Help (mp3 software)
Help (mp3 software)
WTF? ::
Pred kratkim sem si kupiu mp3 predvajalnik SONY NW-E205 in, da lahko na ta mp3 playa nalozim muzko, jo lahko samo s programom sonicstage (z winsi ne gre) problem pa je, da je ta program neverjetno beden ... a obstaja kaksna alternativa ?
MihaFirst ::
a si poskusu, da musko naložiš iz My Document na Removable disk, ki predstavlja USB priključek na compu? kir windows pa maš? 0:)
www.gamma.si
SimplTech ::
Tole sem našel na nekem opisu enega drugega Sony mp3 playerja:
Now to the major bad point - the SonicStage software. Despite the bad reviews I read, I actually went into it with an open mind - is it really as bad as they say? Probably not, but it's not good enough for a major player like Sony. It's one of the very few programs that has crashed on me. Obviously Sony Electronics were under big pressure from Sony Music to protect their music with DRM. But the result is a bloated piece of software which imposes limits I'm not use to. CDs ripped to ATRAC have to imported into it's Library before transfer to the player, making the process more sludgy than it should. Even imported mp3s are wrapped with DRM stuff, so you are advised to back them up before importing. Fortunately there is an alternative piece of software (from Sony itself, but not exactly advertised), that lets you drag and drop mp3s directly and quickly onto the player. It's very basic though, devoid of features but good enough. Using this has stopped me deducting a star.
No sem našel še nekaj dodatnih informacij z googlom. Na temle postu Alternative Sony Network Walkman Software: Doesn't the NW-107 play MP3's natively? If so, you can probably try Sony's "mp3 manager," which is a little application that lets you drag 'n drop MP3 files to the device sans SonicStage. Try googling for it - I'm not sure where Sony keeps it on their website.
Ta program Sony MP3 File Manager pa najdeš tukaj Sony Mp3 Manager
Za dodatni info pa vpreži googla s ključno besedo: SonicStage software alternative
WTF? ::
Stari, najlepsa ti dala ! BTW.. Xpje mam
Modri dirkač ::
Hvala za informacije, ker ta varianta s sonicstage je pa res bedna.
Everybody lies!
Zakaj mi noče predvajat musk na mp3 predvajalniku?
51332 (1206) binxii
Walkman star 30 let
466372 (4682) opeter
Predvajalnik ipod ali kaj podobnega
202739 (2235) UNIVERZUM
Sony notesnik
122133 (2020) j cole
Sony....you suck
102151 (1706) kriko1
