Forum » Programiranje » [ C ] floating point not loaded !!?
Fizikalko ::
Torej, ko izvajam C program (kompajliran z Borland VC 6.0) , mi vrže:
6002 error: floating point not loaded
Želim brat iz ebega fajla in pisat v bazo. Koda je 100% ok. Menda je treba neko opcijo dodat pri kompajliranju, da dodaš podporo za FP...
Prosim pomoč, čim prej...
Hvala že vnaprej.
Hvala že vnaprej.
Zvedavec ::
Zdi se mi, da je včasih pomagalo že, če si naredil v kodi eno spremenljivko tipa float in ji priredil eno vrednost (recimo 1.1) v kodi, da je prevajalnik opazil, da boš potreboval podporo za FP.
Fizikalko ::
sem dodal v main:
float slo=sqrt(5);
Program se SESUJE! WTF?
Access violation.
float slo=sqrt(5);
Access violation.
- spremenilo: Fizikalko ()
Fizikalko ::
Ne štekam. Kje zdej pride koda - v oglatih oklepajih al kaj= Probal vse živo, pa noče vzet. Call me stupid, ampak, kako si to mislil
"st.kodac"??? Kaj je st? Res ne razumem...
Fizikalko ::
static char sqla_program_id[162] =
42,0,65,68,65,75,65,73,82,69,83,84,65,82,84,32,119,65,66,83,
86,88,68,87,48,49,49,49,49,32,50,32,8,0,71,82,69,71,65,32,
32,32,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0
#include "sqladef.h"
static struct sqla_runtime_info sqla_rtinfo =
{{'S','Q','L','A','R','T','I','N'}, sizeof(wchar_t), 0, {' ',' ',' ',' '}};
static const short sqlIsLiteral = SQL_IS_LITERAL;
static const short sqlIsInputHvar = SQL_IS_INPUT_HVAR;
#line 1 "restart.sqc"
/* Restart Program */
/* THIS BATCH PROGRAM READS IN EMPLOYEE DATA CONCERNING THEIR TAX */
/* CLASS WITH MONTHLY AND YEARLY TAX EXEMPTIONS AND INSERTS THE */
/* DETAILS ON TO A DB2 TABLE. EVERY 20 INSERTS ARE COMMITTED AND */
/* CHECKPOINTED BY PUTTING THE DETAILS ON TO A RESTART TABLE. */
/* PGM FLOW */
/* ! READ RESTART-TABLE (SQL) ! */
/* ! IS THERE A ROW IN THE RESTART TABLE? ! */
/* ! YES ! NO !NEITHER! */
/* ! **** 1)(RESTART_ROUTINE)! NORMAL_ROUTINE !4) ! */
/* ! **** 2)(NORMAL_ROUTINE) ! */
/* ! DELETE THE ROW IN THE RESTART TABLE (SQL) ! */
/* ! DELETE OK ! */
/* ! YES ! NO ! */
/* ! END OF PGM ! 4) ! */
/* 1) SUBROUTINE RESTART_ROUTINE *********************************** */
/* ! ! READ Input-FILE ! */
/* ! ! EOF Input-FILE? ! */
/* ! ! NO ! YES ! */
/* ! ! ! ERROR ROUTINE ! */
/* ! ! ! ABNORMAL PROGRAM END ! */
/* ! DO UNTIL (EOF OR THE DATA FROM THE RESTART TABLE ! */
/* ! = THE DATA FROM THE Input-FILE) ! */
/* ! END OF ROUTINE ! */
/* 2) SUBROUTINE NORMAL_ROUTINE ************************************ */
/* ! READ Input-FILE (FIRST RECORD IF NORMAL OR ! */
/* ! NEXT RECORD IF A RESTART) ! */
/* ! DO WHILE (Input-FILE NOT EOF) ! */
/* ! ! UPDATE EMPLOYEE TABLE (SQL) ! */
/* ! ! EMPLOYEE FOUND? ! */
/* ! ! YES ! NO !NEITHER! */
/* ! ! % ! ERROR MESSAGE ! 4) ! */
/* ! ! IS NUMBER OF RECORDS READ > CHECKPOINT LIMIT? ! */
/* ! ! YES ! NO ! */
/* ! ! **** 3) (CHECKPOINT_ROUTINE) ! % ! */
