Vaše temperature AMD 64bit procesorjev
egregor ::
Lep pozdrav!
Ne vem če je najbolje da odpiram novo temo, ampak naj bo.
Zanima me temperatura procesorja in sice imam AMD 64bit Athlon 3000+ 754 z jedrom NewCastle.
Če nimam navitega (2009,8 Mhz) imam temp. okol 39-41 niha, pri igranju iger pa se razume okol 55' C.
Ni mi pa logično da je temp. procesorja okol 27'C kadar je navit na 2400 Mhz, ali je možno da mi senzorji ne kažejo pravilno?
P.S. Na plan z vašimi temperaturami :))
f_w ::
Processor
Model : AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
Speed : 2.01GHz
Model Number : 3800 (estimated)
Performance Rating : PR3015 (estimated)
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Dual-Core
Package : FC µPGA939
Multiplier : 10/1x
Minimum/Maximum Multiplier : 10/1x / 10/1x
Generation : G8
Name : M2B-BH Athlon 64 X2 (K8 Manchester/Toledo) 90nm 2-2.4GHz 1.45-1.55V
Revision/Stepping : 2B / 1 (150)
Stepping Mask : DH-E3
Microcode : MU0FB14D
Core Voltage Rating : 1.350V
Min/Max Core Voltage : 1.100V / 1.400V
Maximum Physical / Virtual Addressing : 40-bit / 48-bit
Native Page Size : 4kB
Co-Processor (FPU)
Type : Built-in
Processor Cache(s)
Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size
Internal Instruction Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size
L2 On-board Cache : 512kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size
L2 Cache Multiplier : 1/1x (2010MHz)
Upgradeability
Socket/Slot : Socket 939
Upgrade Interface : Unknown
Supported Speed(s) : 3.70GHz+
Processor Power Management
Processor Throttling Enabled : Yes
Throttle Range : 50% - 100%
Environment Monitor 1
Model : ITE IT8712F LPC
Version : 7.00
Mainboard Specific Support : No
Power Rating(s)
CPU Core Power : 57W (estimated)
Sensors
CPU Temperature : 32.0°C / 89.6°F
CPU Voltage : 1.36V
mijau
MTm2H37rqt7B ::
AMD64 3000 (2Ghz)
Idle: 25-26 stopinj
Idle z Cool'n'Quiet: 21-22 stopinj
V prostoru je temperatura 18-19 stopinj
_Dejan_ ::
mah to je itak bv primerjat k vsak senzor drugače kaže...
Drugač pa ma moj AMD 3000 Venice navit na 2780Mhz z 1,67V temperaturo v idle 32°C s tem da je zravn še grafična hlajena(Voltmodana)...
ASUS P5E3, INTEL Q6600(3000Mhz 333x9), ATI HD 2600XT,
A-Data 4x2GB PC3-10700H(9-9-9-24-2T),LSI 9260-8i,
4x OCZ Vertex Turbo 30GB(RAID10), 3x1TB (RAID1+Spare)
jarre ::
Moj Athlon 64 3000 (754-Newcastle) je nenavit ogret na 30 stopinj pri sobni temperaturi 22 stopinj Celzija in softmod Gforce 6600GT.
zee ::
X2 4200+ :
ko se dolgočasi: 40°C
ko kaj dela: 50°C
zee
madmitch ::
Athlon 64 3000+ Venice S939, nenavit @1800
Nekje med 35C in 42C
gfighter ::
Athlon 64 3000+ Venice S939, navit na 2700
Idle: 30 stopinj, Full load: 47 stopinj (3 ure prime-a + savna v sobi)
Vent: Thermalright XP-90
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput saxum immane mittam
  • spremenil: gfighter ()
sid911 ::
a64 3200+ @2550MHz idle - 29° ful load ~46°max. s stock hladilnikom
dajte napisat še kak hladilnik uporabljate
1. Asus P8P67 LE | i3 2100 | HD 3850 | 2x4GB | 320 GB + 2 TB
2. FSC Amilo PRO V3515 ( T2060;2 GB;80GB)
  • spremenil: sid911 ()
egregor ::
jaz uporabljam tale hladilnik Klik
Ledenko@64 ::
Mobile AMD Athlon 64 3200+ (2Ghz @1,25V)
-idle 35, full load 50
pri 2340 Mhz @ 1,45V (samo za testiranje)
-idle 45, full load 60
pri 800 Mhz @ 0.8V
-idle 26, full load 40
ponoči ga dam na ~660 Mhz in dela pod 40°C brez ventilatorja
v prenosniku ga hladi majhen ventilatorček
.::..::.@Mac.::..::.
VASkO ::
opteron 144, 2.7GHz 1.55V, idle 25°C ,load 36°C. vodno + grafa x800xt pod vodo.
zee ::
za hlajenje uporabljam stock hladnjak pri minimalnih obratih
zee
venice @ 2790MHz 1.7V idle 33-36°C. ful load 49-52°C (odvisno od temp v sobi.
hlajenje je pa vodno, s tremi bloki.
5pellfire ::
Venice 3000+ navit na 2700Mhz@1.4v idle ~33C load max.45C.
Uporabljam pa ThermalRight SI-120 + NB-UltraSilentFan SX2 Blue Rev.2
Sami ::
Vidim, da so 64-bitni proci veliko bolj hladni, kot pa starejši 32-bitni. Kakšna pa je priporočena najvišja temperatura? (za 32-bitne je okoli 60 stopinj)
5pellfire ::
Čim nižja, boljše je. Za OC toplo>:D priporočajo da je pod 50C.
tiborrr ::
Pa vecina senzorjev itak laze kot pes, takda ne vsega verjet. Ene DFIjke kazejo res prenizke temperature, medtem ko ene Epoxke kazejo se prevec.
