haimachi tezave
haimachi tezave
slovis ::
Ko program starta se ustavi pri setting up
kasneje javi tole:
configuration problem is most likely caused by your firewalling software blocking DHCP traffic on Hamachi adapter.Please make sure that UDP traffic from local port 68 to port 67 at 5.0.0.1 is allowed.Alternatively you can try completly disabling the firewall on hamachi adapter.
firewall v windowsih je izklopljen
  • zaklenil: ToniT ()
Housy ::
Ja problem je v tem, da ti ga firewall blokira in ti bi mogo omogočit te porte (vrata) v požarnem zidu. Sej ti točno piše katere in še piše ti da UPD. Probaj to prvo. Al pa da firewall popolnoma izklopiš, to je pa še druga možnost.
  • spremenil: Housy ()
ToniT ::
Ena tema bo dovolj!
Zaklepam
Vprašanje o povezavi preko Hamachi-ja
71584 (1005) ScottDJ_
Windows network share preko interneta?
Oddelek: Omrežja in internet
203200 (2898) Mr.B
Tekkit server error
121293 (1129) andrej02
Vpn povezava
93753 (2972) slitkx
hamachi
Oddelek: Igre
236904 (3970) ziga14
