Lsass.exe - normalno ali virus?
Storm ::
Sem pogooglal kaj tale lsass.exe je in mi da dva odgovora.
Description:
lsass.exe is a system process of the Microsoft Windows security mechanisms. It specifically deals with local security and login policies. This program is important for the stable and secure running of your computer and should not be terminated.
Note: lsass.exe could also be a process which is registered as a trojan. This Trojan allows attackers to access your computer from remote locations, stealing passwords, Internet banking and personal data. It could also be a registered security risk and should be removed immediately.
Zdej pa mi na podlagi tega, da je NetLimiter zaznal, da mi sprejema kilobajte (cca 4,5kB na dan) oddaja jih pa ne, povejta a je virus al ni? Kateri protivirusni program trenutno najbolj priporočate?
Markec The Great
boss-tech ::
bitdefender ali nod32. seveda pa ne pozabi na anti trojanske programe(ter programe za čiščenje ostale zalege): ewido, spybot
Cofko Cof ::
Bodi pozoren na to ali je lsass.exe ali je isass.exe, ker če pišeš L z malo i pa z veliko zgledata isto(l I). In isass.exe je virus.
Ars longa,vita brevis.
boss-tech ::
probaj če ti bo hijackthis kej našu
racunalnik se mi izklaplja :( na pomoc, prosim
121466 (1225) jesen
Isass.exe
Oddelek: Programska oprema
136622 (2484) cucolino
lsass.exe - error
Oddelek: Operacijski sistemi
211782 (1631) seatleon
Zakaj sistemska exe datoteka vsakih 5min zasede 80% CPU-ja??
111817 (1621) muzičar
lsass.exe in panda platinum internet security 2005 problem
62278 (2212) OtonVM
