Genius Soundmaker Value 5.1
WtFlol ::
Ravnokar sem formatiral disk in WIN XP na novo naložil. Pojavi pa se problem, ker ne morem najti CDja z drajverji za zgoraj omenjeno zvočno kartico.
Na uradni strani imajo probleme (tako da driverjev ne morem DL), sem jih pa našel na googlu vendar jih nevem namestiti (drajverji na cd-ju so imeli setup.exe, tu pa je treba nekaj ročno drk*t.) :(
PCI audio NT4.0 Drivers Note
* For Windows NT 4.0 drivers installation
1. Press "Start" button.
2. Move highlight bar to "Settings" and select "Control Panel".
3. Double click on "Multimedia" icon.
4. Select "Devices" page.
5. Press "Add..." button.
6. Select item "Unlisted or Updated Driver" in "List of Drivers" list box.
7. Specfy path of PCI audio NT drivers.(ex: D:\SM Value 5.1\NT40\drv)
8. The dialog show item that fit your audio device, please press "OK" button.
9. Choose proper I/O or "OK" button for default setting.
10. Please restat Windows NT system.
Mogoče kak step-by-step guide? (Multimedia icon, device, add, krneki.. sem se zgubu)
Hvala že vnaprej za pomoč.
100%Cpe + ostalo
112771 (2441) postar_si
Najdite mi driverje za graficno, pls
121591 (1445) Dr_M
Logitech MouseWare bug (?)
272584 (2180) Swiwer
Kako popolnoma zbrisat stare driverje
71375 (1228) kita103
Pomoč z HPT370 UDMA/ATA 100 RAID Controller
52951 (2858) Nocko
