problem z 64bit driverji
perobiker ::
Inštaliral sem 64 bit XP-je in naletel na težave z driverji.
OK vse sem najdel razen driverjev za printer (Samsung ML-1520) in TV kartico (Leadtek TV2000 XP ekspert).
Za printer win najdejo driverje sam nastane problem, ko bi jih mogel namestit.
"Napiše da jih blokira NT4.0"
Zanima me, če se da to kako nardit da jih nebi blokiral, saj so driverji tapravi?
Ka pa če mam pod VMWARE inštalirane 32 bit win pol bom pa lahko namesto 32bite driverje al ne?
Kak pa nej drgač printam?
Thanks
Izi ::
Some people report a problem when istalling the drivers. If they are not installed properly and you get the message:
"The current printer driver is not compatible with a policy enabled on your computer that blocks Windows NT 4.0 or Windows 2000 kernel-mode drivers."
you can try to install your printer as a different model. In the following list the printer which showed this problem is on the left and the working driver is on the right:
CLP-510 -> CLP-500
ML-2010 -> ML-2150
ML-1740 -> ML-1710
SCX-4100 -> any of those: SCX-4214F, SCX-4x16, SCX-4x21
Nekaj so zasrali z temi driverji.
Torej jaz bi na tvojem mestu probal driverje od modela ML-1510, mogoče bodo delali.
64-bitne dirverje za Leadtek TV2000 XP EXPERT pa imaš tukaj:
http://tw1965.myweb.hinet.net/x64.htm
Driver je pa tole:
http://tw1965.myweb.hinet.net/5.0.18.64...
perobiker ::
Thanks
Ko bom sprobal bom javil, zdej nisem za svojem PC.
perobiker ::
vse dela tak ko si napisal
Nujno rabim pomoč!
101229 (1163) SanAndreas
Katero TV kartico kupiti? (strani: 1 2 )
5015191 (13000) edublin
61813 (1637) MEDENA
Piskanje kompa in ta se ne prizge!
171918 (1771) Morph3us
Tiskalnik ali vecfunkcijska naprava za 30-50k
92179 (2048) MEDENA