Primoz78 ::
Opteron 146 CABYE 0540 APMW @ 2,9ghz 1,488V...idle 19-22°C full load 33-36°C pod vodo. TRENUTNO V RACUNALNIKU!
Opteron 146 CABYE 0540 FPBW @ 3ghz 1,408V...idle 32-35°C full load 48-53°C pod vodo. DEAD :'(
Athlon 64 X2 3800+ @ 2,6ghz 1,552V...idle 28-32°C full load 45-48°C pod vodo. PRODAN!
Vse to na DFI Ultra-D plati...vodno hlajenje vedno isto.
Lp Primoz
GAMING HTPC I5 2500k/ASUS P8P67/4GB CORSAIR XMS3/
VERTEX 3/ASUS 670 GTX OC/Antec TP-650 NEW/
Sami ::
Moja stara Epox 8K3A je kazala povprečno 17 stopinj preveč, ker je imela kao senzor zraven jedra procesorja.
tiborrr ::
Jep, poznam to plosco, res je kazala kakih 10-15°C. Si jo pa lahko 'nategnil', ce si v mosfete usmeril ventilator... Je takoj kazala bistveno bolj realno temperaturo >:D
Izi ::
AMD X2 3800+ @ 2600MHz 1,6V - hladen kot špricar :D
idle: 38 C, ventilator se ne vrti
full load: do 52 z ventilatorjem in do 58 C brez ventilatorja >:D
Najprej sem mislil, da bo šlo povsem brez ventilatorja ampak je za igranje novejših iger še vedno potreben ventilator :|
Ventilator se mi prižge na 40 C in full zalaufa na 50 C
Ventilator je večino časa ugasnjen (za to skrbi BIOS)
Je pa Golden Orb II
Baxxxter ::
AMD X2 3800+ @ 2400mhz
idle 29°
ful load newem :\
hlajenje stock
H4rVeSteR ::
A64 3000+@2700 pri 1.61V (windows)
IDLE: 25 C
Full load: 38-40 C
Cooler TT Tower 112 + 92mm vent, ki vleče vn
***I have a dream***
bremzzi ::
A64 3000+ Venice (default)
idle: 25 C
load: 30 C
box cooler na 5V - neslišno in solidno hlajenje:)
umax ::
A64 3700+@2200Mhz, 1.35V --> idle: 32°C, load: 38°C
A64 3700+@2700Mhz, 1.57V --> idle: 34°C, load: 48°C
*load/12h Prime95
CPU Cooler je pa tale --> Zalman CNPS9500
Asus A8N32-SLI Deluxe/170 0550VPMW@3000MHz/2GB OCZ EB Platinum@3-3-2-5@250MHz
POV GeForce 7800GTX 512MB (610/1820)/SB Xi-Fi Fatal1ty/Tagan530u15/TT Tsunami
zeeero ::
Emm, mene pa čudijo vaše temperature, ali pa so moje v kurci...
Osn. pl: Asus a8n-e
Procesor: AMD Athlon 64 3200+
Ram: 512 Mb DDR
Gainward GeForce 6600GT 128Mb, DD3
Maxtor SATA 200Gb
Everest mi kaže takšne temperature v idle:
Osnovna plošča: 31°C (88°F)
Aux: 45°C (115°F) (procesor?)
Grafični procesor: 34°C (93°F)
Maxtor 6L200M0: 37°C
Ventilatorji
Procesor: 3130 RPM
Ohišje: 2170 RPM
Po enournem igranju UT2004 so temperature iste (razen za grafično, 5° višje...)? 8-O
V ohišju zadaj je še en ventilator 80mm, skozi katerega piha kar hladen zrak (hlajši kot z napajalnika). To po moje sploh ni normalno, ali pač? Upam to, da se senzorji motijo... Nočem pa razmetat računalnika, ker potem izgubim garancijo... What to do?
One Step Closer To Oblivion...
  • spremenil: zeeero ()
toncek_95 ::
do kakšne temperature pa je varno furat amd 64
ASUS A8N-E, AMD ANTHLON 64 3200+@2500Mhz, LEADTEK 7800GT VIVO,
1GB GEIL VALUE, HITACHI 160GB SATA2,
LC POWER 550WG 140mm, GMC H-60
M.B. ::
processor : 0
vendor_id : AuthenticAMD
cpu family : 15
model : 31
model name : AMD Athlon(tm) 64 Processor 3200+
stepping : 0
cpu MHz : 2009.992
cache size : 512 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 1
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 syscall nx mmxext fxsr_opt lm 3dnowext 3dnow lahf_lm
bogomips : 2011.93
idle 20-27°C
compiling 30-36°C
Poleti 42°C
[Zračno hlajenje] Kateri hladilnik za s939/754? (strani: 1 2 3 )
10628402 (24299) svetetko
Hlajenje LGA755 Core 2 Duo - kateri hladilnik kupiti? (strani: 1 2 )
5711369 (9504) Jst
Kateri Hladilnik za AMD (pasivno hlajenje) ?
51316 (1240) cortez
izbira hladilnika in termalne paste
192006 (1627) fras
TT Big Typhoon ali TR XP-90C?
272596 (1807) mm46
