce obstajajo kaksne alternative za file_get_contents in ali se odprejo kaksne luknje na strezniku ce omogocim URL file-access?
r5r ::
Rešitev: http://si2.php.net/manual/en/function.fsockopen.php
Grem poiskat, če imam kaj uporabnejšega na disku.
And it makes me wonder.
r5r ::
<?php
error_reporting(0);
$r = new HTTPRequest('http://example.com/file.txt');
$out = $r->DownloadToString();
if ($out!=='1') {echo $out;}
else {echo 'Connection error!';}
class HTTPRequest
var $_fp; // HTTP socket
var $_url; // full URL
var $_host; // HTTP host
var $_protocol; // protocol (HTTP/HTTPS)
var $_uri; // request URI
var $_port; // port
function _scan_url()
$req = $this->_url;
$pos = strpos($req, '://');
$this->_protocol = strtolower(substr($req, 0, $pos));
$req = substr($req, $pos+3);
$pos = strpos($req, '/');
if($pos === false)
$pos = strlen($req);
$host = substr($req, 0, $pos);
if(strpos($host, ':') !== false)
list($this->_host, $this->_port) = explode(':', $host);
else
$this->_host = $host;
$this->_port = ($this->_protocol == 'https') ? 443 : 80;
$this->_uri = substr($req, $pos);
if($this->_uri == '')
$this->_uri = '/';
// constructor
function HTTPRequest($url)
$this->_url = $url;
$this->_scan_url();
// download URL to string
function DownloadToString()
$crlf = "\r\n";
// generate request
$req = 'GET ' . $this->_uri . ' HTTP/1.0' . $crlf
. 'Host: ' . $this->_host . $crlf
. $crlf;
// fetch
if ($this->_fp = fsockopen(($this->_protocol == 'https' ? 'ssl://' : '') . $this->_host, $this->_port)) {
fwrite($this->_fp, $req);
while(is_resource($this->_fp) && $this->_fp && !feof($this->_fp))
$response .= fread($this->_fp, 1024);
fclose($this->_fp);
// split header and body
$pos = strpos($response, $crlf . $crlf);
if($pos === false)
return($response);
$header = substr($response, 0, $pos);
$body = substr($response, $pos + 2 * strlen($crlf));
// parse headers
$headers = array();
$lines = explode($crlf, $header);
foreach($lines as $line)
if(($pos = strpos($line, ':')) !== false)
$headers[strtolower(trim(substr($line, 0, $pos)))] = trim(substr($line, $pos+1));
// redirection?
if(isset($headers['location']))
$http = new HTTPRequest($headers['location']);
return($http->DownloadToString($http));
else
return($body);
}else { return ('1'); }
?> And it makes me wonder.
| » | php send data to private dirOddelek: Programiranje | 1188 (927) | Excavator |
| » | PHP - Prenos priponk iz RSS viraOddelek: Programiranje | 901 (824) | keworkian |
| » | PHP & XAMPP file_get_contentsOddelek: Izdelava spletišč | 1667 (1447) | KoMar- |
| » | [php] Kako odstraniti dolocen textOddelek: Izdelava spletišč | 1474 (1415) | rokpok |
| » | Kako z VS.NET priti do izvorne kode neke html strani?Oddelek: Programiranje | 1701 (1496) | Microsoft |