/* ! ! READ NEXT RECORD FROM Input-FILE ! */
/* ! ! INCREMENT NUMBER OF RECORDS READ ! */
/* 3) SUBROUTINE CHECKPOINT_ROUTINE ******************************* */
/* ! FILL UP RESTART STRUCTURE WITH DETAILS OF THE RECORD ! */
/* ! INSERT/UPDATE TO RESTART TABLE (SQL) ! */
/* ! INSERT/UPDATE OK ! */
/* ! YES ! NO ! */
/* ! DB2 COMMIT ! ! */
/* ! COMMIT OK ! 4) ! */
/* ! YES ! NO ! ! */
/* ! END OF ROUTINE ! 4) ! ! */
/* 4) CALL SUBROUTINE DBERRORP ************************************* */
/* ! ERRORTEXT = ?????????? ERROR MESSAGE ! */
/* ! CALL DBERRORP ERROR-ROUTINE ! */
/* ! CALL PLIRETC(12) SHOW RETURN-CODE ! */
/* ! RETURN ABNORMAL PROGRAM END ! */
/* TABELLEN / VIEWS THAT ARE USED */
/* TABLE / MEMBER NAME STRUCTURE NAME FIELD NAMES */
/* VIEW */
/* VRESTART MRESTART SRESTART PGMID */
/* TIMESTAMP */
/* RTEXT */
/* VPERS01 MPERS01 SPERS01 EMPNO */
/* TAXCLASS */
/* TAXFREEM */
/* TAXFREEY */
/* *** PSEUDOCODE *** */
/* READ RESTART TABLE (SQL) */
/* SELECT */
/* IF THERE IS A ROW IN THE RESTART TABLE */
/* REPEAT UNTIL (END OF FILE (Input)) OR */
/* (DATA FROM Input FILE = DATA FROM RESTART TABLE) */
/* READ Input FILE */
/* IF END OF FILE (Input) */
/* ERROR ROUTINE */
/* END PGM ABNORMALLY */
/* CALL RESTART_ROUTINE */
/* IF THERE IS NO ROW IN THE RESTART TABLE */
/* CALL NORMAL_ROUTINE */
/* OTHERWISE CALL DBERRORP */
/* READ Input-FILE */
/* REPEAT UNTIL (END OF FILE (Input)) */
/* UPDATE VPERS01 TABLE (SQL) */
/* SELECT */
/* IF NO ROWS FOUND IN VPERS01 TABLE */
/* PUT OUT MESSAGE */
/* IF ROW(S) FOUND IN VPERS01 TABLE */
/* NO ACTION */
/* IF Input_COUNTER > CHECKPOINT-LIMIT */
/* INSERT/UPDATE ROW IN RESTART TABLE (SQL) */
/* IF INSERT/UPDATE NOT OK */
/* CALL DBERRORP */
/* CALL CHECKPOINT_ROUTINE */
/* DELETE ROW IN RESTART TABLE (SQL) */
/* IF DELETE NOT OK */
/* CALL DBERRORP */
/* END OF PGM */
/* Include C library definitions */
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
/* Input/Output files */
/* cardin = input request records */
/* report = output phone report printed to terminal */
FILE *cardin;
FILE *report;
/* Input transaction request from text file MUPDATE */
/* DESCRIPTION OF DATA ELEMENTS */
/* TYPE TYPE 'MUPDATE' */
/* in_empno PERSONNEL NUMBER (EMPNO) */
/* in_taxclass TAX CLASS (TAX CLASS) */
/* in_taxfreem MONTHLY TAX EXEMPTION (TAXFREEM) */
/* in_taxfreey YEARLY TAX EXEMPTION (TAXFREEY) */
/* REST FILLER TO MAKE IT 80 BYTES */
EXEC SQL BEGIN DECLARE SECTION;
#line 183 "restart.sqc"
char type[7];
char in_empno[10];
char in_taxclass[3];
char in_taxfreem[8];
char in_taxfreey[8];
char rest[48];
EXEC SQL END DECLARE SECTION;
#line 191 "restart.sqc"
short restart_switch;
short Input_counter;
short inpz;
char restext[81];
short x;
float slo;
static char fmt1[] = "%7c%9c%2c%7c%7c%49c";
static char fmt2[] = "%-4s%-26s%-80s%\n";
static char msg01[] =
"CHECKPOINT : PGMID = ";
