Forum » Operacijski sistemi » Suse 9.3 - Kinternet vprašanje
suselinux2 ::
V suse 9.3 se mi večkrat zgodi, da se mi kinternet odklopi ( samodejno prkine povezavo) z internetom. kje naj poiščem napako oz. vzrok?
hvala lepa in Lp
marko
hvala lepa in Lp
marko
abba
suselinux2 ::
Kaj je to kinternet !? Jest poznam samo internet
Vse kar treba narediti je prebrati readme.txt !
lepo prosim, ne dajajj neumnih komentarjev....
Torej: Kinternet je orodje za povezavo v internet pri suse linuxu.
Lp in brez zamere
Lp in brez zamere
abba
64202 ::
Najprej poglej, kaj rece kinternet -> view log. Ce tam ni nic pametnega, poglej se v /var/log/messages kot root, pomembne so vrstice s pppd in pppoe. Verjetno pise, zakaj se je povezava podrla.
I am NaN, I am a free man!
suselinux2 ::
Status is: connected
pppd[0]: Terminating connection due to lack of activity.
The connection was idle and shut down.
Status is: disconnecting
pppd[0]: Connect time 59.5 minutes.
pppd[0]: Sent 969148 bytes, received 31304759 bytes.
pppd[0]: restoring old default route to eth0 [192..... ..]
pppd[0]: Couldn't increase MTU to 1500
pppd[0]: Couldn't increase MRU to 1500
pppd[0]: Connection terminated.
pppd[0]: Script /etc/ppp/ip-down finished (pid 10823), status = 0x0
Status is: disconnected
pppd[0] died: Link idle: Idle Seconds reached. (exit code 12)
Kaj naj naredim?
Kaj naj naredim?
abba
64202 ::
Hja, pise da je bil idle timeout. Pojdi v dsl configuration pa povecaj cas...
kriko1 ::
Pojti v Yast, izberi pod network DSL connections, change..., in nekje pod nastavitvami daj timeout na 0.
| » | Ubuntu in adslOddelek: Operacijski sistemi | 2767 (2483) | gregs |
| » | PPP: Input/output errorOddelek: Omrežja in internet | 1950 (1788) | b |
| » | [pppoe povezava] Couldn't increase MRU/MTU to 1500Oddelek: Operacijski sistemi | 2109 (1963) | NeOman |
| » | ADSL modem hangupOddelek: Pomoč in nasveti | 1601 (1465) | 3LeR. |
| » | adsl+debianOddelek: Omrežja in internet | 1908 (1520) | Gandalfar |
