Wireless in Linux
Wireless in Linux
Racko ::
Prej sem imel na softverski router na Linuxu in sicer na distribuciji Debian. Sedaj sem kupil se wireless mrezno kartico in zelim deliti internet preko te mrezne kartice. Tezava se pojavi ze takoj, ker mi kartice ne prepozna.
Citat lspci:
0000:01:00.0 Ethernet controller: Marvell Technology Group Ltd.: Unknown device 1faa (rev 03)
shock ::
Najboljše je če bi povedal kateri wireless kartico imaš. Najbolj ti priporočam da ugotoviš kateri chip ima tvoja kartica in poiščeš na netu drajverje za ta čip.
Racko ::
Imam mrv8000c. Driverje sem installiral preko ndiswrapper a kartica se vedno noce delat.
eth0 no wireless extensions.
lo no wireless extensions.
eth1 no wireless extensions.
sit0 no wireless extensions.
ppp0 no wireless extensions.
shock ::
A si poskusil to kar kaže na tej strani?
Racko ::
OK, prisel sem do naslednjega koraka. Mrezno kartico mi lepo prepozna, ampak se moj laptop in mrezna iz streznika ne najdeta. Niti po dhcp niti po static.
wlan0 Link encap:Ethernet HWaddr 00:40:F4:E4:ED:80
inet addr:192.168.0.9 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::240:f4ff:fee4:ed80/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interrupt:9 Memory:dc010000-dc020000
Listening on LPF/wlan0/00:40:f4:e4:ed:80
Sending on LPF/wlan0/00:40:f4:e4:ed:80
Sending on Socket/fallback/fallback-net
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 4
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 17
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 10
No DHCPOFFERS received.
No working leases in persistent database.
Any idea?
shock ::
A ti misališ biti kot access point ali client?
Racko ::
Kot access point. Sedaj mi kartico prepozna, se poveze nanjo a interneta se vedno noce deliti preko wlan0 :(
  • spremenilo: Racko ()
shock ::
z ndiswrapperjem ti ne bo uspelo, ker ne podpira AP konfiguracijo. Poglej če ta kartica ima kmake druge driverje, ki podpira AP
Racko ::
Nobenih takih driverjev ne najdem. A se res ne bi dalo nekako drugace access pointa postimat?
shock ::
Malo pogooglaj kateri chipset ima tvoja kartica in po tem chipsetu išči driverje za linux.
Racko ::
Marvell čip je. Povsod je omenjen samo ndiswrapper. Kaj pa ce bi kupil router? bi ga lahko priklopil na Linux in potem oddajal WLAN?
CCfly ::
Da.
"My goodness, we forgot generics!" -- Danny Kalev
shock ::
Kupiš en poceni AP s podporo 802.1x za avtentikacijo, pa ti vse skupaj špila stabilno in varno. Seveda moraš v linuxu si dat freeradius da ti deluje kot avtentikator. Če hočeš delat pod linuxom vse sam moraš biti mazohist >:D, ali če imaš res grozno željo po znanjiu in veselju naredit kaj sam.
dnsmasq problem
Oddelek: Omrežja in internet
122722 (2462) poweroff
Ubuntu 10.10 SIOL IPTV in nastavitev dveh kartici
104819 (4693) prastroj
[Ubuntu server 8.04] - povezava se prekine
Oddelek: Operacijski sistemi
81907 (1811) BaRtMaN
Ubuntu in nedelujoč net
82313 (2129) Pyr0Beast
Ubuntu 7.10 (strani: 1 2 3 )
1167209 (6635) stalker
