Forum » Strojna oprema » Zanimiva ideja...
Zanimiva ideja...
igor0203 ::
vendar ne vem kako se bo obnesla... KLIK
je pa to pomoje ful v redu rešitev za tiste k bi radi na nF4 prešaltal pa majo grafično ala gf6800gt al pa kej podobnga...
- spremenil: igor0203 ()
FX5200 Series
MX4000 Series
FX5700LE Series
AGP6200 Series
FX5700 Series
FX5900XT Series
6800 Series
Kak lahko gre gor če so nakatere grafične tak velike. Meni nič nebo pomagalo, ker nepodpira X800.
MX4000 Series
FX5700LE Series
AGP6200 Series
FX5700 Series
FX5900XT Series
6800 Series
overheat ::
sam če svojo agp grafično vtakneš na ta pretvornik za pci 16x ni šans pol da namonteraš grafično v bilo kero ohišje.Ideja ni slaba sam ima dost malenkosti,Če sploh deluje tko kokr je treba?
hello :)
- spremenil: overheat ()
tiborrr ::
Za Radeone ne bo, ker Albatron ne stanca ATi kartic.
Good Guy ::
offtopic: kako pa sploh pritrdiš tako grafo ki jo maš v pretvorniku
http://goo.gl/7ItKpU
Naj računalnik dela za vas^^
profii ::
še eno glupo prašanje: kako pa prikopiš enkran na tako grafo?? (ki ima konektor not v ohišju)
cole-22 ::
Now we know more about it. The converter is only compatible with the following AGP Video cards from NVIDIA: MX4000, FX5200, FX5700, FX5700LE, GeForce 6800, GeForce 6200. Since the card uses a bridge chip, performance is degraded a bit. In most cases not much, but sometimes up to 10%.Installation requires that you remove the AGP card's slot bracket and screw it to the bracket of the ATOP. The D-Sub output on the ATOP overrides any D-Sub ouput on the video card. Other outputs like DVI and TV-Out remain usable on the AGP card. The ATOP card will be initially bundled with the AGP6200A VGA card. In the July 2005 time frame, the ATOP card will be available as a separate product.
- spremenil: cole-22 ()
| » | Katero grafično ste že imeli ? (strani: 1 2 3 4 )Oddelek: Strojna oprema | 24434 (17499) | Janac |
| » | PCI (ne PCI-e) grafična kartica vsaj FX5200 z video izhodom - kje bi to pri nas dobilOddelek: Kaj kupiti | 2425 (2278) | celk |
| » | NASA World WindOddelek: Programska oprema | 3090 (3008) | Person |
| » | RADEON 9550Oddelek: Kaj kupiti | 2861 (1928) | boštjan |
| » | Katero graf. kartico za 25.000 sit (strani: 1 2 )Oddelek: Kaj kupiti | 6060 (5225) | Jaffa |
