VisualBasic vprasanje
alesrosina ::
zanima me kako narest, da se ikona programa pojavi v taskbaru (tm kt je ura v Windowsih).
webblod ::
Najprej kreiraš nov podatkovni tip:
Public Type NOTIFYICONDATA
cbSize As Long
hwnd As Long
uId As Long
uFlags As Long
uCallBackMessage As Long
hIcon As Long
szTip As String * 64
End Type
Določiš potrebne konstante:
Public Const NIM_ADD = &H0
Public Const NIM_MODIFY = &H1
Public Const NIM_DELETE = &H2
Public Const NIF_MESSAGE = &H1
Public Const NIF_ICON = &H2
Public Const NIF_TIP = &H4
Public Const WM_MOUSEMOVE = &H200
Public Const WM_LBUTTONDOWN = &H201
Public Const WM_LBUTTONUP = &H202
Public Const WM_LBUTTONDBLCLK = &H203
Public Const WM_RBUTTONDOWN = &H204
Public Const WM_RBUTTONUP = &H205
Public Const WM_RBUTTONDBLCLK = &H206
Nato deklariraš funkcije:
Public Declare Function SetForegroundWindow Lib "user32" (ByVal hwnd As Long) As Long
Public Declare Function Shell_NotifyIcon Lib "shell32" Alias "Shell_NotifyIconA" (ByVal dwMessage As Long, pnid As NOTIFYICONDATA) As Boolean
in seveda kreiraš spremenljivko podatkovnega tipa:
Public nid As NOTIFYICONDATA
Sedaj pa še spišeš kodo, ki bo vse to 'pohandlala'... Lahko jo ustvariš v inicializaciji programa (torej main proceduri) ali pa daš uporabniku možnost izbire "Show in System Tray"... Pač kakor hočeš.
Upam da sem ti odprl pogled na zadevo...
There must be a reason, why I'm so damn dissapointed on M$ Visual Basic
WEBblod.NET :: Slovenska programerska scena
alesrosina ::
hvala ti.
[C#] Prosim pomagajte! Potrebujem program, ki bi pobiral podatke iz ene strani
Oddelek: Programiranje
213220 (2830) David1994
Vb6
101804 (1667) StratOS
API+VB
262555 (2259) webblod
Odpiranje dat.exe v VB
123831 (3624) webblod
Visual basic Progress bar
52012 (1945) Lunik
