NTLDR is missing
NTLDR is missing
adrian007 ::
Problem je sledeč. Sem formatiral računalnik, če nimam CD od XP-jev not, mi pri nalaganju napiše NTLDR is missing, če pa je not, pa gre normalno vse. Kaj je to narobe....
TitanSLO ::
direkt z HELP ME
Windows XP users
1. Insert the Windows XP bootable CD into the computer.
2. When prompted to press any key to boot from the CD, press any key.
3. Once in the Windows XP setup menu press the "R" key to repair Windows.
4. Log into your Windows installation by pressing the "1" key and pressing enter.
5. You will then be prompted for your administrator password, enter that password.
6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter "E". This letter may be different on your computer.
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Mac OS Snow Leopard na PC
Oddelek: Operacijski sistemi
485632 (4180) Gray_Warden_
Prehod iz Win2000 na Win XP
362550 (1875) chrush
vista problem
153711 (3370) markk1
Win. could not start...... wtf. \windows\system32\config\system
82812 (2725) Tovaris Stalin
Windows XP - težave z zagonom
63165 (3007) SebaR
