The SIME 2 Kode
The SIME 2 Kode
Crazy Frog ::
Jaz vem some za eno kodo.
KODA je : MOTHERLODE (da 50,000 kesha)
Ketere kode pa
vi poznate.
No če mi boste katero povedali
še zraven napišite kaj
pomeni.
LP Jan
kilergas ::
Ce bi uporabil google in malo pameti bi dobil marsikatero kodo.
Kaching - 1000
Motherlode - 50,000
moveobjects on - move objects on
moveobjects off - move objects off
aging-on - your sims get old
aging-off - your sims dont get old
Misc. Codes
Press CTRL + SHIFT + C to access the cheat window, then enter the following:
Set to false to remove removes shadows on objects outside house boolprop objectShadows (True/False)
Set to false to remove shadows on objects inside house boolProp guob (True/False)
Set to true and walls will no longer cut away from selected Sim boolprop renderSelectedSimLevel (True/False)
Set to true to see the path where the selected Sim walks to boolProp displayPaths (True/False)
Set to true and blocks appear on Sims faces and on parts where Sims look at boolprop displayLookAtBoxes (True/False)
Toggle shadows on/off for Sims boolProp simShadows (True/False)
In neighborhood, shows filename of house when lot is highlighted boolprop ShowLotPackageFilename (True/False)
Set to true and cars will have more detail in neighborhood boolprop carsCompact (True/False)
Set to true to show lot information boolprop lotInfoAdvancedMode (True/False)
Set to false to place floor tiles outside lot boolprop locktiles (True/False)
Set to false to remove removes water (ponds) from lots boolprop lotWater (True/False)
Set to false to remove floorpainting on lot boolprop lotTerrainPaints (True/False)
Set to false to remove props like rocks and towers from neighborhood boolprop displayNeighborhoodProps (True/False)
Set to true to light up objects continuously instead of only when used boolprop allObjectLightsOn (True/False)
Set to false to remove roads from neighborhood boolprop displayNeighborhoodRoads (True/False)
Set to false to removes trees/plants from neighborhood boolprop displayNeighborhoodFlora (True/False)
Set to false to remove water from neighborhood boolprop displayNeighborhoodWater (True/False)
Set to false to removes house graphics from neighborhood boolprop displayLotImposters (True/False)
Set to false to remove bridges from neighborhood. boolprop displayNeighborhoodRoadsWithModel (True/False)
Set to false and lots will not light up when highlighted in neighborhood boolprop lotTerrainLighting (True/False)
increases game performance but lowers graphics vsync (on/off)
moves objects and deletes you couldnt before moveobjects (on/off)
lets you know if theres a patch autopatch (on/off)
get 1000 cash kaching
list cheats help -all
expands or contracts cheat window expand
closes cheat window exit
Puts the game in slow motion. Enter any number that 0 through 8 (0=fastest and 8=slowest) slowmotion
makes your sims larger or smaller StretchSkeleton
Disables the ability to change elevation of floor tiles. boolprop constrainFloorElevation true
Allows you to change elevation of floor tiles. boolprop constrainFloorElevation false
turn on aging aging on
turn off aging aging off
50,000 simoleans motherlode
turns off facial bounding limitations. It prevents the normal corrections the game will make for two parents with very different facial structures. faceBlendLimits (on/off)
You can invite more people to your parties. intProp maxNumOfVisitingSims 8
You can place objects outside the grid. boolProp snapObjectsToGrid true/false
Takes off censoring intprop censorgridsize 0
Clears all cheat codes on the screen, but codes are still in effect. clear
You can tell what social reaction will happen before you do it social_debug
Neighborhood Only Cheats
Bring up cheat window by pressing Ctrl + Shift + C
At neighborhood view only, removes every Sim from the neighborhood. deleteAllCharacters
Only for use in neighborhood view, toggles between the two terrain types. TerrainType (desert/temperate)
More Codes
Press Ctrl + Shift + C to access the console.Some cheats require you enter the Postprocessing cheat.
