Blokiranje naslovov strani
mobil123 ::
Zanima me če kdo pozna kakšen program, s katerim je mogoče blokirati določene internetne strani. To je imela panda internet security 2006, že vgrajeno, vendar mi je potekel aktivacijski čas.
Hvala
gumby ::
to se da elegantno resit z editiranjem C:\WINNT\system32\drivers\etc\hosts
dodas naslov in ga postavis na 127.0.0.1
OmegaBlue ::
Je bilo veliko takih tem, a naj ti bo. Za blokiranje URL naslova (ubistvu domene), kar uporabi hosts datoteko, ki jo najdeš v C:\WINDOWS\system32\drivers\etc.
mobil123 ::
Mi ne dela kot bi moralo. Če grem po tistem primeru recimo da hočem blokirati bolho notri napišem:
195.246.14.51 bolha.com
127.0.0.1 localhost
pa ne dela..
gumby ::
takole:
127.0.0.1 bolha.com
edit:
localhost pusti kot je...
ta datoteka ni za blokiranje strani, ampak za neke vrste lokalen DNS.
na ta nacin bo bolha.com v bistvu tvoja masina:D
  • spremenil: gumby ()
mobil123 ::
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
127.0.0.1 bolha.com
mobil123 ::
to sem napisal pa se vedno ne deluje..
gumby ::
browser restartaj... ali pa kar cel sistem
za FF je dost samo browser, za IE ne vem
CaqKa ::
a nisi hotel da nebi delovalo?
mobil123 ::
Res malo dvoumno... mislil sem da še vedno noče blokirati...
Sedaj sem restartal cele windowse, pa se vedno noce blokirati. Na FF in explorerju se vesno pridem na bolho nemoteno..
mobil123 ::
A mogoce kaj vpliva router?
gumby ::
pri meni dela, in sem tud na routerju...
a na routerju ne mores nastavit blokiranja?
mobil123 ::
Našel odgovor... Poskusil sem napisati
127.0.0.1 www.bolha.com
ter zablokira.
127.0.0.1 bolha.com
pa ne..
Še enkrat hvala za odgovore, še posebej pa gumby-ju.
CaqKa ::
če imaš router poglej če lahko router blokiraš
pa namesto bolha.com probaj napisat *.bolha.com ali pa www.bolha.com
klihk ::
Je mogoče blokirati tudi chrome://downloads/ in https://www.sendspace.com/, ker preko ruterja mi teh dveh noče blokirati, ostale strani pa?
clancy ::
Kako bi se lahko blokirale določene neželjene strani kar preko routerja v celem domačem omrežju? Na primer, da bi vnesel listo prepovedanih strani. Da otroci ne bi mogli z tablicami in telefoni dostopati do teh neželjenih strani. Sem nekaj gledal v nastavitvah routerja, vendar nisem našel te možnosti.
Router je TP-Link 941ND. Verjetno je vmesnik isti kot pri 1041ND.
Good Guy ::
za blokado na računalniku uporabi Internet access Controler (od Gearboxa). Free zadeva ki ima lepo število funkcij(od blokade, spletnih strani, blokade servisov,blokade programov....)
za blokado iz ruterja->access control->target->izbereš domain in to je to
http://goo.gl/7ItKpU
Naj računalnik dela za vas^^
clancy ::
Hvala, te možnosti sploh nisem pogledal, sem bolj šaril pod Parental Control.
Sem sedaj pod target izbral domain in vpisal naslov strani, sejval, restartal ruter, ampak ne zgodi se nič. Stran se še vedno normalno odpira, tudi če obkljukam "Enable intenet access control". Any idea?
levaky ::
Lahko si ogledaš tudi OpenDNS. Nastaviš njihov DNS v router in preko weba na openDNS nadzorni plošči nastavljaš, katere domene ne delujejo...
Nikoli sicer probal, ampak baje da to dela:)
MAtej
CaqKa ::
klihk je izjavil:
chrome:download ni spletna stran ampak je stran znotraj chromea.
če ne želiš da je tam kaj na njej, moreš zbrisat zgodovino downloadov.
sendspace bi moralo normalno blokirat...
clancy ::
Good Guy je izjavil:
Končno mi je uspelo s pomočjo tega vodiča:
http://www.tp-link.com/en/article/?faqi...
Je potrebno iti še naprej in par stvari vklopiti. Precej komplicirano za začetnika.
Hvala za pomoč ;).
Zakaj mi ne odpre samo ene določene strani?
Oddelek: Omrežja in internet
288460 (4500) BorutK-73
Bloiranje spletnih strani
196262 (5254) SeMiNeSanja
Shranjevanje v Hosts file
82521 (2459) Mendex
ne dovoli mi namestiti antivirusnega programa
134781 (4509) k4vz0024
Obstaja program ki onemogoči določeno spletno stran?
Oddelek: Programska oprema
152105 (1982) #000000
