Nero v5.5.5.1 Out!
Nero v5.5.5.1 Out!
Tr0n ::
Nero 5.5.5.1 is the offical Nero version for Windows XP
Changes from Nero 5.5.4.0 -> 5.5.5.1
Bug Fixes:
The boot cd property page will now also allow boot image template volumes,that are larger than 600MB, if another destination medium than CD is selected. For example DVDs might pretty well contain boot data of 4GB, that the old dialog just did not allow to select.
Fixed overburning in WaitCD dialog (would eject CD instead of asking the user for overburning, which would only happen once the CD was inserted a second time)
When IMAPI disabling failed, try to switch to other running Nero.
The content of the SCANDATA.DAT file was not written on SVCD.
Fix delete char bug when editing file name in the File Browser
Fix minimized compilation bug when using "show desktop".
Fixed problem of reading CD-Extra in some CD-ROM drives (data track not readable).
The database dialog did not display CD entries with identical CDDB hash values correctly. Instead the same entry was displayed several times.
The progress during the cache phase works smoother.
Fix main windows flickering during resize.
BurnStatus colors repaint correctly on different desktop-settings while burning
Fix invisible column text in High Contrast color setting.
Prevent the user from creating audio track smaller than 4 seconds by splitting a track
DVD-R/RW drive support now much improved
Fixed a crash at the end of CD autodetection
New:
Added many new recorders.
DAO mode is now present as default and active in CD Copy dialog and it is not changeable
Added new 'buffer underrun preventing features': Power-Burn, BURN-Free and SafeLink
Added IMAPI lock for Windows XP
Several improvements to comply with Windows XP Logo
http://www.nero.com/en/download.htm
Navali narod :).
Valve & STEAM & On-Line gaming (strani: 1 2 )
Oddelek: Igre
719935 (8357) Tilen
Azureus 2.2.0.0 zunaj
295307 (5307) zile
nero overburning
111409 (1190) Pisk
Problemi z CDRW Teac 516EB in nerotom v XP-jih!
101286 (1162) Paramedic
Nero + teacW516EB
91271 (1184) PupaSuchen
