tezava pri kompajlanju, ati gonilnikih in sumnikih
motorka_m ::
1.) Uporabljam Suse 9.2, ko napisem v konzoli ./configure mi napise tole
linux:~/Desktop/dc-qt-0.1.2> ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for uname... Linux
checking for Qt moc...
Qt's moc not found! If you have installed Qt in an
unusual place, please use the "--with-qt-moc=" option
rad bi dobil (ce sploh obstaja) cel paket teh knjiznic in ostalih stvari da bom lahko normalno kompajlov.
2.) kako instalerati gonilnike za ati radeon 9200, gonilke sem si downlowdow iz njihove strani.
3.)A se da nastimat sumnike v suse-u?
Hvala
Kje so programi
Oddelek: Operacijski sistemi
71737 (1536) madness
Igre za linux
Oddelek: Igre
232250 (1831) NoUse4AName
namestitev KDE
Oddelek: Programiranje
81684 (1526) Ezekiel
Katera dist LINUXA
472752 (2090) mte
Kako instalirat v linux?
51229 (1185) BigWhale
