netPPBM install problem-pomoč
boss-tech ::
prosim za pomoč. mam php-nuke in not galerijo. ta zahteva netpbm in jst sm ga snel z neta- sm ne vem kok ga nej inštaliram- tam piše nej dam sam pot do tega binarne mape pa je- kok to- če mi ne prime
The filesystem path to your NetPBM binaries? tu morn dat pot
$gallery->app->pnmDir = "C:\AppS\www\stran\page2\netpbm";
Error: I can't find NetPBM at the location you provided. Gallery prefers NetPBM version 9.9 and up.
You can install the entire NetPBM package from NetPBM on SourceForge(http://sourceforge.net/projects/netpbm) or you can install just the binaries Gallery needs from Gallery on SourceForge. (http://sourceforge.net/projects/gallery)
Note: You can install the binaries from the Gallery site even if you don't have root access on your box! If Gallery does not have the specific binaries for your hardware/software combination post a request On the Gallery website and we'll build them for you.
darkolord ::
Mogoče morš dat relativno pot?
[C++] Povezave
Oddelek: Programiranje
4264747 (3320) DamijanD
Mac OS Snow Leopard na PC
Oddelek: Operacijski sistemi
485668 (4216) Gray_Warden_
GAIM 2.0.0 prihaja (strani: 1 2 )
718684 (7111) B-D_
Anti SPAM filter
Oddelek: Omrežja in internet
61575 (1539) pivmik
Web Galerija
Oddelek: Izdelava spletišč
212405 (2152) Cuoresportivo
