Forum » Strojna oprema » Pomagajte mi pripravit skener Mustek SE 6000P do delovanja
Evil Penguin ::
Dobil sem zgoraj omenjeni skener. Uporablja LPP port. Sem ga priklopil in vse.
Snel sem tele driverje (med drugimi) http://members.driverguide.com/driver/d...
Navodila so taka:
reštartam, windowsi še vedno nimajo pojma, da je priklopljen. V twain 32 se naloži tole:
Če zaženem otemnjen program, se odpre tisto ko je za skeniranje (knofi za scan itd.) ampak ko pritisnem se nič ne zgodi. To je imo bolj ali manj logično, glede na to, da ti dllji ne gredo nikamor v windowse, zato ga windows tudi ne spozna.
Navodila so taka:
In this zip-file you can find three files:
- instructions.txt (which you are reading now!)
- se6000p_2k.exe (this is the Windows 2000 driver for Mustek ScanExpress 6000 P)
- fixwinxp.exe (the tool that lets Win 2000 drivers work on Win XP machines)
You need to unzip these files to a temporary location on your harddrive (e.g. "C:\temp scanner\")
Than open fixwinxp.exe, choose your language, click OK and browse to the file se6000p_2k.exe
which you've extracted a few minuts ago.
Click OK, if you receive a System Error click continue or cancel DO NOT click abort or something.
Click continue to start the installtion. When the installation is finished click OK.
Restart your computer and everything should work.
Good Luck!!!
When the Win XP tool (fixwinxp.exe) doesn't seem to work you can try the method described
beneath. This solution is given by Mustek and you can also find it on their website.
Use this one if the above mentioned method didn't work and you know how to handle with editing
the Windows registry.
You can try following solution if the XP-Tool is not working:
1. Start Regedit
2. In HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\Current Version
rename the key "ProduktName"
from "Microsoft Windows XP"
into "Microsoft Windows 2000"
3. install the Mustekdriver for Windows 2000
4. Undo the changes in the Registry.
| » | Windows 7 Installer (64-bit) - težaveOddelek: Programska oprema | 3707 (3097) | fr!Xy |
| » | Msn TEŽAVA...!!! čudna zadevaa...Oddelek: Pomoč in nasveti | 2254 (1879) | d3n!5 |
| » | Ne predvaja novega audio CDOddelek: Pomoč in nasveti | 2607 (2563) | Tea Time |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2527 (2493) | Mercier |
| » | Iščem alternativo vudujuOddelek: Kaj kupiti | 2442 (2206) | Arthur |
