Ne pokaze namizja
Ne pokaze namizja
robert22 ::
Pozdrav!
Zanima me ce mi lahko pomagate pri naslednjem problemu:
pri prijavi kot uporabnik administrator se na monitorju pokaze ura in potem pc caka. To se zgodi takrat ko nisem prikljucen na mrezo, če pa sem prikljucen na mrezo se pc normalno nalozi.
Pri ostalih uporabnikih teh tezav nimam.
LP Robert
in vendar se vrti
robert22 ::
Pozdrav!
Ze urejeno
Blank Desktop or No Desktop After Logon to Windows 2000
Symptom: After logon to W2K, you may see a blank desktop or no desktop. If you use CTRL+ALT+DELETE to start Task Manager, you may find that Explorer.exe is not listed in the list of running tasks or processes. Starting a new instance of Explorer.exe does not resolve the issue.
Resolution: open Task Manager>File>New Task (Run). Type cmd.exe, and then press ENTER. If necessary, change to the %SystemRoot% folder. This is typically the Winnt or Windows folder. Rename the Shdocvw.dll file by typing ren shdocvw.dll shdocvw.old. Restart the computer.
Note: Other older files that may cause problems with Explorer.exe or the shell if they are located in %SystemRoot% folder: Browseui.dll, Comctl32.dll, Comdlg32.dll, Mlang.dll, Ole32.dll, Oleaut32.dll, Shdocvw.dll, Shell32.dll, Shlwapi.dll, Urlmon.dll, Wininet.dll, Setupapi.dll.
LP Robert
in vendar se vrti
analiza hijack this
172498 (2278) klaudija
Problem z odpiranjem spletnih strani, setup datotekami...
254522 (4311) Tac20
Ikone v win XP izginile po uporabi programa Spybot Search & Destroy. Kako dobiti ikon
52679 (2635) riba43
Kako narediti redirect, če uporabnik vpiše napačno ime .html
Oddelek: Izdelava spletišč
161770 (1671) darh
Obešanje explorer.exe
52099 (2025) lojze_car
