Forum » Kaj kupiti » epox 8kta3
epox 8kta3
danielka84 ::
na njo lahko daš vse od Duron 600 ~ 1000(Morgan), ter vse Thunderbirde do 1400, ki so tudi na 266 FSB!
Za Athlon XP pa še žal ni novega biosa (za sedaj, verjetno pa bo).
ni-da-ni
danielka84 ::
kje si ga pa dobil?
Na AMDforums.com še dobenemu ni uspelo AthlonXP gor spravit(vsaj mislim)
Na Epox 8KTA3 ne gre, na Epox 8KTA3 Pro pa gre, tak sem jas čul!
Vasko kje dobim ta bios?
Hvala!
Hvala!
ni-da-ni
Blue3D ::
Glede da imam zdaj durona 700@933
kateri procesor bi se splacalo gor dati ?
npr. osnovni takt 1000 mhz pa na kolko bi lahko navil v mejah normale
Imam pa dober hladilnik tak da ni problema pri 933 mhz max. 42 stopinnj C zdaj imam 39 C
Konkretno kateri procesi se lahko za koklo navijejo ?
Athlon 1400/266
Athlon 1333/266
Athlon 1200/266
Athlon 1133/266
Athlon 1400/266
Athlon 1333/266
Athlon 1200/266
Athlon 1133/266
ChiefThunder ::
Tukaj pejd mal pogledat, da vsaj okvirno vidiš...
... po liniji najmanjšega odpora. ;)
VASkO ::
zakaj ne berete newsgroupov od Epoxa?
Preberi to (z Epoxovih novic, news.epox.com!!!):
Folks,
It's not posted yet on the regular Epox site, but at the FTP site, there's a
new bios for the 8KTA3 Pro(+), which can be found at:
ftp://ftp.epox.com/support/motherboard/bios/
Look for the "8k201a19.exe" file. It's 243 KB in size...
Apparently, it has added XP and MP capability! FINALLY!
For the original 8KTA3(+), look for the file called, "8kt31a19.exe", 242 KB
Here's the "readme.txt" file for the new BIOS for the 8KTA3 Pro(+):
"Enhancements & Fixes for this BIOS release:
Fixed HCT ACPI test failures under WIN2K. Fixed system hang when
installing a SoundBlaster and Live Ware. Fixed WINXP installation
failure with Nvidia Geforce 2MX AGP Card. Fixed abnormal FAN signal
hanging BIOS. Fixed ACPI errors in event viewer under WINXP. Fixed
issue of resetting FSB back to 100MHz when previously set for
133MHz. Added new BIOS feature to differentiate between Athlon XP
or Athlon MP. *
Folks,
or Athlon MP. *
VASkO ::
deluje, zakaj pa ne preberes malo Epoxovih novic, se naslov streznika sem napisal
jaz sem si ta BIOS flasal pa dela (mam doma se en rezervni flash ROM, ce kaj stekne samo hot-swap naredim in flasham nazaj)l
VASkO ::
aja, imam tudi cbrom utility (za BIOSe modificirat) pa pri tem novem BIOSu napise pod posebnostmi, da ima updatano microcodo in CPUID, tako, da potem mora tudi delat, kmalu bo BIOS tudi na Epoxovi strani (kaksen teden) za zdaj je samo na njihovem FTPju (link zgoraj)
danielka84 ::
ok, saj piše v readme fajlu da podpira AthlonXP in AthlonMP!
Torej sedaj podpira vse Durone, vključno z novim Morganom, potem vse Thunderbirde na 200 in 266fsb, potem še pa AthlonXP in AthlonMP tudi na 200 in 266fsb!
plata mi je še zmeraj iz novice v novico bolj všeč
ni-da-ni
| » | 8kta3 prblOddelek: Strojna oprema | 1229 (1028) | danielka84 |
| » | Epox 8KTA3 in Athlon XPOddelek: Strojna oprema | 1146 (910) | Matek |
| » | Naj stabilna,bolsa,SDR plata.Kdo je?Oddelek: Pomoč in nasveti | 1654 (1453) | VASkO |
| » | ABIT KT7 RAID-ATHLON1300Oddelek: Strojna oprema | 1914 (1440) | ijatebi |
| » | motherboard za AMD AthlonOddelek: Kaj kupiti | 1818 (1562) | CCD |