Make you set the game speed. (# = 0 to 8, 0 is normal) slowMotion #
Turns Postprocessing on. boolProp enablePostProcessing true
Turns Postprocessing off. boolProp enablePostProcessing false
Sitcom flashback blur effect (# = 0.0 to 1.0) (require postprocessing on) bloom rgb #
Blurry bits at the edge of the screen. (# = 0.0 to 1.0) (require postprocessing on) vignette # # #
Makes the screen grainy. (# = 0.0 to 1.0) (require postprocessing on) filmGrain #
Adds a letterbox effect to the view. (# = 0.0 to 0.4) (require postprocessing on) letterBox #
Other Parameters
Add these to the shortcut's parameters for other helpful things. Some have code counterparts.
Windowed Mode -w
Start with desired resolution (in pixels). -r[width]x[height]
Fullscreen Mode -f
Disables sound -nosound
Debug Mode
Open the cheat menu by pressing Ctrl + Shift + C, then entering the following:boolProp testingCheatsEnabled trueWhile in Create-a-Sim, press Shift + N before creating your first sim to enable skintones, clothes, and hairstles that would normally be used only by NPCs. Press Shift + M to disable it.While in Live mode, Shift + Click on a sim to bring up the debug menu.
Sims 2 Glitches
Disgusting Faces
There is a glitch in character creation mode where you can make absolutely disgusting faces. The trick is that if you go to the face designing area and you select a face part such as the eyes and max out all the sliders one way or the other, then go to a different face part and select one of the PREDESIGNED parts, and then come back to the eyes, the sliders will have reset in the middle, but the eyes will still look the same. This works for all of the face adjusting tabs. Exploiting this, you can make eyes the size of dinner plates, cheekbones 4 feet long, and a HUMUNGOUS nose, to name a few.
free bookcase skills
Buy a bookcase, then have your sim start to study. Interrupt the action so that the book it placed on the ground, then simply sell the bookcase. The book can then do everything the bookcase could have done for free.
Sims 2 Secrets
Custom Painting
To decorate your house with custom artwork, first your sim must have a creativity level of 5 and be able to paint a still life. Have your sim paint and a frame will appear that you can center on whatever you want to paint. If you want to paint a picture of something outside the Sims 2 game, just press C anywhere at this time. This will pause the game. Use Alt + Tab to exit the game, then open a picture program such as Paint and open the snapshot you just took, it will usually be in the folder: C:\My Documents\EA\Sims2\Storytelling\Snapshot.bmp Then, you also have to open the picture you want to have in your game. If your picture is too large resize it so it will fit in the original snapshot from the game. Copy your custom picture on to your snapshot from the game, then save the picture. Use Alt + Tab to get back to your game and your sim will start painting your own custom picture. Using this trick you can put pictures of your friends or family, web pictures, or anything else in your Sims 2 game.
Listen To Mp3's On Sim Radio
First get whatever Mp3's you want to put on the game, then open up MyDocuments/EAGames/TheSims2/Music/(whatever RadioStation you want your song on). Then, Drag your MP3 into the folder. Now, start Sims 2 then go to options menu, then music settings, then the Radio Station, then pick witch songs you want the radio to play. You can now listen to your favorite songs in your Sims game.
Use your own videos for the TV
It's possible to watch your own videos on the Sim-TV. You must put the video you want into My Documents\EA Games\The Sims 2\Movies\Broadcast (the TV sender you want). If you then turn on the TV in the game you can watch it! The video must be .avi-clips and the clips shouldn't be larger then 128x128 pixel also it shouldn't have more then 15 frames per second.
Listen to music included with game
First, open your The Sims 2/TSData/Res/Sound directory. The names of radio stations, plus a few more including Build mode and Neighborhood music should be here in *.package files. Copy and paste the file corresponding to whatever you want to listen to into another folder. Rename it from [File].package to [File].mp3. You can now listen to the sound/songs included in the file.
For Poor Families
The trick is that no matter how many times you use an object, if you sell it in the same day, you can get all your money back. So if your Sim is poor and needs body points or something, buy a body machine and keep selling it back to refund all your money.
Lenoba
  • spremenilo: kilergas ()
Crazy Frog ::
Tanx!:D
Unreal Tournament III (strani: 1 2 3 4 )
Oddelek: Igre
18417309 (4964) kuglvinkl
Kako pohitriti FireFox
105062 (4773) Bakunin
Gentoo Xorg.conf LCD - sistem se obesi
Oddelek: Operacijski sistemi
362106 (1899) Mr.B
RA2 preko dveh modemov?!
Oddelek: Igre
101791 (1686) bastadu
