Forum » Kaj kupiti » koliko bi dobil za Monitor LG Flatron 915FT Plus?
|Luka| ::
Zadeva je stara 2,5 leti, in je kot nov. Deluje BP.
Nekaj specifikacij:
CDT Technology Flatron Flat Tube, Dynamic Focus
CDT Size/Type 19"(18.01" Viewable)
Display Size 14.4" x 10.8"
Display Colors Unlimited
CDT Transmission 40%
CDT Pitch 0.24mm stripe
CDT Coating Wide-ARAS, internal anit-glare
Phosphor Persistence Medium Short
Maximum Resolution 1880 x 1440 x@ 70 Hz
Maximum Flicker-Free Resolutions 1600 x 1200 @ 85 Hz
1280 x 1024 @100 Hz
1024 x 768 @ 130 Hz
800 x 600 @170 Hz
640 x 480 @ 200 Hz
Apple Compatibility 832 x 624 @ 70 Hz
1152 x 870 @ 120 Hz
Display Capability Auto-sync within scanning frequencies
Horizontal Scanning Frequencies 30-110 KHz
Vertical Scanning Frequencies 50-200 KHz
Pixel Frequencies (Clock) 235 MHz
Input Signal RGB analog, 0.7 Vp-p/75 ohms
Sync Signal Separate, composite, SOG
Input Connectors 15-pin D-sub, and 5BNC
Monitor Control Type Digital microprocessor controls with on-screen display
Memory Modes 13 factory preset, 26 user-settable
Plug and Play DDC 1/2B, USB (hub w/4 ports)
Digital On-Screen Controls Brightness, contrast, color controls, H/V position, H/V size, pincushion, pin balance, pin S and pin W, purity, H/V convergence, trapezoid, parallelogram, H/V moire control, manual degauss, tilt control, video level, DDC mode, OSD position, mode recall, self diagnostics, display language select
Language Selection English, German, French, Italian, Spanish, Portugese, Swedish, Finnish
Front Panel Controls Power, OSD, on/off, up, down, left, right, set
Power Requirements AC 90-132/198-264V, 50-60 Hz
DPMS Power Consumption Maximum: 140 Watts
Stand-by: 8 Watts
Off: 3 Watts
Universal Serial Bus (USB) Hub (1 upstream,4 downstream)
Supplied Cables Power Cable, 15 Pin D-sub cable (VGA), USB cable
Tilt/Swivel Base Detachable, forward 5°, backward 13.5°
Dimensions with Base 18.5" x 18.5" x 18.9" (W x D x H)
Weight: Set/Packed 58.8 lbs./62.5 lbs
Mean Time Between Failure 50,000 hours
Safety/regulatory UL, FCC-B, CSA, TUV-GS CB, DHHS, NEMKO, SEMKO, DEMKO, FIMKO, GOST, CE, FTZ-B, TCO'99, HWC,ROV, ISO9241-3, ISO8241-8 NUTEK, EPA, CCIB
Nekaj specifikacij:
1280 x 1024 @100 Hz
1024 x 768 @ 130 Hz
800 x 600 @170 Hz
640 x 480 @ 200 Hz
1152 x 870 @ 120 Hz
Stand-by: 8 Watts
Off: 3 Watts
Izi ::
Maksimalno 20k SIT če je res vse v najlepšem redu.
Najbolje je vedno, da najprej pogledaš za koliko ga prodajajo ostali.
Evo:
Pred skoraj enim letom ga je pogo prodajal za 25k. Lahko ga vprašaš, če mu je uspelo.
Evo:
bluefish ::
se, če uporabljaš toliko časa dokler ne odpove ali pa samo preizkusiš, prodaš, kupiš novo.
Novo kupit in čez 2 leti prodat se res nč ne splača. Niti avto, monitor, digitalni fotič...znucaj do konca pa je. Jaz imam tudi enga 19" preveč, ki niti nov ni bil drag, pa kaj naj znjim...rajši ga imam za kdaj pa kdaj kot pa da ga prodam za 10 jurjev.
| » | 1 nakup lcd monitorjaOddelek: Kaj kupiti | 2154 (1992) | raab himself |
| » | LG 1980U al pa neovo 19EOddelek: Kaj kupiti | 1957 (1745) | Silencer |
| » | MonitorOddelek: Kaj kupiti | 1941 (1756) | jerry2000 |
| » | Kateri monitor?Oddelek: Kaj kupiti | 1948 (1799) | boštjan |
| » | Mitsubishi Diamond Pro 930 monitorOddelek: Kaj kupiti | 1281 (1199) | Clemento |