static char msg02[] =
" TIMESTAMP = ";
static char msg03[] =
" RTEXT = ";
static char msg04[] =
"MSG04I - ROLLING BACK, RETURN CODE IS:";
static char msg05[] =
"MSG05I - EITHER INPUT OR OUTPUT FILE CANNOT BE OPENED";
static char msg06[] =
"MSG06I - ROLLBACK FAILED, RETURN CODE IS:";
static char msg07[] =
"MSG07I - NORMAL START";
static char msg08[] =
"MSG08I - NEGATIVE RETURN CODE FROM SQLAINTP ";
static char msg09[] =
"MSG09I - ERROR DELETING FROM VRESTART";
static char msg10[] =
"MSG10I - RESTARTING";
static char msg11[] =
"MSG11I - ERROR RESTARTING";
static char msg12[] =
"MSG12I - PERS NUM NOT FOUND FOR UPDATE";
static char msg13[] =
"MSG13I - ERROR FORCED - RESTART....";
static char msg14[] =
"MSG14I - COMMIT SUCCESSFUL";
static char msg15[] =
"MSG15I - END OF PROGRAM";
/******************Function prototypes*********************************/
void restart_routine(void);
void normal_routine(void);
void checkpoint_routine(void);
void sql_err(void);
/* Include for SQLCA. */
EXEC SQL INCLUDE SQLCA;
/* SQL Communication Area - SQLCA - structures and constants */
#include "sqlca.h"
struct sqlca sqlca;
#line 250 "restart.sqc"
#line 251 "restart.sqc"
/* Variables that map to the VPERS01 and RESTART tables are declared */
/* below. Note the definitions. */
/* Variables for VPERS01 table */
char empno[9];
char taxclass[2];
float taxfreem; /*TAXFREEM DECIMAL(7, 2),*/
float taxfreey; /*TAXFREEY DECIMAL(7, 2) */
/* Variables for RESTART table */
char pgmid[4];
char timestamp[26];
char rtext[81];
/* Indicator Variables */
short pgmt_i;
short pgyr_i;
/* Variables for connect statement */
char userid[9];
char password[9];
char database[9];
#line 284 "restart.sqc"
/*****************Error handling***************************************/
/* SQL errors transfer control to DBERROR routine. */
/* SQL warnings continue. */
/**** SQL error handling ****/
/**** SQL warning handling ****/
EXEC SQL WHENEVER SQLWARNING CONTINUE;
#line 296 "restart.sqc"
EXEC SQL WHENEVER SQLERROR GO TO DBERROR;
#line 297 "restart.sqc"
EXEC SQL WHENEVER NOT FOUND CONTINUE;
#line 298 "restart.sqc"
/* Main routine */
/* Read one record at a time from the input file. */
int main()
report = sqrt(5);
/* Open the input and output files */
cardin = fopen("MUPDATE", "r");
report = fopen("REPORT", "w");
if (cardin == NULL || report == NULL) {
fprintf(report, "%s\n", msg05);
exit(0);
/* Connect to database */
/**** SQL Connect to database ****/
/* Set up host variables for */
/* userid, password, and database */
strcpy(userid,"grega");
strcpy(password,"password");
strcpy(database,"EDDB");
/* Code the connect statement */
/* using the host variables */
EXEC SQL CONNECT TO :database;
#line 339 "restart.sqc"
sqlastrt(sqla_program_id, &sqla_rtinfo, &sqlca);
sqlaaloc(2,1,1,0L);
struct sqla_setdata_list sql_setdlist[1];
sql_setdlist[0].sqltype = 460; sql_setdlist[0].sqllen = 9;
