Problem z ugašanjem računalnika (sam se resetira)
[Pavle] ::
Pozdravljeni fantje in punce...
...mam en problem:
Ko pržgem komp se mi včasih sam ugasne (ponavad ko zažene kakšn bolj "zahteven" proces:več aplikacij naenkrat, ...al pa ko se ugasne monitor) No nek sm prebrov da je to zarad temperature procesorja pa to, da se sam ugasne, sam mam temperature: CPU 38, matična 36, disk 30 stopin C, tko da to ne vem če je razlog...nekje sm prebrav da je razlog mogoče v ram-u...kao če nista ista (mam 1x 256MB + 2x nova 512MB), tko da, vsi podatki o ram-ih:
Chipset Information :
Type : DDR-SDRAM PC2100
Frequency : 134 MHz
FSB/RAM Multiplier : 1/1x
Channels : Single
PAT Enabled : Yes
ECC Diagnostic : Ne
CAS Latency (tCL) : 2.5 clocks
RAS to CAS (tRCD) : 3 clocks
RAS Precharge (tRP) : 3 clocks
Cycle Time (tRAS) : 6 clocks
Information SPD EEPROM (A0) :
Type : DDR-SDRAM PC2700 (166 MHz)
Size : 256 MB (1 rows, 4 banks)
Module Buffered : No
Module Registered : No
Width : 64-bit
Error Correction Capability : No
Max. Burst Length : 8
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 2.5v
Supported Frequencies : 133 MHz, 166 MHz
CAS Latency (tCL) : 2 clocks @133 MHz, 2.5 clocks @166 MHz
RAS to CAS (tRCD) : 3 clocks @133 MHz, 3 clocks @166 MHz
RAS Precharge (tRP) : 3 clocks @133 MHz, 3 clocks @166 MHz
Cycle Time (tRAS) : 6 clocks @133 MHz, 7 clocks @166 MHz
Information SPD EEPROM (A1) :
Type : DDR-SDRAM PC2100 (133 MHz)
Size : 512 MB (2 rows, 4 banks)
Width : 64-bit
Voltage : SSTL 2.5v
Supported Frequencies : 100 MHz, 133 MHz
CAS Latency (tCL) : 2 clocks @100 MHz, 2.5 clocks @133 MHz
RAS to CAS (tRCD) : 2 clocks @100 MHz, 3 clocks @133 MHz
RAS Precharge (tRP) : 2 clocks @100 MHz, 3 clocks @133 MHz
Cycle Time (tRAS) : 5 clocks @100 MHz, 6 clocks @133 MHz
Information SPD EEPROM (A2) :
Size : 512 MB (1 rows, 4 banks)
Width : 64-bit
Voltage : SSTL 2.5v
Drgač mam pa Intel Pentium 4 (2400 MH) procesor, GigaByte matična, Radeon 9600 series grafična, ...
Windowsi pravjo (k se spet prižgejo pa je un "system has recovered from a serius error" ... pač za error report), da je neki zarad driverjev, sam ne vejo kerih...tko da
...tko da res ne vem kaj bi naredu (Mam nov disk, ram-a, pa tv kartico...) Na starmu komp-u mi je normaln delal vse...no saj resetirov se ni sam :)
Opravičujem se, če je že kakšn tak post, sam je ga nism najdu...saj ne da bi mi pomagov...tko, da se vam izkreno zahvaljujem, če mi boste uspel pomagat...
LP, Pavle
Kami ::
Mogoče kriv napajalnik?
Probaj z kakim drugim
[Pavle] ::
No če vas zanima...sm vrgu vn en ram pa še 1x naložu Win. pa vse vse ql zdej...tko da...ql ane.
LP Pavle...
fahrenGONE ::
Za testirat rame: http://www.memtest86.com/.
st00rm ::
ej fahrenheit a obstaja kej takšnega za grafično kartico ???
God must love stupid people because he made so many of them.
Gonilniki
Oddelek: Programska oprema
122422 (2305) Housy
Nadgradnja DDR400 RAM-a
111828 (1667) ignis
Mticna plosca i845Pe
201939 (1722) mtosev
A se da navit RAM!!!!!
Oddelek: Navijanje
101528 (1363) JIM22
ram PC3200 deluje kot PC2700
81796 (1703) drejcmb
