Forum » Operacijski sistemi » Pingo Linux in ASrock K8NF4G-SATA2 NF4 S754 Zvok/mreza gonilniki
radems ::
Naložil sem Pingo 4.1 KDE namizje.
Pingo ni zaznal vgrajene mrežne kartice Realtek PHY RTL8201CL
in
ni zaznal niti vgrajene zvoène kartice Realtek ALC 850 7.1.
Ob samozaznavi zvočne kartice sporoči napako:
Error while initsialising the sound driver:
device /dev/dsp can't be opened (no such file or directory)
The sound server will continue, using the null output device.
Po teh navodilih sem poskušal namestit zvoèno vendar brez uspeha!
The source code copy from www.alsa-project.org. ver:R3.2
Linux Source Code for ALC audio codec
Installation:
This Source Code is from www.alsa-project.org.
For driver installation, please follow below steps.
Step 1. unzip source code
tar xfvj azx-021705.tar.bz2
Step 2. Turn on sound support (soundcore module, default turn on)
Step 3. Complied source code
a. ./configure
b. make
c. make install
d. ./snddevices
Step 4. Edit your /etc/modules.conf or conf.modules depending on the
distribution
(Please refer to the attached modules.conf)
Step 5. reboot your machine
Note: 1. The most detail information, can refer the
alsa-kernel/documenttation/ALSA-Configuration.txt in the azx-021705.tar.bz2.
2. Kernel Version must be 2.2.14 or later.
3. All mixer channels are muted by default. You must use a native
or OSS mixer program to unmute appropriate channels.
4. If can not compile the source code, try to rename the /usr/src/linux-2.x
-> /usr/src/linux.
5. The driver added to support the SPDIF functoin.
6. Suggest use alsamixer to control mixer function. you can find it in the
alsa-utils-0.9.4 (www.alsa-project.org).
7. a. You can download the alsa-lib-1.0.8 and alsa-utils-1.0.8 form the
www.alsa-project.org, then unzip and install them.
b. Used "alsaconf" can autodetect which drive you need to install (step 4).
pod korakom 2
nisem storil nič saj mi ob zagonu vedno sporoči
Pod korakom 3 Step 3. Complied source code
sem v neki mapi home/user/gonilniki z SU privilegijem izvedel ukaze
a. ./configure
b. make
c. make install
d. ./snddevices
ni mi javilo nobene napake
Ustavilo se mi je pri koraku 4
Step 4.Edit your /etc/modules.conf or conf.modules depending on the
distribution
(Please refer to the attached modules.conf)???
vsaka pomoč je dobrodošla
in
Installation:
a. ./configure
b. make
c. make install
d. ./snddevices
distribution
-> /usr/src/linux.
pod korakom 2
a. ./configure
b. make
c. make install
d. ./snddevices
distribution
- premaknil iz Pomoč in nasveti: gkovac ()
| » | [Linux] Tezave z zvocnim cipomOddelek: Operacijski sistemi | 2307 (2023) | MarkoSan |
| » | Slackware 10 - ZVOKOddelek: Operacijski sistemi | 1458 (1368) | WarMaker |
| » | Fedora - Modules - Opl3sax - kako zagnati module avtomatično?Oddelek: Operacijski sistemi | 1102 (1038) | Gandalfar |
| » | Linux in integrirana zvočna karticaOddelek: Operacijski sistemi | 1285 (1210) | Malinovc |
| » | red hat 9 in mrežna kartica sis900Oddelek: Operacijski sistemi | 1419 (1368) | dr.J |