sql_setdlist[0].sqldata = (void*)database;
sql_setdlist[0].sqlind = 0L;
sqlasetdata(2,0,1,sql_setdlist,0L,0L);
sqlacall((unsigned short)29,4,2,0,0L);
if (sqlca.sqlcode < 0)
sqlastop(0L);
goto DBERROR;
sqlastop(0L);
/* USER :userid USING :password;*/
/* UPDATE VPERS01 DATA */
restart_switch = 0;
x = 0;
/* SET UP WHERE STATEMENT FOR RESTART TABLE */
/* READ RESTART TABLE - DETERMINE IF THERE ARE ANY ROWS */
/* FOR THE pgmid. */
strcpy(pgmid,"TP01");
EXEC SQL
SELECT *
INTO :pgmid, :timestamp, :rtext
FROM VRESTART
WHERE PGMID = :pgmid;
#line 358 "restart.sqc"
sqlaaloc(2,1,2,0L);
sql_setdlist[0].sqltype = 460; sql_setdlist[0].sqllen = 4;
sql_setdlist[0].sqldata = (void*)pgmid;
sqlaaloc(3,3,3,0L);
struct sqla_setdata_list sql_setdlist[3];
sql_setdlist[1].sqltype = 460; sql_setdlist[1].sqllen = 26;
sql_setdlist[1].sqldata = (void*)timestamp;
sql_setdlist[1].sqlind = 0L;
sql_setdlist[2].sqltype = 460; sql_setdlist[2].sqllen = 81;
sql_setdlist[2].sqldata = (void*)rtext;
sql_setdlist[2].sqlind = 0L;
sqlasetdata(3,0,3,sql_setdlist,0L,0L);
sqlacall((unsigned short)24,1,2,3,0L);
sqlastop(0L);
goto DBERROR;
sqlastop(0L);
/* IF THERE IS A ROW IN RESTART */
/* DO THE RESTART PROCESSING */
if (sqlca.sqlcode == 0)
restart_routine();
/* If no row in restart table */
if (sqlca.sqlcode == 100)
fprintf(report, "%s\n\n", msg07);
/* IF NO ROW IN RESTART */
/* DO NORMAL PROCESSING */
/* NORMAL PROCESSING VIA SUBROUTINE */
normal_routine();
/* DELETE ROW FROM RESTART TABLE AND CHECK FOR ERRORS */
EXEC SQL
DELETE FROM VRESTART
#line 386 "restart.sqc"
sqlaaloc(2,1,4,0L);
sqlacall((unsigned short)24,2,2,0,0L);
sqlastop(0L);
goto DBERROR;
sqlastop(0L);
fprintf(report, "%s\n\n", msg09);
/* END OF PROCESSING */
pgmend();
DBERROR: sql_err();
return(0);
} /* end main */
/* END OF PROGRAM */
/*XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX*/
/* SUBROUTINE RESTART_ROUTINE */
void restart_routine()
/* READ Input FILE UNTIL */
/* DATA FROM Input-FILE = DATA FROM RESTART TABLE */
fscanf(cardin, fmt1, type,
in_empno,
in_taxclass,
in_taxfreem,
in_taxfreey,
rest);
strcpy(restext,"");
strcat(restext,type);
strcat(restext,in_empno);
strcat(restext,in_taxclass);
strcat(restext,in_taxfreem);
strcat(restext,in_taxfreey);
strcat(restext,rest);
while (!feof(cardin))
if (!strcmp(rtext,restext))
/* RESTART PROCESSING - MESSAGE */
fprintf(report, "%s\n\n", msg10);
fprintf(report, fmt2, pgmid,
timestamp,
rtext);
restart_switch = 1;
return;
else
in_empno,
in_taxclass,
in_taxfreem,
in_taxfreey,
rest);
strcpy(restext,"");
} /* end while */
fprintf(report, "%s\n\n", msg11);
/* SET RESTART SWITCH TO '1' (-> UPDATE IN RESTART-TABLE) */
restart_switch = 1;
return;
} /* END RESTART_ROUTINE */
/* SUBROUTINE NORMAL_ROUTINE */
void normal_routine()
/* READ Input-FILE (FIRST ROW IF NORMAL OR NEXT */
/* ROW IF RESTART) */
