Forum » Strojna oprema » Dolžina kabla pri WEB kameri
Arrivo ::
Koliko je lahko dolg kabel za web kamero brez dodatnega napajanja, ki bi jo priklopil na USB ?
Hvala za pomoč .
Hvala za pomoč .
Ja ja to drži !!!
Gwanaroth ::
Q: What is the max. length of a USB 2.0 cable?
A: 5m. However, if you cascade 5 hubs with 5m USB cables, this will allow you to connect a device 30m away.
Q: I saw one cable supplier making USB A-B with the length of 10 and 20 meters per piece. So does it means these 2 cables or any cables with the length over than 5meters won't work or get full use of it? Pls advice. Thanks in advance.
A: It won't work. The rules are the rules - 5M max.
Q: Does the USB2.0 transfer rate become slower for a longer cable?
Let say a USB2.0 device reach 480Mbps in 1 meter cable, can it reach 480Mbps too in a 5 meter cable?
A: No - it's the same anywhere within the acceptable range envelope.
Skopirano iz http://www.everythingusb.com/
| » | HDMI kabel (strani: 1 2 )Oddelek: Kaj kupiti | 14632 (9952) | showsover |
| » | Thunderbolt vs USB Type-COddelek: Pomoč in nasveti | 2205 (1690) | krepki |
| » | USB 1.1 ali 2.0 ?Oddelek: Strojna oprema | 1397 (1173) | playboy |
| » | Zakaj ISDN, če hočem ADSL ???Oddelek: Omrežja in internet | 2185 (2033) | Bx |
| » | Zvok z vecih cd-romov?Oddelek: Zvok in slika | 2562 (2333) | Justy |
