boot.ini
boot.ini
lebang1 ::
Boot ini imam tako:
[boot loader]
timeout=0
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /fastdetect /NoExecute=OptIn
in me zanima kaj pomeni /NoExecute=OptIn
fahrenGONE ::
To je za kontrolo Data Execution Prevention, vec o tem pise tukaj.
Edit: Jaz imam na /noexecute=alwaysoff in tako mi ne tezi vec s tem in sistem dela malo bolj hitro.
krneki ::
lebang1 ::
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
Data Execution Protection - DEP
Po temu vem tolko ki prej.
Ali je to dobro in kaj je narobe če to zbrišem?
OmegaBlue ::
Nastavi na off, in ne nič ni narobe.
Boot.ini in Windows XP SP3 problem
191936 (1685) kixs
Pomoč pri bootanju vista, xp
132197 (2059) matjaz23
Težavica z boot.ini v XP-jih
Oddelek: Operacijski sistemi
61504 (1365) >>><<<
en problem
61512 (1429) Good Guy
Windows XP PRO Boot problem
81689 (1656) 50Cent
