Forum » Programska oprema » [Moj programček] Xtra Windows Stability
RejZoR ::
Xtra Windows Stability was designed to enhance Windows stability and to minimize loss of your work on Windows crash. This is done by forcing Windows to run its subsystems as separate processes.
These subsystems are: Desktop, Explorer (Folders) and Internet Explorer.
Using these enhancements can slightly increase memory usage while running several folders or Internet Explorer Windows. If you run only few of them, there should be no difference.
Xtra Windows Stability is a stand-alone application (extract&use)
Download:
www.excessive-software.tk
- spremenil: RejZoR ()
| » | C-disk se mi sam polni ???Oddelek: Pomoč in nasveti | 12056 (11151) | cookyx |
| » | Internet explorer se ugasa - sam od sebe... HELP !Oddelek: Pomoč in nasveti | 2095 (1983) | jarni2 |
| » | Internet Explorer mi povzroča težaveOddelek: Pomoč in nasveti | 2298 (1963) | neres |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2545 (2511) | Mercier |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2613 (2209) | Swiwer |
