kako daleč nese LAN
kako daleč nese LAN
radiator ::
Kako daleč lahko vlečem UTP kabel da bo še delalo?
5er--> ::
Gigabit Ethernet (over copper), 1000baseT
Speed:1000 Mbps
Max Len:100 Meters
Cable:UTP, RJ-45 connectors
Fast Ethernet, 100baseT
Speed:100 Mbps
Max Len:100 Meters
Twisted Pair Ethernet, 10baseT
Speed:10 Mbps
Max Len:100 Meters
Thin Ethernet , 10 base 2
Speed:10 Mbps
Max Len:185 Meters
Cable:RG-58 type coax, 50 ohm impedance
Thick Ethernet, 10 base 5
Speed:10 Mbps
Max Len:500 Meters
CCfly ::
CAT5: 100m (100 MBit)
CAT5e: 350m (1Gbit)
CAT6: 100m (1 GBit)
"My goodness, we forgot generics!" -- Danny Kalev
radiator ::
Hvala....
Saj vem da bi si lahko sam poiskal pa se mi ni dalo :)
bastadu ::
A ta " CAT5e: 350m (1Gbit)" je odvisen samo od kabla, al morajo biti tudi kakšne posebne 1Gbit mrežne?
Tale 350m tudi mene malo bega, ja. Sploh ker je na slabsem kablu.
CCfly ::
http://searchnetworking.techtarget.com/sDefinition/0,,sid7_gci211752,00.html
Pri 100MBit omrežju je omejitev 205m med dvema točkama ne glede na kabel. Možno je da so se pri Wikipedii zmotili za CAT5e. Računaj na 100m.
... the standart specifies that UTP cat5e cables can be used to up to 100m. FTP cables can be used to up to 150m and STP cables up to 200m.
From my personal experience I can tell you that using cables manufactured by a good brand will extend those ranges with at least 25%.
I work for a company that is a Belden distributor, and I can assure you that I personally tested UTP cat5e Belden cables to 140m
So, your 80m are no problem, not even if you'll use some low quality cable, however I don't recommend it.
Kateri kabel za omrežje v hiši? utp/ftp/stp/sftp?
Oddelek: Omrežja in internet
2812723 (10399) antonija
Brezžična povezava ali UTP kabel
4420121 (19033) Bimbo11111
Kategorije ožičenja Ethernet
91405 (1241) iges
Dolga UTP kabel med dvema switch-ema!
92049 (1801) yapka
ADSL + 3 rac v omrezju, kako ?
402870 (2341) klemen338
