Forum » Programska oprema » netPPBM install problem-pomoč
boss-tech ::
prosim za pomoč. mam php-nuke in not galerijo. ta zahteva netpbm in jst sm ga snel z neta- sm ne vem kok ga nej inštaliram- tam piše nej dam sam pot do tega binarne mape pa je- kok to- če mi ne prime
The filesystem path to your NetPBM binaries? tu morn dat pot
$gallery->app->pnmDir = "C:\AppS\www\stran\page2\netpbm";
Error: I can't find NetPBM at the location you provided. Gallery prefers NetPBM version 9.9 and up.
You can install the entire NetPBM package from NetPBM on SourceForge(http://sourceforge.net/projects/netpbm) or you can install just the binaries Gallery needs from Gallery on SourceForge. (http://sourceforge.net/projects/gallery)
Note: You can install the binaries from the Gallery site even if you don't have root access on your box! If Gallery does not have the specific binaries for your hardware/software combination post a request On the Gallery website and we'll build them for you.
| ! | [C++] PovezaveOddelek: Programiranje | 64634 (3207) | DamijanD |
| » | Mac OS Snow Leopard na PCOddelek: Operacijski sistemi | 5617 (4165) | Gray_Warden_ |
| » | GAIM 2.0.0 prihaja (strani: 1 2 )Oddelek: Novice / Ostala programska oprema | 8636 (7063) | B-D_ |
| » | Anti SPAM filterOddelek: Omrežja in internet | 1564 (1528) | pivmik |
| » | Web GalerijaOddelek: Izdelava spletišč | 2382 (2129) | Cuoresportivo |
