Forum » Programska oprema » Problem z MSNjem
Problem z MSNjem
pepelopez ::
Ko ga poizkusam zagnati mi javi to napako.
"This application has failed to start because CRYPNET.dll was not found. Re-insalling the application may fix this problem."
Sem ga poizkusal intalirat se enkrat, vendar ne pomaga. Uporabljam pa zadnjo verzijo WML. Do sedaj pa mi je delal brezhibno.
A bi znal kdo pomagat??
Hvala
Hvala
- premaknil iz Pomoč in nasveti: ToniT ()
| » | VirusOddelek: Pomoč in nasveti | 3818 (3743) | koyotee |
| » | google analyticsOddelek: Slo-Tech | 3611 (3081) | roli |
| » | DOS!Oddelek: Igre | 1493 (1219) | misterno |
| » | HTTP serv. programOddelek: Omrežja in internet | 2376 (2213) | pivmik |
| » | Kako zagnati program v želeni prioriteti?Oddelek: Operacijski sistemi | 2271 (2130) | tha_man |
