WinXP Skinanje #2
WinXP Skinanje #2
Tr0n ::
No, pa sem le docakal to, kar sem mislil, da ne bom nikoli :).
Podjetje TGT Soft. je izdalo Styles XP in v kratkem se Styles Builder, ki vam bo omogocal spremembo ze obstojecih visualnih stilov, kot so trenutno Blue, Olive in Silver. Vse dodatne informacije dobite @ http://www.tgtsoft.com. Pa se nekaj iz njegovega FAQa.
What is Style XP?
Style XP will have many carefully constructed styles for XP. Style XP Beta 2 has only one of these styles: Toothpaste.
Is Style XP safe? How does it work? How does it differ from other products?
Style XP has no service or executable code, so there is no worry about your machine slowing. We have completely decoded the luna.msstyles file and have created an XML-to-msstyles engine. Our StyleBuilder product takes the XML with their corresponding images and compiles it to an msstyles file.
Will Style XP slow my system down?
No. Style XP will operate at the same speed as the original Microsoft supplied styles. When compared to the Windows® Classic look, all of the new styles (Blue, Olive Green, and Silver) will run a tiny bit slower. Some other skinning products will produce a measurable system slow down, especially with complex-looking skins.
notice that some applications, like the command prompt, don't use the style of the other windows. Can StyleBuilder handle the modification of those colors?
Yes. The command prompt takes on the classic look, but the rest of the windows maintain the applied visual style. These "classic" settings reside in the same place as the new visual style settings. StyleBuilder does handle this kind of alteration.
I have noticed that some new UI elements have appeared in explorer. Will the first version of Style Builder handle those settings?
Like most of the graphical elements in XP, these are just simple gradients defined by 2 RGB values and a series of bitmaps, some with Alpha channels. These setting are easily modifiable with StyleBuilder and your favorite paint program.
Slisi se dobro :). Gremo probat.
Tr0n ::
Aja, to sem se pozabil. Taisto podjetje isce tudi talentirane oblikovalce skinov in je za dober skin pripravljeno tudi placati. Check @ http://www.tgtsoft.com/challenge.html .
teme in ikone za windows XP
103744 (3541) PaX_MaN
Najljubsi styli v XP?
Oddelek: Operacijski sistemi
161721 (1233) rc-car
Kako spremeniti Boot Logo v XP
Oddelek: Programska oprema
233055 (2692) zile
Style builder Beta 1
92552 (2552) Morpheus
Styles XP
263150 (3150) andrej