/* INCREMENT Input_counter (COUNTER) BY 1 */
in_empno,
in_taxclass,
in_taxfreem,
in_taxfreey,
rest);
Input_counter = 1;
/* READ Input-FILE WHILE (Input-FILE NOT EOF) */
/* ASSIGN DATA FROM THE Input-FILE INTO THE SQL HOST VARIABLES */
sscanf(in_taxfreem," %f ",&taxfreem);
sscanf(in_taxfreey," %f ",&taxfreey);
if (!(strcmp(in_taxfreem,"")))
pgmt_i = -1;
else
pgmt_i = 0;
if (!(strcmp(in_taxfreey,"")))
pgyr_i = -1;
else
pgyr_i =0;
/* UPDATE VPERS01 TABLE */
/* WITH NEW TAX CLASS, NEW TAX FREE MONTHLY VALUE, and */
/* NEW TAX FREE YEARLY VALUE. */
EXEC SQL
UPDATE VPERS01
SET TAXCLASS = :in_taxclass,
TAXFREEM = :taxfreem :pgmt_i,
TAXFREEY = :taxfreey :pgyr_i
WHERE EMPNO = :in_empno;
#line 529 "restart.sqc"
sqlaaloc(2,4,5,0L);
struct sqla_setdata_list sql_setdlist[4];
sql_setdlist[0].sqltype = 460; sql_setdlist[0].sqllen = 3;
sql_setdlist[0].sqldata = (void*)in_taxclass;
sql_setdlist[1].sqltype = 481; sql_setdlist[1].sqllen = 4;
sql_setdlist[1].sqldata = (void*)&taxfreem;
sql_setdlist[1].sqlind = (short*)&pgmt_i;
sql_setdlist[2].sqltype = 481; sql_setdlist[2].sqllen = 4;
sql_setdlist[2].sqldata = (void*)&taxfreey;
sql_setdlist[2].sqlind = (short*)&pgyr_i;
sql_setdlist[3].sqltype = 460; sql_setdlist[3].sqllen = 10;
sql_setdlist[3].sqldata = (void*)in_empno;
sql_setdlist[3].sqlind = 0L;
sqlasetdata(2,0,4,sql_setdlist,0L,0L);
sqlacall((unsigned short)24,3,2,0,0L);
sqlastop(0L);
goto DBERROR;
sqlastop(0L);
/* IF ROW FOUND */
/* NO ACTION */
/* IF ROW NOT FOUND */
/* SAY SO IN A MESSAGE */
fprintf(report, "%s\n\n", msg12);
/* OTHERWISE CALL ERROR ROUTINE */
/*%%%%%%%%%%%%%%%%%%%% USED FOR TESTING RESTARTABILITY %%%%%%%%%%%%%%*/
inpz++;
if (inpz > 50)
fprintf(report, "%s\n\n", msg13);
exit(12);
/* PERFORM CHECKPOINT AFTER 20 ROWS VIA SUBROUTINE */
if (Input_counter > 19)
checkpoint_routine();
/* READ NEXT ROW FROM Input-FILE */
/* INCREMENT Input_counter BY 1 */
in_empno,
in_taxclass,
in_taxfreem,
in_taxfreey,
rest);
Input_counter++;
} /* END WHILE */
return;
DBERROR: sql_err();
} /* END NORMAL_ROUTINE; */
/* SUBROUTINE CHECKPOINT_ROUTINE */
void checkpoint_routine()
/* INITIALIZE Input_counter TO 0 */
/* PUT RESTART INFO INTO RTEXT */
Input_counter = 0;
strcpy(rtext,"");
strcat(rtext,type);
strcat(rtext,in_empno);
strcat(rtext,in_taxclass);
strcat(rtext,in_taxfreem);
strcat(rtext,in_taxfreey);
strcat(rtext,rest);
EXEC SQL
VALUES (CURRENT TIMESTAMP)
INTO :timestamp;
#line 608 "restart.sqc"
sqlaaloc(3,1,6,0L);
sql_setdlist[0].sqltype = 460; sql_setdlist[0].sqllen = 26;
sql_setdlist[0].sqldata = (void*)timestamp;
sqlasetdata(3,0,1,sql_setdlist,0L,0L);
sqlacall((unsigned short)24,4,0,3,0L);
sqlastop(0L);
goto DBERROR;
sqlastop(0L);
/* IF THERE WE HAVE ALREADY PUT A ROW INTO THE RESTART TABLE, */
/* UPDATE RESTART TABLE WITH THE MOST RECENT INFO */
if (restart_switch != 0)
EXEC SQL
UPDATE VRESTART
SET TIMESTAMP = :timestamp,
RTEXT = :rtext
