[java] Serialiacija in posiljanje preko mreze
alum ::
Poskusam serializirati objekt, ki vsebuje ImageIcon (sliko) in ime. Vendar mi javi Exception, s katerim si res neznam pomagat...kaj delam narobe?
EXCEPTION:
java.net.SocketException: Software caused connection abort: socket write error
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(Unknown Source)
at java.net.SocketOutputStream.write(Unknown Source)
at java.io.ObjectOutputStream$BlockDataOutputStream.drain(Unknown Source)
at java.io.ObjectOutputStream$BlockDataOutputStream.setBlockDataMode(Unknown Source)
at java.io.ObjectOutputStream.writeNonProxyDesc(Unknown Source)
at java.io.ObjectOutputStream.writeClassDesc(Unknown Source)
at java.io.ObjectOutputStream.writeOrdinaryObject(Unknown Source)
at java.io.ObjectOutputStream.writeObject0(Unknown Source)
at java.io.ObjectOutputStream.writeFatalException(Unknown Source)
at java.io.ObjectOutputStream.writeObject(Unknown Source)
at test.main(test.java:24)
import javax.swing.*;
import java.io.*;
import java.net.*;
public class test{
	public static void main(String arg[]) throws Exception{
		ImageIcon i = new ImageIcon( "test.jpg" );
		User u = new User( "bla", i );
		User n = null;
		if(arg.length == 1)
			Socket s = new Socket( "localhost", 5555 );
			try
				OutputStream os = s.getOutputStream();
				ObjectOutputStream oos = new ObjectOutputStream( os );
				oos.writeObject( u );
				oos.flush();
				oos.close();
				InputStream is = s.getInputStream();
				ObjectInputStream ois = new ObjectInputStream( is );
				n = (User)ois.readObject();
				ois.close();
				System.out.println( n );
			catch(Exception e){ e.printStackTrace(); }
		else
			ServerSocket ss = new ServerSocket( 5555 );
			try
				Socket s = ss.accept();
				oos.flush();
				oos.close();
				ois.close();
			catch(Exception e){}
verjetno je napaka v zaporedju ustvarjanja input in output streama, ali pa je napaka v samem ustvarjanju streama...ce v obeh blokih postavim input stream pred output se program neha odzivat...
DCER ::
Nisem prepričan, ampak bi rekel da zato ker zapreš streame. Lahko pa da sem čisto mimo vrezal :D
alum ::
ja nisi mimo vrezal:)
problem je bil, ker sem prehitro zapiral streame:)
[JAVA] HTTPS client
Oddelek: Programiranje
173694 (2424) peterv6i
[Android] Nov tip shranjevanja slike
142725 (1849) urosz
[Java] Multi Client chat server
263172 (2443) javaMaster
[Java] pošiljanje slik prek porta
51541 (1460) xlarge
Kako pošiljanje datotek v JAVI.
142243 (2114) kopernik
