problem pri uploadanju avdio fajla- PHP
AglioAlio ::
Lep pozdrav!
Imam sledeč problem.
V Phpju sem naredil stran, kjer lahko uploadam slike in glazbo (mp3, wav). Ko odprem sliko mi zaigra glasba. Problem je v tem da ne morem uploadat mp3-jev večjig kot 1MB,čeprav je maksimalna velikost fajla 10MB. S slikami pa ni težav (ista koda)
prilaagm kodo:
form enctype="multipart/form-data" action="uploader.php" method="POST"
input type="hidden" name="MAX_FILE_SIZE" value="10000000"
div align="right">Choose a file to upload:
input name="uploadedPhoto" type="file" style="slide"
input type="hidden" name="M_F_S" value="10000000" align="right">Select audio file:
nput name="uploadedAudio" type="file" style="slide"
input name="submit" type="submit" value="Upload File"
pa se PHP koda:
$target_pathP = "uploads/";
$target_pathA = "uploads/";
//Add the original filename to our target path. Result is "uploads/filename.extension"
$target_pathP = $target_pathP . basename( $_FILES['uploadedPhoto']['name']);
$target_pathA = $target_pathA . basename( $_FILES['uploadedAudio']['name']);
if(move_uploaded_file($_FILES['uploadedPhoto']['tmp_name'], $target_pathP)){
if(move_uploaded_file($_FILES['uploadedAudio']['tmp_name'], $target_pathA)) {
$query= "INSERT INTO tablephoto VALUES ('','$target_pathP','$target_pathA ','$description','$ime')";
echo "The file ". basename( $_FILES['uploadedPhoto']['name']). " has been uploaded";
mysql_query($query);
else{
echo"There was an error uploading the audio file, please try again!";
} else{
echo "There was an error uploading the photo file, please try again!";
dolegar ::
Po čem sklepaš, da je max velikost 10MB po MAX_FILE_SIZE?
Naredi enp phpinfo datoteko in jo naloži na server potem pa poglej
- post_max_size
- upload_max_filesize
oz. ,da ti pri večjih datotekah ne "timeout-a" skripta (30 sekund) razen, či nisi časa že povečal.
[JS / PHP] miniajax post
Oddelek: Programiranje
131354 (1088) cobrica
Pomoč pri nalaganju večih slik naenkrat
Oddelek: Izdelava spletišč
61167 (1017) winlins
php $_FILE in pravice
51053 (980) psychoP
[php] unlink - problemček
152040 (1586) PaX_MaN
Unattended install for Windows - beginner
Oddelek: Operacijski sistemi
61621 (1574) TitanSLO