#line 621 "restart.sqc"
sqlaaloc(2,3,7,0L);
sql_setdlist[1].sqltype = 460; sql_setdlist[1].sqllen = 81;
sql_setdlist[1].sqldata = (void*)rtext;
sql_setdlist[2].sqltype = 460; sql_setdlist[2].sqllen = 4;
sql_setdlist[2].sqldata = (void*)pgmid;
sqlasetdata(2,0,3,sql_setdlist,0L,0L);
sqlacall((unsigned short)24,5,2,0,0L);
sqlastop(0L);
goto DBERROR;
sqlastop(0L);
/* IF NO ROWS IN RESTART TABLE */
/* SET RESTART_SWITCH TO '1'. */
/* INSERT INFO INTO RESTART TABLE */
else
restart_switch = 1;
EXEC SQL
INSERT INTO VRESTART
VALUES (:pgmid, :timestamp, :rtext);
#line 634 "restart.sqc"
sqlaaloc(2,3,8,0L);
sqlacall((unsigned short)24,6,2,0,0L);
sqlastop(0L);
goto DBERROR;
sqlastop(0L);
/* DB2 COMMIT WITH CHECKING */
EXEC SQL COMMIT;
#line 640 "restart.sqc"
sqlacall((unsigned short)21,0,0,0,0L);
sqlastop(0L);
goto DBERROR;
sqlastop(0L);
fprintf(report, "%s\n\n", msg14);
/* MESSAGE FROM CHECKPOINT PROCESSING */
fprintf(report, "%s %s\n", msg01, pgmid);
fprintf(report, "%s %s\n", msg02, timestamp);
fprintf(report, "%s %s\n\n", msg03, rtext);
return;
DBERROR: sql_err();
} /* end of CHECKPOINT_ROUTINE; */
/* SQL error handler */
void sql_err() {
#include <sqlenv.h>
#define DATA_LEN 80
char error_message_buffer[512];
short buffer_size = sizeof(error_message_buffer);
short int rc;
int i;
fprintf(report, "%s %i\n", msg04, sqlca.sqlcode);
/* Format the sqlca */
rc = sqlaintp(error_message_buffer, buffer_size, DATA_LEN, &sqlca);
if (rc == 0)
fprintf(report, "%s %hi\n", msg08, rc);
else
/* fprintf(report, error_message_buffer); */ /* Print formatted */
fprintf(report, "%s\n", error_message_buffer);
/* Attempt to rollback any work already done */
EXEC SQL WHENEVER SQLERROR CONTINUE;
#line 685 "restart.sqc"
#line 686 "restart.sqc"
#line 687 "restart.sqc"
x = 1;
pgmend();
return;
} /* end of sql_err */
pgmend()
if (x == 1)
EXEC SQL ROLLBACK;
#line 698 "restart.sqc"
sqlacall((unsigned short)28,0,0,0,0L);
sqlastop(0L);
if (sqlca.sqlcode != 0) /* If rollback fails */
fprintf(report, "%s %i\n", msg06, sqlca.sqlcode); /* display error msg */
else
EXEC SQL COMMIT;
#line 704 "restart.sqc"
sqlastop(0L);
fprintf(report, "%s\n", msg15);
fclose(cardin);
fclose(report);
exit(0);
return(0);
Fizikalko ::
Mislim, da zajebava pri delu s fajlom. Mislim, da moram pri kompajliranju dodat kakšen support za float ali kaj takega.
Tole je moja complink procedura:
cl -Ox -W2 -TC -D_X86_=1 -I"C:\SQLLIB\include" %1.c /link -out:%1.exe "C:\SQLLIB\lib\db2api.lib"
| » | Postavitev mySQLOddelek: Programiranje | 2883 (2461) | M01O |
| » | Linux CentOS - block ip rangeOddelek: Omrežja in internet | 903 (791) | Bakunin |
| » | SQL težavaOddelek: Programiranje | 7036 (6318) | joseti |
| » | Hard disk popravilo / rešitev podatkovOddelek: Strojna oprema | 2146 (2047) | darkolord |
| » | sql-t stored procedureOddelek: Programiranje | 1388 (1255) | detroit |
