Forum » Programiranje » Še en mysql problem [ERROR] Fatal error: Can't open privilege tables: Table 'mysql.host' doesn't exist
_blind_ ::
ZIvjo imam naslednji problem pri zagonu mysql serverja
blind:/usr/local/mysql/bin# ./mysqld_safe
Starting mysqld daemon with databases from /usr/local/mysql/data
STOPPING server from pid file /usr/local/mysql/data/blind.pid
050901 14:11:17 mysqld ended
pol ko pogledam v /usr/local/mysql/data/blind.err
050901 14:13:21 mysqld started
050901 14:13:21 InnoDB: Database was not shut down normally!
InnoDB: Starting crash recovery.
InnoDB: Reading tablespace information from the .ibd files...
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer...
050901 14:13:21 InnoDB: Starting log scan based on checkpoint at
InnoDB: log sequence number 0 43634.
InnoDB: Doing recovery: scanned up to log sequence number 0 43634
050901 14:13:21 InnoDB: Flushing modified pages from the buffer pool...
050901 14:13:21 InnoDB: Started; log sequence number 0 43634
050901 14:13:21 [ERROR] /usr/local/mysql/libexec/mysqld: Can't find file: './mysql/host.frm' (errno: 13)
050901 14:13:21 [ERROR] Fatal error: Can't open privilege tables: Can't find file: './mysql/host.frm' (errno: 13)
050901 14:13:21 mysqld ended
InnoDB: buffer...
I like SkA
- premaknilo iz Pomoč in nasveti: bastadu ()
Kami ::
Zaženi ukaz mysql_install_db (da naredi tabele) oz daj celo pot do binary, če tako ne bo delalo
| » | XAMPP - mysqlOddelek: Programiranje | 1135 (1023) | illion |
| » | problem pri sprembi root gesla v MySQL v UbuntuOddelek: Pomoč in nasveti | 1730 (1310) | killa bee |
| » | MySQL RelacijeOddelek: Izdelava spletišč | 1522 (1288) | mkos2 |
| » | MySql Vprasanje - problem dupliciranih kljucevOddelek: Izdelava spletišč | 1904 (1726) | KernelPanic |
| » | Backup podatkovnih bazOddelek: Omrežja in internet | 2592 (2220) | jype |
