Forum » Hlajenje in modifikacije » Dolžina IDE in napajalnih kablov
smilyxx ::
Torej Zanima me če je kakšna omejitev pri dolžini IDE in napajalnih kablov? Sam bi rabil razdaljo kakih 4ih metrov. Hvala.
Save water.
drink beer.
drink beer.
5er--> ::
Dan's Data
The maximum cable length you're meant to use for any ATA interface - any kind of modern "IDE" drive - is 457mm, according to the official specification. That's 18 inches.
This length limit applies to 40 and 80-wire cables alike. 80 wire cables also can't be any shorter than 254mm (ten inches), by the way.
In practice, 24 inch/600mm cables should be just fine for UDMA/33 mode with modern hardware. They may work OK for UDMA/66 as well, but I wouldn't count on it.
DimmniBurek ::
JEst sm kupu lani IDE kable ki imajo 90cm, gor sta 2 diska in CD RW in DVD RW, tko da...
There Is No Stronger Drug Than Reality
| » | HDMI kabel (strani: 1 2 )Oddelek: Kaj kupiti | 14634 (9954) | showsover |
| » | 34" ultra-wide (3440x1440) na ThinkPad T440p - bo delovalo?Oddelek: Pomoč in nasveti | 2065 (1810) | pirx |
| » | Dolga UTP kabel med dvema switch-ema!Oddelek: Omrežja in internet | 2051 (1803) | yapka |
| » | NV silencer 5 rev. 2 in 7800GTOddelek: Hlajenje in modifikacije | 1165 (1124) | raynox |
| » | master/slaveOddelek: Pomoč in nasveti | 7467 (7389) | TheJack |
