Težava z WINAMP v5.12
Dr.S ::
Ko skušam v WinAMPu odpret radijsko postajo www.gaydarradio.com (odlična muzika) mi tega noče in javi sledeče:
Music File Identification Error
The digital music file currently playing cannot be identified. This could be due to a number of reasons, but the most common is improper or garbled tagging.
Since the Minibrowser depends on clean information to work, the integrity of tags is essential. Checking your music file tags is simple, just do the following:
Press Alt-3.
In the ensuing field, you will see two tagging options: 1) ID3v1 and 2) ID3v2.
We recommend using the ID3v2, as it can contain more information about the file.
To correct the tag, click the white box by the word "ID3v2 Tag," enter or correct any information you have availalbe, such as artist name, album name and so on, then
Click "Update."
Then click the "Refresh" icon on the MiniBrowser frame (lower left). The MiniBrowser should now work.
Skušam najti nastavitve z ALT-3 pa nič o ID3v2.
KJE LAHKO TO NASTAVIM, DA MI BO RADIO POSTAJA DELOVALA V WINAMPU?
Hvala.
Dober Singleplayer campain FPS špil?
Oddelek: Igre
355802 (4976) Bor H
Windows 7 Installer (64-bit) - težave
Oddelek: Programska oprema
153725 (3115) fr!Xy
Ne predvaja novega audio CD
52616 (2572) Tea Time
pohitritev dsl ali kabelskega neta v win xp
Oddelek: Omrežja in internet
62190 (1928) BlueRunner
Win XP security
81785 (1647) JanezH
