Forum » Operacijski sistemi » problem prijavljanja v account
ql000 ::
kot pie e v naslovu: ne morem se prijavit v svoj acc na Suse 9.1! Vpisem svoj username in masword pol me pa sam vrze na zacetek, tj. na isto okno. sploh se ne prijavi v sistem! kaj bi bilo lahk narobe!
ql000 ::
mnja ko bi blo vsaj! V primeru, da je napacno geslo pac sporoci login failed. probal sem ustvarit nov user acc in se lahko brez problema logiram, v mojega pa ne! a je mozn, da je kak program, ki je laufal ob shutdownu usu account, al kaj takega?
laufal sem: azureusa, amsn, skype, setiathome, thunderbird-a in karambo.
Gandalfar ::
dej si najprej spremeni password unega prvotnega userja
/var/log/auth.log bi se tudi splacalo pogeldat
ql000 ::
sem spremeni password prvotnega userja: nobenega efekta.
v /var/log fileta z imenom auth.log sploh ni!
da se malo bolj natancno simptome opisem:
pac vpisem username, password, potrdim, monitor za trenutek postane crn in sem spet v prijavnem oknu. V /var/log/XFree86.0.log sem najdu eno par errorjev:
(WW) NVIDIA(0): Failed to set up write-combining range (0xf0000000,0x2000000)
(II) NVIDIA(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Indirect CPU to Screen color expansion
Solid Lines
Scanline Image Writes
Offscreen Pixmaps
Setting up tile and stipple cache:
32 128x128 slots
32 256x256 slots
16 512x512 slots
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(**) Option "dpms"
(**) NVIDIA(0): DPMS enabled
(WW) NVIDIA(0): Option "CalcAlgorithm" is not used
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Keyboard "Keyboard[0]" handled by legacy driver
(**) Option "Protocol" "explorerps/2"
(**) Mouse[1]: Device: "/dev/input/mice"
(**) Mouse[1]: Protocol: "explorerps/2"
(**) Option "CorePointer"
(**) Mouse[1]: Core Pointer
(**) Option "Device" "/dev/input/mice"
(**) Option "Buttons" "7"
(==) Mouse[1]: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" "4 5"
(**) Mouse[1]: ZAxisMapping: buttons 4 and 5
(**) Mouse[1]: Buttons: 7
(II) XINPUT: Adding extended input device "Mouse[1]" (type: MOUSE)
(II) Server_Terminate keybinding not found
(II) Mouse[1]: ps2EnableDataReporting: succeeded
Could not init font path element /usr/X11R6/lib/X11/fonts/local, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/CID, removing from list!
Could not init font path element /usr/local/share/fonts, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts, removing from list!
SetClientVersion: 0 8
se tu mogoce pojavi kriticna napaka?
Solid Lines
Offscreen Pixmaps
32 128x128 slots
32 256x256 slots
16 512x512 slots
(**) Option "dpms"
(==) RandR enabled
borchi ::
probej ugasnat Xe in iz konzole pod svojim userjem startat Xe. boš vsaj vede, če je v desktop managerju problem (verjento ma suse kdm?).
a kot root pa se lahko prijaviš.
l'jga
ql000 ::
ja pa sej to je največji štos! Če se logiram kot root sploh ni nobenih problemov, sam kot user mam pa veselico! Na kakšen način se lahko logiram kot user v konzolo?
ok, če je v desktop managerju problem kako lahko zadevo popravim (matr kaj bi dal za system restore!)? Nima Microsoft samo smotanih idej!
- spremenil: ql000 ()
ql000 ::
evo feedbacka: v konzoli se logiram kot user, potem startx, dobim neke errorje:
connection to ":0.0" refused by server
invalid MIT-MAGIC-COOKIE-1 key
unable to connect to X server
no such process (errno 3): server error
ja pa na zacetku pove, da X server ze laufa!
ql000 ::
kako?
ej kaj bi se zgodilo, e bi upgradal na 9.2 professional. Kaj bi se zgodilo z /home direktorijem in z maili na thunderbirdu, pa e z drugimi programi, ki laufajo gor (Azureus,..)?
