Forum » Operacijski sistemi » dodajanje diskov v suse 10.1 linuxu?
ekseR ::
Mam dva diska za windows in jih hočem imet na namizju suse linuxa. Kva morm nardit da bom lohk dostopov do teh dveh diskov prek susa?
i7 920 d0@4,2GHz | Gigabyte EX58-UD3R | Mushkin <m HP 1600MHz 6GB |
Sapphire HD5850@994/1275 | Corsair TX650W | Samsung spinpoint F3 1TB |
Hitachi T7K250 160GB | GMC J-1 | 3D Mark Vantage P20311 3DMarks
ekseR ::
sedaj mij ratal dodat diska, samo en mi ne do vol dostopa in ko kliknem na disk mii napiše permission denied. Kva nj nardim da bom mu dostop do tegaa diska?
Iz "man mount", odsek za ntfs
uid=value, gid=value and umask=value
Set the file permission on the filesystem. The umask value is given in octal. By default, the files are owned by root and not readable by somebody else.
torej v /etc/fstab za te particije napisi (poleg defaults) se uid=tvoj uid,gid=tvoj gid
Recimo takole:
/dev/sda1 /windows/C ntfs defaults,uid=1000,gid=100 0 0
Svoj uid in gid dobis z ukazom "id".
Recimo takole:
ekseR ::
Ja sm probov na rootu pa mi tud noče odpret.
jype a lohk bolj podrobno razložiš ker ne obladam tolk linuxa da bi znal kej tazga štimat.
Kot root pozenes editor (ce uporabljas KDE lahko to naredis tako, da pritisnes alt-F2, reces options, obkljukas "run as a different user" in vpises root in geslo za root.
Potem v polje "command" vpises recimo "kate /etc/fstab" in popravis datoteko tako, da bo vsebovala tiste opcije, ki sem ti jih napisal.
Potem odpres Konsole in vpises
su -
vtipkas root geslo
umount /windows/C
umount /windows/D
mount -a
exit
exit
In je.
su -
vtipkas root geslo
umount /windows/C
umount /windows/D
mount -a
exit
exit
In je.
ekseR ::
tux@suse:~> su -
Password:
suse:~ # ummount /windows/C
-bash: ummount: command not found
suse:~ # umount /windows/C
suse:~ # umount /windows/D
umount: /windows/D: not found
suse:~ # mount -a
suse:~ #
tole mi vrže. V windowsh mi D: dela bp
Password:
suse:~ # mount -a
suse:~ #
Brane2 ::
Za to, da vidiš disk v neki mapi, mora ta mapa obstajati in disk mora biti zmountan vanjo.
najprej poglej, če mapa /windows/D sploh obstaja in jo po potrebi naredi ter ji daj ustrezna dovoljenja.
Nato pa probaj zmountat še disk vanjo.
Poglej prej za kateri disk gre.
Če je tvoj disk "D:" v bistvu recimo enota /dev/sdb1, potem ročno zmountaš zadevo tako:
mount -t ntfs /dev/sdb1 /windows/D -o rw
Če ti to dela, prepišeš to linijo v /etc/fstab, vendar brez vodilnega "mount" in z ustrezno razporejenimi polji, ki gredo tam v drugem vrstnem redu ter brez "-o"- opcije so v enem stolpcu in tam se ta "-o" razume sam po sebi.
Nato unmountaš zadevo z umount /windows/D in pogledaš, če jo znastvar sama zmountat; mount -a -t ntfs
BTW- writeable dostop na NTFS zna biti baje nevaren. Sam še nisem imel težav, je pa res, da sam nisem izzival nesreče. Če sem kdaj kaj pisal na NTFS, je šlo za file ali dva. Nisem premetal kvadrilijona fileov po miljonu map naenkrat...
ekseR ::
Brane2 kako pa to v /etc/fstab dadaš? A lohk bolj podrobno opišeš? Ker uporablam linux šele 1 tedn, tko da nč ne znam.
Brane2 ::
Nekje v terminalu vpiši "man fstab" in preberi navodila.
Prej si lahko pogledaš sam fajl s kakim "less /etc/fstab", toliko da boš lažje bral navodila...
ekseR ::
Zdj sm uštimu. Sam sm kopiru tisto vrstico od C:, pa spremenu oznako diska v hdb1 in zj lepo dostopam. Sam noče mi predvajat nobenga filma in vrže error kot da plugin manjka. A morm mar kodeke naložit?
- spremenil: ekseR ()
ekseR ::
Če seše kermu lub pomagat nj mi pove kako bi lohk predvajal filme, k mi vrže en errork kao manjka plugin.
| » | ntfs mount suse 10.2Oddelek: Operacijski sistemi | 1651 (1528) | karafeka |
| » | SUSE vprasanjaOddelek: Operacijski sistemi | 1391 (1347) | sid_dabster |
| » | Ubuntu in win particijeOddelek: Operacijski sistemi | 1474 (1330) | ZGI |
| » | zunanji USB disk na SuseOddelek: Operacijski sistemi | 1713 (1586) | kriko1 |
| » | Suse to the data rescueOddelek: Operacijski sistemi | 1558 (1463) | Jst |
