Katero DDR plato?
Katero DDR plato?
Sergio ::
no, ko smo se odlocili, da je SDR plata najboljsa Iwillova KK266-R (potrjeno), vas sprasujem... katero ddr plato, da bo highly OCable, podpirala tbirde 1.4 GHz, imela RAID ter pustila visoko navitje mojega sistema?
Tako grem jaz, tako gre vsak, kdor čuti cilj v daljavi:
če usoda ustavi mu korak,
on se ji zoperstavi.
VASkO ::
malo se potrpi na Sis735 in Ali Magik1 (B1 revizija), ki sta dosti boljsa od AMD760 in VIA KT266 DDR cipovij (in tudi cenejsa).
Pisk ::
a ni lamersko odpirat identicno temo??? malenkost nizje poglej...
sis pa se nikoli ni naredil nic spodobnega in najbrz bo ostalo tako. sis=shit!
frudi ::
a ni lamersko šimfat čipovje, ki ga očitno sploh ne poznaš? malo teste poglej...
Pisk pa še nikoli ni napisal nič spodobnega in najbrž bo ostalo tako. Pisk = .....!
zile ::
Abit released that their new motherboards will have several new features.
The new features include, but are not limited to, onboard debugging LEDs, voltage tweaking up to 2.2 V, and "Overclocking Strips," which are placed on the back of the board to increase stability while overclocking.
Abit it introducing these new, overclocking based features in an effort to stay put as the number one motherboard manufacturer when it comes to tweaking and overclocking ability. Since other manufacturers are including more and more features aimed at overclocking and tweaking themselves, Abit has to work harder to keep up.
Torej, upam da bo mela kšen nForce al pa SiS735 čipovje gor.
Vir tukaj
morphling1 ::
Cool, ni kaj. Bom se cakal z ddr plato ,tko in tko mi moja KT7a raid dela skor tako hitro kot vecina ddr plat.
Yohan del Sud ::
Ej Sergo, samo ena malenkost. Sem včer reku da dobiš dodaten USB kabl zraven. No, ga ne. Sem se pol spomnu sem ga dobil OEM v kišti skupi s tastaro plato. Sam tolko.
Pretorijanec ::
Sergio: odvisno od denarja. Če ne nameravaš čakat na SiS735 ali nForce, kupi Gigabyte GA-7DXR (70k SIT) ali Epox 8K7A+.
Daishi ::
Al pa pridi do nas po GA 7DXR 330.000 ITL !:D
SIS pa je zgodovinsko zelo priznana znamka. "SIS=shit" definitivno ne velja, sami si izdelujejo cipovje, sami delajo svoje nacrte in so bili med najvecjimi inovatorji kar se tice cache kontrolerjev. Pac so dolga leta cepeli v temi in se skoncentrirali na OEM pogodbe ( SIS cipi so v ogromno brand racunalnikih). Dejstvo, da niso sodelovali v bojih za najhitrejsi podporni cip ne pomeni obvezno, da tega ne znajo, ampak lahko le, da jih retail ni zanimal. ( opazite preteklik ? ) :D
Uros - Essedi Gorica
ICQ No.: 56362066
Sergio ::
Daishi: če si resen glede tega, da bi mi kej zrihtal (a delaš v Essedi?), potem povej cene za tbird 1400, 2x256 MB DDR CAS2 pomnilnika ter Epoxovo platko. :D
Daishi ::
Epox nimamo ! :'(
Za ostale cene te moram pa zal prosit, da v sredo pogledas na stran Essedi in si pod "Prodotti" (izelki) pogledas "Memorie" (spomini), "Processori" ( procesorji) in "Piastre Madri" (maticne plosce).
Pricakujem radikalno nove cene za spomine in procesorje !
Smo pa dobili KG7 Raid !!! >:D>:D>:D
ICQ No.: 56362066
Daishi ::
So mi dali nove cene za proce 5 min nazaj !
Athlon 1400 340.000 ITL + IVA !>:D
Sam se Tyan more mal spustit ceno ! >:D>:D
ICQ No.: 56362066
hatch ::
maticna plata za AMDje sploh nebi smela biti vprasanje
v mlacomu -> ELITE K7S5A SIS735 DDR +SB 21.500 25.585
Je trenutno najhitrejsa in tudi najcenejsa maticna plosca za AMDje.
Justy ::
daishi, daj ce si ponosan slovenac:D zraven pisi se valuto lira/sit, ker ce tolko slo folka tam kopuje bi se to ze spodoblo;)
Daishi ::
OK ! Pomnozis z 0,114 ! ( 340.000 ITL= 37.400 SIT )
ICQ No.: 56362066
Sergio ::
Daishi, pomnozi mi tole:
AMD Thunderbird 1400
Abit KG7 RAID
256 MB PC2400 CAS2 Corsair RAM
V tolarjih. Z davkom, plz ;)
Abit KG7 ali KR7 ?
321719 (1352) kuglvinkl
DAISHIIIII
111336 (1163) totimato
DDR Plata
271964 (1485) Milko
Plata Socket A - 266 DDR?
131544 (1290) Daishi
Kero DDR palto?
251485 (1247) asPeteR