Gandalfar ::
Nic. Programi bi se posodobili in uporabljali naprej nastavitve iz tvojega ~ (ce ga bi pri upgrejdu ne bi zbrisal)
ql000 ::
ma qrc! sem upgradal na 9.2 professional. Isto sranje, matr sem že čist... kake so še kaj variante? Kako lahko window managerja ponovno nastavim, naložim, kar koli, sam da probam!
Gandalfar ::
poglej si tvoje .* datoteke
Meni je v taksnih situacijah pomagalo, da sem zbrisal (premaknil) nastavitvene datoteke
kot root naredi
mkdir /home/ql000/backup
mv /home/ql000/.* /home/ql000/backup
in se poskusi logirat. Ce to dela lahko zacnes selit svoje config datoteke pocasi cez.
kot root naredi
Gandalfar ::
Pomojem da nic.
a1200:~# mkdir /home/livecd/backup
a1200:~# ls -la /home/livecd/.*
-rw------- 1 livecd livecd 2335 Jan 28 23:38 /home/livecd/.bash_history
-rw-r--r-- 1 livecd livecd 414 Dec 30 00:08 /home/livecd/.bash_profile
-rw-r--r-- 1 livecd livecd 2063 Dec 30 20:13 /home/livecd/.bashrc
-rw-r--r-- 1 livecd livecd 14810 Jan 28 20:27 /home/livecd/.fonts.cache-1
-rw-r--r-- 1 livecd livecd 363 Jan 28 23:00 /home/livecd/.ibuild.conf
-rw------- 1 livecd livecd 3744 Jan 28 20:42 /home/livecd/.viminfo
a1200:~# mv /home/livecd/.* /home/livecd/backup/
mv: cannot overwrite directory `/home/livecd/backup/.'
mv: cannot overwrite directory `/home/livecd/backup/..'
a1200:~# ls -la /home/livecd/backup/
total 36
drwxr-xr-x 7 root root 352 Jan 29 01:50 .
drwxr-xr-x 4 livecd livecd 160 Jan 29 01:50 ..
-rw------- 1 livecd livecd 2335 Jan 28 23:38 .bash_history
-rw-r--r-- 1 livecd livecd 414 Dec 30 00:08 .bash_profile
-rw-r--r-- 1 livecd livecd 2063 Dec 30 20:13 .bashrc
-rw-r--r-- 1 livecd livecd 14810 Jan 28 20:27 .fonts.cache-1
drwxr-xr-x 2 livecd livecd 112 Dec 30 00:08 .freemind
drwx------ 2 livecd livecd 48 Jan 28 20:27 .gconf
drwx------ 2 livecd livecd 80 Jan 28 23:00 .gconfd
drwx------ 2 livecd livecd 48 Dec 30 00:37 .gnome
-rw-r--r-- 1 livecd livecd 363 Jan 28 23:00 .ibuild.conf
drwx------ 2 livecd livecd 48 Dec 30 23:03 .ssh
-rw------- 1 livecd livecd 3744 Jan 28 20:42 .viminfo
a1200:~# ls -la /home/livecd.*
ls: /home/livecd.*: No such file or directory
total 36
ql000 ::
ok bom zvečer probal, se je treba učit, k so izpiti! Ampak, kaj je najhujše pri vsej stvari? Da jo ta šmorn naredila moja punca, ki za piko na i pojma nima kaj je sploh naredila. Po ženko pravi, da se je citiram: "nekaj pokazalo" konec citata.
Matr brez njih res ni nikdar dolgcajt!
Hvala obema za pomoč! Zvečer poročam o situaciji!
ql000 ::
zadevščina ni delovala! Kakor koli, danes zvečer mi je poču film, backapiral sem dokumente in ostale zadevščine, formatiral particijo in sedaj že laufam suse 9.2. Hvala še enkrat!
| » | MacBook pro- ni slike v ne-osX (linux, win)Oddelek: Strojna oprema | 1112 (1068) | zee |
| » | Gentoo install (strani: 1 2 )Oddelek: Operacijski sistemi | 6461 (5881) | HerrBaron |
| » | kde in resolucijaOddelek: Operacijski sistemi | 1995 (1863) | moj_nick |
| » | manjka ukaz emergeOddelek: Operacijski sistemi | 1820 (1590) | Brane2 |
| » | Vtis Gentoo Linux 1.4Oddelek: Operacijski sistemi | 1756 (1520) | Brane2 |
